Datasheet LT3063 (Analog Devices) - 2
Описание45V VIN, Micropower, Low Noise, 200mA LDO with Active Output Discharge
Страниц / Страница22 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION …
Формат / Размер файлаPDF / 975 Кб
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION http://www.linear.com/product/LT3063#orderinfo
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION http://www.linear.com/product/LT3063#orderinfo
5 предложений от 5 поставщиков
IC REG LINEAR 3.3V 200MA 8DFN
LT3063IDCB-3.3#TRPBF
212 ₽
263 ₽
LT3063 Series
IN Pin Voltage ...±50V Operating Junction Temperature (Notes 3, 5, 12) OUT Pin Voltage .. +20V, –1V LT3063E, LT3063I ... –40°C to 125°C Input to Output Differential Voltage (Note 2) ...±50V LT3063MP ... –55°C to 150°C ADJ Pin Voltage ..±50V LT3063H .. –40°C to 150°C SHDN Pin Voltage ...±50V Storage Temperature Range .. –65°C to 150°C REF/BYP Pin Voltage .. –0.3V to 1V Lead Temperature (Soldering, 10 sec) Output Short-Circuit Duration .. Indefinite MS8E Package Only ..300°C
PIN CONFIGURATION
TOP VIEW TOP VIEW REF/BYP 1 8 GND REF/BYP 1 8 GND ADJ 2 7 SHDN 9 ADJ 2 9 7 SHDN OUT GND 3 6 IN OUT 3 GND 6 IN OUT 4 5 IN OUT 4 5 IN MS8E PACKAGE DCB PACKAGE 8-LEAD PLASTIC MSOP 8-LEAD (2mm × 3mm) PLASTIC DFN TJMAX = 150°C, θJA = 29°C/W TO 45°C/W, θJC = 5°C/W to 10°C/W T EXPOSED PAD (PIN 9) IS GND, MUST BE SOLDERED TO PCB JMAX = 150°C, θJA = 38°C/W TO 45°C/W, θJC = 3.5°C/W EXPOSED PAD (PIN 9) IS GND, MUST BE SOLDERED TO PCB
ORDER INFORMATION http://www.linear.com/product/LT3063#orderinfo LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LT3063EDCB#PBF LT3063EDCB#TRPBF LGMZ 8-Lead (2mm × 3mm) Plastic DFN –40°C to 125°C LT3063IDCB#PBF LT3063IDCB#TRPBF LGMZ 8-Lead (2mm × 3mm) Plastic DFN –40°C to 125°C LT3063HDCB#PBF LT3063HDCB#TRPBF LGMZ 8-Lead (2mm × 3mm) Plastic DFN –40°C to 150°C LT3063MPDCB#PBF LT3063MPDCB#TRPBF LGMZ 8-Lead (2mm × 3mm) Plastic DFN –55°C to 150°C LT3063EMS8E#PBF LT3063EMS8E#TRPBF LTGNB 8-Lead Plastic MSOP –40°C to 125°C LT3063IMS8E#PBF LT3063IMS8E#TRPBF LTGNB 8-Lead Plastic MSOP –40°C to 125°C LT3063HMS8E#PBF LT3063HMS8E#TRPBF LTGNB 8-Lead Plastic MSOP –40°C to 150°C LT3063MPMS8E#PBF LT3063MPMS8E#TRPBF LTGNB 8-Lead Plastic MSOP –55°C to 150°C LT3063EDCB-3.3#PBF LT3063EDCB-3.3#TRPBF LGYV 8-Lead (2mm x 3mm) Plastic DFN –40°C to 125°C LT3063IDCB-3.3#PBF LT3063IDCB-3.3#TRPBF LGYV 8-Lead (2mm x 3mm) Plastic DFN –40°C to 125°C LT3063EDCB-5#PBF LT3063EDCB-5#TRPBF LGYW 8-Lead (2mm x 3mm) Plastic DFN –40°C to 125°C LT3063IDCB-5#PBF LT3063IDCB-5#TRPBF LGYW 8-Lead (2mm x 3mm) Plastic DFN –40°C to 125°C LT3063EMS8E-3.3#PBF LT3063EMS8E-3.3#TRPBF LTGZD 8-Lead Plastic MSOP –40°C to 125°C LT3063IMS8E-3.3#PBF LT3063IMS8E-3.3#TRPBF LTGZD 8-Lead Plastic MSOP –40°C to 125°C LT3063EMS8E-5#PBF LT3063EMS8E-5#TRPBF LTGZC 8-Lead Plastic MSOP –40°C to 125°C LT3063IMS8E-5#PBF LT3063IMS8E-5#TRPBF LTGZC 8-Lead Plastic MSOP –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix. 3063fa 2 For more information www.linear.com/LT3063 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Applications Information Package Description Revision History Typical Application Related Parts
