Линейка продуктов KEEN SIDE
Datasheet LT3582, LT3582-5, LT3582-12 (Analog Devices) - 3
ОписаниеBoost and Single Inductor Inverting DC/DC Converters with Optional I2C Programing and OTP
Страниц / Страница28 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 328 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
43 предложений от 23 поставщиков
ЧипСити
LT3582EUD-5#PBF
229 ₽
Элитан
LT3582EUD-5
666 ₽
ТаймЧипс
LT3582EUD-12TRPBF
LT3582EUD-12PBF
LT3582/LT3582-5/LT3582-12
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 3.6V, VSHDN = VIN unless otherwise noted. (Note 3) Switching Regulator Characteristics SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
TON_MAX Maximum Switch On-Time Inverting and Boost Switches 10 μs ILIMIT_P Boost Switch Current Limit l 285 350 430 mA ILIMIT_N Inverting Switch Current Limit l 490 600 720 mA RON_P Boost Switch On-Resistance ISWP = 200mA 500 mΩ RON_N Inverting Switch On-Resistance ISWN = –400mA 560 mΩ IOFF_P Boost Switch Leakage Current into VSWP = 5V 0.01 0.5 μA SWP Pin IOFF_N Inverting Switch Leakage Current Out of VIN = 5.0, VSWN = 0.0 0.01 1 μA SWN Pin RON_DIS Output Disconnect Switch VCAPP = 10V, RAMPP > 1.4V 1.4 Ω On-Resistance ILIMIT_DIS Output Disconnect Current Limit l 124 155 186 mA IVOUTP_PDS VOUTP Power-Down Discharge Current VOUTP = 8V 2.4 4.8 8.8 mA ICAPP_PDS CAPP Power-Down Discharge Current CAPP = 8V 1.2 2.4 4.4 mA IVOUTN_PDS VOUTN Power-Down Discharge Current VOUTN = –8V –1.4 –2.8 –4.2 mA TSTART-UP Confi guration Start-Up Delay VIN> VIN_MIN and SHDN > VSHDN_VIH to I2C l 64 128 μs Enabled and Power-Up Sequencing Start
Programmable Output Characteristics (Note 6) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VVOUTP Positive Output Voltage LT3582-5 l 4.95 5 5.05 V LT3582-12 l 11.88 12 12.1 V N_VOUTP Positive VOUTP Resolution (Note 2) 9 Bits VVOUTP_LSB VOUTP LSB (Note 2) 25 mV VVOUTP_FS VOUTP Full-Scale Voltage (Note 2) Code = BFh, VPLUS = 1 l 12.56 12.775 12.94 V VVOUTP_MIN VOUTP Minimum Voltage (Note 2) Code = 00h, VPLUS = 0 l 3.152 3.20 3.248 V VVOUTP_LR VOUTP Line Regulation Code = BFh, 2.575 < VIN < 5.5 –0.02 %/V VVOUTN Negative Output Voltage LT3582-5 l –5.075 –5 –4.925 V LT3582-12 l –12.1 –12 –11.868 V N_VOUTN Negative VOUTN Resolution (Note 2) 8 Bits VVOUTN_LSB VOUTN LSB (Note 2) –50 mV VVOUTN_FS VOUTN Full-Scale Voltage (Note 2) Code = FFh l –14.2 –13.95 –13.7 V VVOUTN_MIN VOUTN Minimum Voltage (Note 2) Code = 00h l –1.23 –1.205 –1.18 V VVOUTN_LR VOUTN Line Regulation Code = FFh, 2.575 < VIN < 5.5 –0.01 %/V INL_VOUTP VOUTP Integral Nonlinearity (Notes 2, 4) l ±0.6 LSB DNL_VOUTP VOUTP Differential Nonlinearity (Notes 2, 4) l ±0.6 LSB INL_VOUTN VOUTN Integral Nonlinearity (Note 2) l ±0.85 LSB DNL_VOUTN VOUTN Differential Nonlinearity (Note 2) l ±0.85 LSB IRAMP00 RAMPP/RAMPN Pull-Up Current VRAMPP = 0.0V l 0.7 1.0 1.3 μA IRMP Code = 00 VRAMPN = 0.0V IRAMP01 RAMPP/RAMPN Pull-Up Current (Note 2) VRAMPP = 0.0V l 1.4 2.0 2.6 μA IRMP Code = 01 VRAMPN = 0.0V 3582512fb 3
