Datasheet LT3475, LT3475-1 (Analog Devices) - 3
ОписаниеDual Step-Down 1.5A LED Driver
Страниц / Страница20 / 3 — The. ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 249 Кб
The. ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply over the full operating
The ELECTRICAL CHARACTERISTICS denotes the specifi cations which apply over the full operating
30 предложений от 20 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Устройства управления светодиодами
LT3475IFE-1#TRPBF
182 ₽
LT3475IFE-1#PBF
318 ₽
LT3475IFE-1#PBF
857 ₽
LT3475IFE-1#PBF
LT3475/LT3475-1
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 12V, VBOOST = 16V, VOUT = 4V unless otherwise noted (Note 3) PARAMETER CONDITIONS MIN TYP MAX UNITS
LED Pin Current VADJ Tied to VREF • 2/3 0.97 1.00 1.03 A ● 0.94 1.04 A VADJ Tied to VREF • 7/30 0.336 0.350 0.364 A LT3475E/LT3475E-1 0°C to 85°C 0.325 0.375 A ● 0.31 0.385 A REF Voltage ● 1.22 1.25 1.27 V Reference Voltage Line Regulation 4V < VIN < 40V 0.05 %/V Reference Voltage Load Regulation 0 < IREF < 500μA 0.0002 %/μA VADJ Pin Bias Current (Note 4) ● 40 400 nA Switching Frequency RT = 24.3k ● 530 600 640 kHz Maximum Duty Cycle RT = 24.3k ● 90 95 % RT = 4.32k 80 % RT = 100k 98 % Switching Phase RT = 24.3k 150 180 210 Deg Foldback Frequency RT = 24.3k, VOUT = 0V 80 kHz SHDN Threshold (to Switch) 2.5 2.6 2.74 V SHDN Pin Current (Note 5) VSHDN = 2.6V 7 9 11 μA PWM Threshold 0.3 0.8 1.2 V VC Switching Threshold 0.8 V VC Source Current VC = 1V 50 μA VC Sink Current VC = 1V 50 μA LED to VC Transresistance 500 V/A LED to VC Current Gain 1 mA/μA VC to Switch Current Gain 2.6 A/V VC Clamp Voltage 1.8 V VC Pin Current in PWM Mode VC = 1V, VPWM = 0.3V ● 10 400 nA OUT Pin Clamp Voltage (LT3475) 13.5 14 14.5 V OUT Pin Current in PWM Mode VOUT = 4V, VPWM = 0.3V ● 25 50 μA Switch Current Limit (Note 6) 2.3 2.7 3.2 A Switch VCESAT ISW =1.5A 350 500 mV BOOST Pin Current ISW =1.5A 25 40 mA Switch Leakage Current 0.1 10 μA Minimum Boost Voltage Above SW 1.8 2.5 V
Note 1:
Note 3:
The LT3475E and LT3475E-1 are guaranteed to meet performance may cause permanent damage to the device. Exposure to any Absolute specifi cations from 0°C to 85°C. Specifi cations over the –40°C to 85°C Maximum Rating condition for extended periods may affect device operating temperature range are assured by design, characterization and reliability and lifetime. correlation with statistical process controls. The LT3475I and LT3475I-1
Note 2:
This IC includes overtemperature protection that is intended are guaranteed to meet performance specifi cations over the –40°C to to protect the device during momentary overload conditions. Junction 125°C operating temperature range. temperature will exceed 125°C when overtemperature protection is active.
Note 4:
Current fl ows out of pin. Continuous operation above the specifi ed maximum operating junction
Note 5:
Current fl ows into pin. temperature may impair device reliability.
Note 6:
Current limit is guaranteed by design and/or correlation to static test. Slope compensation reduces current limit at higher duty cycles. 3475fb 3
