Datasheet LT3587 (Analog Devices) - 3
ОписаниеHigh Voltage Monolithic Inverter and Dual Boost
Страниц / Страница24 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 410 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
IC REG BST CUK ADJ TRPL 20QFN. Boost, Cuk Switching Regulator IC Positive and Negative (Dual Rail) Adjustable ±2.5V 3 Output...
LT3587EUD#TRPBF
230 ₽
LT3587EUD#TRPBF
Hi-Tech Circuit Group
LT3587EUD#TRPBF
LT3587EUD-TRPBF
LT3587
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VVIN = 3.6V, VEN/SS1 = VEN/SS3 = VVIN unless otherwise noted (Note 2, 3). PARAMETER CONDITIONS MIN TYP MAX UNITS Boost1
CAP1 Bias Current VCAP1 = 15V, VOUT1 = Open 60 150 μA FB1 Reference Voltage l 1.19 1.22 1.25 V VOUT1 Output Voltage RFB1 = 1MΩ l 14.25 15 15.75 V SW1 Current Limit 800 990 mA SW1 VCESAT ISW1 = 400mA 200 mV SW1 Leakage Current VSW1 = 15V 0.1 5 μA EN/SS1 for Full Inductor Current VFB1 = 1.1V, VFB2 = 0.1V 2.5 V EN/SS1 Shutdown Voltage Threshold l 0.2 V EN/SS1 Pin Bias Current VEN/SS1 = 0V –0.5 –1 –1.5 μA VOUT1 Current Limit VCAP1 = 15V 100 155 mA CAP1 to VOUT1 On-Resistance (RDISC1) VCAP1 = 15V, IVOUT1= 50mA 5 8 Ω VOUT1 Disconnect Leakage VVIN = VCAP1 = 6V, VVOUT1 = 0V 0.1 1 μA
Inverter
FB2 Reference Voltage l –10 5 20 mV Output Voltage RFB2 = 1MΩ l –7.5 –8 –8.5 V SW2 Current Limit 900 1090 mA SW2 VCESAT ISW2 = 600mA 250 mV SW2 Leakage Current VSW2 = 15V 0.1 5 μA FB1 Threshold to Start Negative Channel Percent of Final Regulation Value 87 90 %
Boost3
CAP3 Bias Current VCAP3 = 15V, VOUT3 = Open 70 150 μA Boost3 Programmed Current RIFB3 = 8.06kΩ l 18 20 22 mA VFB3 Reference Voltage RVFB3 = 1MΩ, IVOUT3 = 20mA l 0.77 0.8 0.83 V VOUT3 Output Voltage RVFB3 = 1MΩ, IVOUT3 = 20mA l 14 15 16 V SW3 Current Limit 400 480 mA SW3 VCESAT ISW3 = 200mA 250 mV SW3 Leakage Current VSW3 = 15V 0.1 5 μA EN/SS3 for Full Inductor Current VVFB3 = VIFB3 = 0.6V 2 V EN/SS3 Shutdown Voltage Threshold l 0.2 V EN/SS3 Pin Bias Current VEN/SS3 = 0V –0.5 –1 –1.5 μA VOUT3 Current Limit VCAP3 = 15V, VIFB3 = 0V 70 110 mA CAP3 to VOUT3 On Resistance (RDISC3) VCAP3 = 15V, IVOUT3 = 20mA 10 15 Ω VOUT3 Disconnect Leakage VVIN = VCAP3 = 6V, VVOUT3 = 0V 0.1 1 μA CAP3 Pin Overvoltage Clamp 27 29 31 V
Note 1:
Note 2:
All currents into pins are positive; all voltages are referenced to may cause permanent damage to the device. Exposure to any Absolute GND unless otherwise noted. Maximum Rating condition for extended periods may affect device
Note 3:
The LT3587 is guaranteed to meet specifi ed performance from reliability and lifetime. 0°C to 125°C. Specifi cations over the –40°C to 125°C operating range are assured by design, characterization and correlation with statistical process controls. 3587fc 3
