Datasheet LT3022, LT3022-1.2, LT3022-1.5, LT3022-1.8 (Analog Devices) - 2
Описание1A, 0.9V to 10V, Very Low Dropout Linear Regulator
Страниц / Страница20 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION
Формат / Размер файлаPDF / 581 Кб
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION
34 предложений от 16 поставщиков
Микросхемы управления электропитанием - Стабилизаторы напряжения - Линейные
LT3022IMSE#TRPBF
от 144 ₽
LT3022IMSE-1.8#TRPBF
314 ₽
LT3022IMSE#TRPBF
386 ₽
727GS
LT3022IMSE#TRPBF
LT3022/LT3022-1.2 LT3022-1.5/LT3022-1.8
IN Pin Voltage .. ±10V Operating Junction Temperature Range OUT Pin Voltage ... ±10V E-, I-Grades (Notes 2, 3) ... –40°C to 125°C Input-to-Output Differential Voltage ... ±10V Storage Temperature Range ... –65°C to 150°C ADJ/SENSE Pin Voltage ... ±10V Lead Temperature (Soldering, 10 sec) SHDN Pin Voltage .. ±10V MSOP Package .. 300°C Output Short-Circuit Duration ... Indefinite
PIN CONFIGURATION
TOP VIEW NC 1 16 NC TOP VIEW NC 2 15 NC NC 1 16 NC NC 2 15 NC OUT 3 14 IN OUT 3 14 IN OUT 4 17 13 IN OUT 4 13 17 IN ADJ/SENSE* 5 GND 12 IN GND ADJ 5 12 IN AGND 6 11 PGND AGND 7 10 PGND AGND 6 11 PGND NC 8 9 SHDN AGND 7 10 PGND MSE PACKAGE 16-LEAD PLASTIC MSOP NC 8 9 SHDN TJMAX = 125°C, qJA = 38°C/W**, qJC = 5°C/W TO 10°C/W EXPOSED PAD (PIN 17) IS GND, MUST BE SOLDERED TO PCB DHC PACKAGE *PIN 5: ADJ FOR LT3022 16-LEAD (5mm × 3mm) PLASTIC DFN SENSE FOR LT3022-1.2/LT3022-1.5/LT3022-1.8 TJMAX = 125°C, qJA = 38°C/W*, qJC = 4°C/W **SEE THE APPLICATIONS INFORMATION SECTION EXPOSED PAD (PIN 17) IS GND, MUST BE SOLDERED TO PCB *SEE THE APPLICATIONS INFORMATION SECTION 3022fb 2 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Package Description Revision History Typical Application Related Parts
