Datasheet LTC3834 (Analog Devices) - 2
Описание30μA IQ Synchronous Step-Down Controller
Страниц / Страница30 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION …
Формат / Размер файлаPDF / 793 Кб
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING*
29 предложений от 17 поставщиков
Чип стабилизации напряжения, DC-DC converter; step down; Uin:4÷36V; Uout:0.8÷5V; 25A; TSSOP20
727GS
LTC3834IFE#TRPBF
259 ₽
ЧипСити
LTC3834IFE#TRPBF
420 ₽
LTC3834IFE#PBF
LTC3834IFE#TRPBF
LTC3834
Input Supply Voltage (VIN) ... 36V to –0.3V ITH, VFB Voltages .. 2.7V to –0.3V Topside Driver Voltage (BOOST) .. 42V to –0.3V Peak Output Current <10µs (TG, BG) ..3A Switch Voltage (SW) ... 36V to –5V INTVCC Peak Output Current ... 50mA INTVCC, (BOOST-SW), CLKOUT, PGOOD . 8.5V to –0.3V Operating Temperature Range (Note 2)..–40°C to 85°C RUN, TRACK/SS .. 7V to –0.3V Junction Temperature (Note 3) ... 125°C SENSE+, SENSE– Voltages ...11V to –0.3V Storage Temperature Range .. –65°C to 150°C PLLIN/MODE, PHASMD, PLLLPF ...INTVCC to –0.3V Lead Temperature (Soldering, 10 sec) EXTVCC ... 10V to –0.3V FE Package ...300°C
PIN CONFIGURATION
TOP VIEW TOP VIEW CLKOUT 1 20 PHASMD PLLLPF 2 19 PLLIN/MODE PLLLPF CLKOUT PHASMD PLLIN/MODE 20 19 18 17 ITH 3 18 PGOOD TRACKS/SS 4 17 SENSE+ ITH 1 16 PGOOD V TRACK/SS 2 15 SENSE+ FB 5 21 16 SENSE– VFB 3 14 SENSE– SGND 6 15 RUN 21 SGND 4 13 RUN PGND 7 14 BOOST PGND 5 12 BOOST BG 8 13 TG BG 6 11 TG INTVCC 9 12 SW 7 8 9 10 EXTVCC 10 11 VIN V CC V CC V IN SW FE PACKAGE INT 20-LEAD PLASTIC TSSOP EXT UFD PACKAGE TJMAX = 125°C, θJA = 35°C/W 20-PIN (4mm × 5mm) PLASTIC QFN EXPOSED PAD (PIN 21) IS SGND, MUST BE SOLDERED TO PCB TJMAX = 125°C, θJA = 37°C/W EXPOSED PAD (PIN 21) IS SGND, MUST BE SOLDERED TO PCB
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC3834EFE#PBF LTC3834EFE#TRPBF LTC3834FE 20-Lead Plastic TSSOP –40°C to 85°C (Note 2) LTC3834IFE#PBF LTC3834IFE#TRPBF LTC3834FE 20-Lead Plastic TSSOP –40°C to 85°C LTC3834EUFD#PBF LTC3834EUFD#TRPBF 3834 20-Lead (4mm × 5mm) Plastic QFN –40°C to 85°C (Note 2) LTC3834IUFD#PBF LTC3834IUFD#TRPBF 3834 20-Lead (4mm × 5mm) Plastic QFN –40°C to 85°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based finish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/ 3834fc 2 For more information www.linear.com/LTC3834 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Operation Package Description Typical Application Related Parts
