Datasheet LT1618 (Analog Devices) - 3
ОписаниеConstant-Current/Constant-Voltage 1.4MHz Step-Up DC/DC Converter
Страниц / Страница16 / 3 — ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over …
Формат / Размер файлаPDF / 215 Кб
ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes specifications which apply over the full operating
36 предложений от 20 поставщиков
Преобразователь DC/DC, Conv DC-DC 1.6V to 18V Step Up Single-Out 1.263V to 36V Automotive 10Pin DFN EP Tube
LT1618EDD#TRPBF
471 ₽
ЗУМ-СМД
LT1618EDD
Контест
LT1618EDD
LT1618EDD(LAFQ)
LT1618
denotes specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. VIN = 1.6V, VSHDN = 1.6V, unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS
Switch VCESAT ISW = 1A (Note 4) 200 260 mV Switch Leakage Current Switch Off, VSW = 5V 0.01 5 µA SHDN Pin Current VSHDN = 1.6V 5 20 µA Shutdown Threshold (SHDN Pin) 0.3 V Start-Up Threshold (SHDN Pin) 1 V
Note 1:
Absolute Maximum Ratings are those values beyond which the life temperature range are assured by design, characterization, and correlation of a device may be impaired. with statistical process controls.
Note 2:
The LT1618 is guaranteed to meet performance specifications
Note 3:
Bias currents flow into the ISP and ISN pins. from 0°C to 70°C. Specifications over the – 40°C to 85°C operating
Note 4:
Switch current limit and switch VCESAT for the DD package is guaranteed by design and/or correlation to static test.
W U TYPICAL PERFOR A CE CHARACTERISTICS Switch Saturation Voltage (VCE, SAT) FB Pin Voltage and Bias Current Switch Current Limit
500 1.270 4 2.5 FB PIN BIAS CURRENT (nA) 400 2.0 1.265 2 TJ = 125°C VOLTAGE 300 1.5 TJ = 25°C 1.260 0 CURRENT 1.0 200 PEAK CURRENT (A) T FEEDBACK VOLTAGE (V) J = –50°C 1.255 – 2 SATURATION VOLTAGE (mV) 0.5 100 0 1.250 – 4 0 0 0.5 1.0 1.5 2.0 – 50 – 25 0 25 50 75 100 125 – 50 – 25 0 25 50 75 100 125 SWITCH CURRENT (A) TEMPERATURE (°C) TEMPERATURE (°C) 1618 G02 1618 G01 1618 G03
Current Sense Voltage Current Sense Voltage (IADJ Pin = 0V) (VISP, ISN) Quiescent Current
52 60 2.5 50 2.0 VIN = 18V 51 V 40 IN = 1.6V 1.5 50 30 1.0 20 49 QUIESCENT CURRENT (mA) 0.5 CURRENT SENSE VOLTAGE (mV) CURRENT SENSE VOLTAGE (mV) 10 48 0 0 – 50 – 25 0 25 50 75 100 125 0.0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 – 50 – 25 0 25 50 75 100 125 TEMPERATURE (°C) IADJ PIN VOLTAGE (V) TEMPERATURE (°C) 1618 G04 1618 G05 1618 G06 sn1618 1618fas 3
