Datasheet LT3012 (Analog Devices) - 15
Описание250mA, 4V to 80V Low Dropout Micropower Linear Regulator
Страниц / Страница16 / 15 — PACKAGE DESCRIPTION. DE Package. 12-Lead Plastic DFN (4mm. 3mm). FE …
Формат / Размер файлаPDF / 188 Кб
PACKAGE DESCRIPTION. DE Package. 12-Lead Plastic DFN (4mm. 3mm). FE Package. 16-Lead Plastic TSSOP (4.4mm)
PACKAGE DESCRIPTION DE Package 12-Lead Plastic DFN (4mm 3mm) FE Package 16-Lead Plastic TSSOP (4.4mm)
30 предложений от 15 поставщиков
Чип стабилизации напряжения, Linear Voltage Regulator IC Positive Adjustable 1 Output 1.24V ~ 60V 250mA 16-TSSOP-EP
LT3012EFE#TRPBF
от 99 ₽
LT3012EFE#TRPBF
188 ₽
LT3012EFE#TRPBF
271 ₽
ЗУМ-СМД
LT3012EFE#TRPBF
LT3012
3mm)
(Reference LTC DWG # 05-08-1695) 4.00 ±0.10 R = 0.115 0.40 ± 0.10 (2 SIDES) TYP 7 12 0.70 ±0.05 R = 0.05 TYP 3.30 ±0.05 3.30 ±0.10 3.60 ±0.05 3.00 ±0.10 2.20 ±0.05 1.70 ± 0.05 (2 SIDES) 1.70 ± 0.10 PIN 1 PIN 1 NOTCH TOP MARK R = 0.20 OR PACKAGE (NOTE 6) 0.35 × 45° OUTLINE CHAMFER 6 1 (UE12/DE12) DFN 0806 REV D 0.25 ± 0.05 0.200 REF 0.75 ±0.05 0.25 ± 0.05 0.50 BSC 0.50 BSC 2.50 REF 2.50 REF RECOMMENDED SOLDER PAD PITCH AND DIMENSIONS 0.00 – 0.05 BOTTOM VIEW—EXPOSED PAD APPLY SOLDER MASK TO AREAS THAT ARE NOT SOLDERED NOTE: 1. DRAWING PROPOSED TO BE A VARIATION OF VERSION (WGED) IN JEDEC PACKAGE OUTLINE M0-229 2. DRAWING NOT TO SCALE 3. ALL DIMENSIONS ARE IN MILLIMETERS 4. DIMENSIONS OF EXPOSED PAD ON BOTTOM OF PACKAGE DO NOT INCLUDE MOLD FLASH. MOLD FLASH, IF PRESENT, SHALL NOT EXCEED 0.15mm ON ANY SIDE 5. EXPOSED PAD SHALL BE SOLDER PLATED 6. SHADED AREA IS ONLY A REFERENCE FOR PIN 1 LOCATION ON THE TOP AND BOTTOM OF PACKAGE
(Reference LTC DWG # 05-08-1663)
Exposed Pad Variation BB
4.90 – 5.10* (.193 – .201) 3.58 (.141) 3.58 (.141) 16 1514 13 12 10 11 9 6.60 ±0.10 2.94 4.50 ±0.10 (.116) SEE NOTE 4 2.94 6.40 (.116) (.252) 0.45 ±0.05 BSC 1.05 ±0.10 0.65 BSC 1 2 3 4 5 6 7 8 RECOMMENDED SOLDER PAD LAYOUT 1.10 4.30 – 4.50* (.0433) 0.25 (.169 – .177) MAX REF 0° – 8° 0.65 0.09 – 0.20 0.50 – 0.75 (.0256) 0.05 – 0.15 (.0035 – .0079) (.020 – .030) BSC (.002 – .006) 0.195 – 0.30 FE16 (BB) TSSOP 0204 (.0077 – .0118) TYP NOTE: 1. CONTROLLING DIMENSION: MILLIMETERS 4. RECOMMENDED MINIMUM PCB METAL SIZE MILLIMETERS FOR EXPOSED PAD ATTACHMENT 2. DIMENSIONS ARE IN (INCHES) *DIMENSIONS DO NOT INCLUDE MOLD FLASH. MOLD FLASH SHALL NOT EXCEED 0.150mm (.006") PER SIDE 3. DRAWING NOT TO SCALE 3012fd Information furnished by Linear Technology Corporation is believed to be accurate and reliable. However, no responsibility is assumed for its use. Linear Technology Corporation makes no representa- tion that the interconnection of its circuits as described herein will not infringe on existing patent rights. 15
