Datasheet LT1083, LT1084, LT1085 (Analog Devices) - 7
Описание7.5A, 5A, 3A Low Dropout Positive Adjustable Regulators
Страниц / Страница22 / 7 — Typical perForMance characTerisTics. LT1083. Dropout Voltage. …
Формат / Размер файлаPDF / 293 Кб
Typical perForMance characTerisTics. LT1083. Dropout Voltage. Short-Circuit Current. Load Regulation. LT1084. LT1085
Typical perForMance characTerisTics LT1083 Dropout Voltage Short-Circuit Current Load Regulation LT1084 LT1085
29 предложений от 16 поставщиков
Linear Voltage Regulator IC Positive Fixed 1 Output 3A DDPAK-3
727GS
LT1085IM#TRPBF
от 204 ₽
Эиком
LT1085IM#TRPBF
от 1 385 ₽
LT1085IM-3.6#TRPBF
LT1085IM#TRPBF
LT1083/LT1084/LT1085
Typical perForMance characTerisTics LT1083 LT1083 LT1083 Dropout Voltage Short-Circuit Current Load Regulation
2 12 0.10 INDICATES GUARANTEED TEST POINT ∆I = 7.5A –40°C ≤ TJ ≤ 150°C 10 25°C 0.05 0°C ≤ TJ ≤ 125°C 150°C 8 0 1 6 –0.05 TJ = 150°C –55°C T –0.10 J = 25°C 4 TJ = –55°C SHORT-CIRCUIT CURRENT (A) 2 I OUTPUT VOLTAGE DEVIATION (%) –0.15 FULL LOAD MINIMUM INPUT/OUTPUT DIFFERENTIAL (V) GUARANTEED 0 0 –0.20 0 1 2 3 4 5 6 7 8 9 10 0 5 10 15 20 25 30 35 –50 –25 0 25 50 75 100 125 150 OUTPUT CURRENT (A) INPUT/OUTPUT DIFFERENTIAL (V) TEMPERATURE (°C) LT1083/4/5 ADJ G01 LT1083/4/5 ADJ G02 LT1083/4/5 ADJ G03
LT1084 LT1084 LT1084 Dropout Voltage Short-Circuit Current Load Regulation
2 10 0.10 INDICATES GUARANTEED TEST POINT 9 ∆I = 5A –55°C ≤ TJ ≤ 150°C 8 0.05 0°C ≤ TJ ≤ 125°C 7 150°C 0 6 25°C –55°C 1 5 –0.05 TJ = –55°C 4 T –0.10 T J = 25°C 3 J = 150°C SHORT-CIRCUIT CURRENT (A) 2 –0.15 OUTPUT VOLTAGE DEVIATION (%) 1 IFULL LOAD MINIMUN INPUT/OUTPUT DIFFERENTIAL (V) GUARANTEED 0 0 –0.20 0 1 2 3 4 5 6 0 5 10 15 20 25 30 35 –50 –25 0 25 50 75 100 125 150 OUTPUT CURRENT (A) INPUT/OUTPUT DIFFERENTIAL (V) TEMPERATURE (°C) LT1083/4/5 ADJ G04 LT1083/4/5 ADJ G05 LT1083/4/5 ADJ G06
LT1085 LT1085 LT1085 Dropout Voltage Short-Circuit Current Load Regulation
2 6 0.10 INDICATES GUARANTEED TEST POINT ∆I = 3A 5 0.05 –55°C ≤ TJ ≤ 150°C 0°C ≤ TJ ≤ 125°C 4 25°C 0 150°C 1 TJ = –55°C 3 –0.05 TJ = 25°C –55°C TJ = 150°C 2 –0.10 SHORT-CIRCUIT CURRENT (A) I 1 FULL LOAD –0.15 GUARANTEED OUTPUT VOLTAGE DEVIATION (%) MINIMUM INPUT/OUTPUT DIFFERENTIAL (V) 0 0 –0.20 0 1 2 3 4 0 5 10 15 20 25 30 35 –50 –25 0 25 50 75 100 125 150 OUTPUT CURRENT (A) INPUT/OUTPUT DIFFERENTIAL (V) TEMPERATURE (°C) LT1083/4/5 ADJ G07 LT1083/4/5 ADJ G08 LT1083/4/5 ADJ G09 108345fh For more information www.linear.com/LT1083 7 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Block Diagram Applications Information Typical Application Package Description Revision History Typical Applications Related Parts
