Datasheet LT1308A, LT1308B (Analog Devices) - 3
ОписаниеSingle Cell High Current Micropower 600kHz Boost DC/DC Converter
Страниц / Страница20 / 3 — The. ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 381 Кб
The. ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply over the full operating temperature
The ELECTRICAL CHARACTERISTICS denotes the specifi cations which apply over the full operating temperature
48 предложений от 26 поставщиков
LT1308BCS8#PBF
227 ₽
727GS
LT1308BCS8#TRPBF
LT1308BCS8
ТаймЧипс
LT1308BCS8#PBF
LT1308A/LT1308B
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. Commercial Grade 0°C to 70°C. VIN = 1.1V, VSHDN = VIN, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IQ Quiescent Current Not Switching, LT1308A 140 240 μA Switching, LT1308B 2.5 4 mA VSHDN = 0V (LT1308A/LT1308B) 0.01 1 μA VFB Feedback Voltage l 1.20 1.22 1.24 V IB FB Pin Bias Current (Note 3) l 27 80 nA Reference Line Regulation 1.1V ≤ VIN ≤ 2V l 0.03 0.4 %/V 2V ≤ VIN ≤ 10V 0.01 0.2 %/V Minimum Input Voltage 0.92 1 V gm Error Amp Transconductance ∆I = 5μA 60 μmhos AV Error Amp Voltage Gain 100 V/V fOSC Switching Frequency VIN = 1.2V l 500 600 700 kHz Maximum Duty Cycle l 82 90 % Switch Current Limit Duty Cycle = 30% (Note 4) 2 3 4.5 A Switch VCESAT ISW = 2A (25°C, 0°C), VIN = 1.5V 290 350 mV ISW = 2A (70°C), VIN = 1.5V 330 400 mV Burst Mode Operation Switch Current Limit VIN = 2.5V, Circuit of Figure 1 400 mA (LT1308A) Shutdown Pin Current VSHDN = 1.1V l 2 5 μA VSHDN = 6V l 20 35 μA VSHDN = 0V l 0.01 0.1 μA LBI Threshold Voltage 196 200 204 mV l 194 200 206 mV LBO Output Low ISINK = 50μA l 0.1 0.25 V LBO Leakage Current VLBI = 250mV, VLBO = 5V l 0.01 0.1 μA LBI Input Bias Current (Note 5) VLBI = 150mV 33 100 nA Low-Battery Detector Gain 3000 V/V Switch Leakage Current VSW = 5V l 0.01 10 μA
The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. Industrial Grade –40°C to 85°C. VIN = 1.2V, VSHDN = VIN, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IQ Quiescent Current Not Switching, LT1308A l 140 240 μA Switching, LT1308B l 2.5 4 mA VSHDN = 0V (LT1308A/LT1308B) l 0.01 1 μA VFB Feedback Voltage l 1.19 1.22 1.25 V IB FB Pin Bias Current (Note 3) l 27 80 nA Reference Line Regulation 1.1V ≤ VIN ≤ 2V l 0.05 0.4 %/V 2V ≤ VIN ≤ 10V l 0.01 0.2 %/V Minimum Input Voltage 0.92 1 V gm Error Amp Transconductance ∆I = 5μA 60 μmhos AV Error Amp Voltage Gain 100 V/V 1308abfb 3
