Datasheet LT3024 (Analog Devices) - 3
ОписаниеDual 100mA/500mA Low Dropout, Low Noise, Micropower Regulator
Страниц / Страница20 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 264 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
15 предложений от 12 поставщиков
Чип стабилизации напряжения, Linear Voltage Regulator IC Positive Adjustable 2 Output 1.22V ~ 20V 500mA, 100mA 16-TSSOP-EP
LT3024EFE#TRPBF
107 ₽
SUV System
LT3024EFE#TRPBF
Hi-Tech Circuit Group
LT3024EFE#TRPBF
LT3024EFE#TRPBF
LT3024
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 2) PARAMETER CONDITIONS MIN TYP MAX UNITS
Minimum Input Voltage Output 2, ILOAD = 100mA l 1.8 2.3 V (Notes 3, 11) Output 1, ILOAD = 500mA l 1.8 2.3 V ADJ1, ADJ2 Pin Voltage VIN = 2V, ILOAD = 1mA 1.205 1.220 1.235 V (Note 3, 4) Output 2, 2.3V < VIN < 20V, 1mA < ILOAD < 100mA l 1.190 1.220 1.250 V Output 1, 2.3V < VIN < 20V, 1mA < ILOAD < 500mA l 1.190 1.220 1.250 V Line Regulation (Note 3) ΔVIN = 2V to 20V, ILOAD = 1mA l 1 10 mV Load Regulation (Note 3) Output 2, VIN = 2.3V, ΔILOAD = 1mA to 100mA 1 12 mV VIN = 2.3V, ΔILOAD = 1mA to 100mA l 25 mV Output 1, VIN = 2.3V, ΔILOAD = 1mA to 500mA 1 12 mV VIN = 2.3V, ΔILOAD = 1mA to 500mA l 25 mV Dropout Voltage (Output 2) ILOAD = 1mA 0.10 0.15 V VIN = VOUT(NOMINAL) (Notes 5, 6, 11) ILOAD = 1mA l 0.19 V ILOAD = 10mA 0.17 0.22 V ILOAD = 10mA l 0.29 V ILOAD = 50mA 0.24 0.31 V ILOAD = 50mA l 0.40 V ILOAD = 100mA 0.30 0.35 V ILOAD = 100mA l 0.45 V Dropout Voltage (Output 1) ILOAD = 10mA 0.13 0.19 V VIN = VOUT(NOMINAL) (Notes 5, 6, 11) ILOAD = 10mA l 0.25 V ILOAD = 50mA 0.17 0.22 V ILOAD = 50mA l 0.32 V ILOAD = 100mA 0.20 0.34 V ILOAD = 100mA l 0.44 V ILOAD = 500mA 0.30 0.35 V ILOAD = 500mA l 0.45 V GND Pin Current (Output 2) ILOAD = 0mA l 20 45 μA VIN = VOUT(NOMINAL) (Notes 5, 7) ILOAD = 1mA l 55 90 μA ILOAD = 10mA l 230 400 μA ILOAD = 50mA l 1 2 mA ILOAD = 100mA l 2.2 4 mA GND Pin Current (Output 1) ILOAD = 0mA l 30 75 μA VIN = VOUT(NOMINAL) (Notes 5, 7) ILOAD = 1mA l 65 120 μA ILOAD = 50mA l 1.1 1.6 mA ILOAD = 100mA l 2 3 mA ILOAD = 250mA l 5 8 mA ILOAD = 500mA l 11 16 mA Output Voltage Noise COUT = 10μF, CBYP = 0.01μF, ILOAD = Full Current, 20 μVRMS BW = 10Hz to 100kHz ADJ Pin Bias Current ADJ1, ADJ2 (Notes 3, 8) 30 100 nA Shutdown Threshold VOUT = Off to On l 0.8 1.4 V VOUT = On to Off l 0.25 0.65 V SHDN1/SHDN2 Pin Current VSHDN1, VSHDN2 = 0V l 0 0.5 μA (Note 9) VSHDN1, VSHDN2 = 20V l 1 3 μA Quiescent Current in Shutdown VIN = 6V, VSHDN1 = 0V, VSHDN2 = 0V 0.01 0.1 μA Ripple Rejection VIN = 2.72V (Avg), VRIPPLE = 0.5VP-P, fRIPPLE = 120Hz, 55 65 dB ILOAD = Full Current 3024fa 3
