Datasheet LT1610 (Analog Devices) - 3
Описание1.7MHz, Single Cell Micropower DC/DC Converter
Страниц / Страница16 / 3 — ELECTRICAL CH. ARA TERISTICS The. denotes specifications which apply over …
Формат / Размер файлаPDF / 224 Кб
ELECTRICAL CH. ARA TERISTICS The. denotes specifications which apply over the specified temperature
ELECTRICAL CH ARA TERISTICS The denotes specifications which apply over the specified temperature
13 предложений от 13 поставщиков
Boost, SEPIC Switching Regulator IC Positive Adjustable 1.23V 1 Output 450mA (Switch) 8-SOIC (0.154, 3.90mm Width)
LT1610IS8#TRPBF
135 ₽
LT1610IS8#TRPBF
156 ₽
LT1610IS8#TRPBF
246 ₽
LT1610IS8#TRPBF
LT1610
ELECTRICAL CH C ARA TERISTICS The
denotes specifications which apply over the specified temperature range, otherwise specifications are at TA = 25
C. Commercial grade 0
C to 70
C, VIN = 1.5V, VSHDN = VIN, unless otherwise noted. (Note 2) PARAMETER CONDITIONS MIN TYP MAX UNITS
Switch Current Limit (Note 3) 450 600 900 mA Switch VCESAT ISW = 300mA 300 350 mV ● 400 mV Switch Leakage Current VSW = 5V 0.01 1 µA SHDN Input Voltage High 1 V SHDN Input Voltage Low 0.3 V SHDN Pin Bias Current VSHDN = 3V 10 µA VSHDN = 0V 0.01 0.1 µA
The
C. Industrial grade – 40
C to 85
C, VIN = 1.5V, VSHDN = VIN, unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS
Minimum Operating Voltage TA = 85°C 0.9 1 V TA = – 40°C 1.25 V Maximum Operating Voltage 8 V Feedback Voltage ● 1.20 1.23 1.26 V Quiescent Current 30 60 µA Quiescent Current in Shutdown VSHDN = 0V, VIN = 2V 0.01 0.5 µA VSHDN = 0V, VIN = 5V 0.01 1.0 µA FB Pin Bias Current ● 27 80 nA Reference Line Regulation 2V ≤ VIN ≤ 8V (– 40°C) 0.03 0.15 %/V 2V ≤ VIN ≤ 8V (85°C) 0.2 %/V Error Amp Transconductance ∆I = 2µA 25 µmhos Error Amp Voltage Gain 100 V/V Switching Frequency (Note 4) ● 1.4 1.7 2 MHz Maximum Duty Cycle (Note 4) 77 80 95 % ● 75 95 % Switch Current Limit 450 600 900 mA Switch VCESAT ISW = 300mA 300 350 mV ● 400 mV Switch Leakage Current VSW = 5V 0.01 1 µA SHDN Input Voltage High 1 V SHDN Input Voltage Low 0.3 V SHDN Pin Bias Current VSHDN = 3V 10 µA VSHDN = 0V 0.01 0.1 µA
Note 1:
Absolute Maximum Ratings are those values beyond which the life
Note 3:
Current limit guaranteed by design and/or correlation to static test. of a device may be impaired. Current limit is affected by duty cycle due to ramp generator. See Block
Note 2:
The LT1610C is guaranteed to meet specified performance from Diagram. 0°C to 70°C and is designed, characterized and expected to meet these
Note 4:
Not 100% tested at 85°C. extended temperature limits, but is not tested at – 40°C and 85°C. The LT1610I is guaranteed to meet the extended temperature limits. 3
