Datasheet LT3746 (Analog Devices) - 4
Описание32-Channel 20mA LED Driver with Buck Controller
Страниц / Страница28 / 4 — elecTrical characTerisTics. The. denotes the specifications which apply …
Формат / Размер файлаPDF / 609 Кб
elecTrical characTerisTics. The. denotes the specifications which apply over the full operating
elecTrical characTerisTics The denotes the specifications which apply over the full operating
IC LED DRVR CTRLR DIM 30MA 56QFN. LED Driver IC 32 Output DC DC Controller Step-Down (Buck) PWM Dimming 30mA 56-QFN...
LT3746EUHH#TRPBF
214 ₽
LT3746EUHH#TRPBF
394 ₽
LT3746EUHH#TRPBF
Hi-Tech Circuit Group
LT3746EUHH#TRPBF
LT3746
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. VIN = 24V, VCC = 3.3V, VEN/UVLO = 1.5V, VFB = 1.5V, VISP = VISN = 0V, RT = 105k, RISET = 60.4k, CCAP = 0.47µF to VIN, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Gate Driver
VBIAS CAP Bias Voltage (VIN – VCAP) 7V < VIN < 55V 6.54 6.77 7.00 V ICAP CAP Bias Current Limit (VIN – VCAP) = VBIAS – 0.5V 22 mA GATE High Level (VIN – VGATE) IGATE = –100mA 0.4 V GATE Low Level (VGATE – VCAP) IGATE = 100mA 0.3 V GATE Rise Time CGATE = 3.3nF to VIN, VIN = 12V 30 ns GATE Fall Time CGATE = 3.3nF to VIN, VIN = 12V 30 ns
LED Driver
VISET Trimmed ISET Pin Voltage l 1.181 1.205 1.229 V LEDxx Operating Voltage VISP = VISN = VLEDxx l 0 13 V LEDxx Leakage Current LED Channel Off, VISP = VISN = 5V, 0.2 µA VLEDxx = 3V ILED LED Constant Sink Current VISP = VISN = 5V, VLEDxx = 0.5V REGDC = 0x00 7 11.5 16 mA REGDC = 0x20 15.5 21.5 27.5 mA REGDC = 0x3F 23 30 37 mA ∆ILEDC Current Mismatch Between Channels VISP = VISN = 5V, VLEDxx = 0.5V, 8 20 % REGDC = 0x20 (Note 6) ∆ILEDD Current Mismatch Between Devices VISP = VISN = 5V, VLEDxx = 0.5V, –15 5 20 % REGDC = 0x20 (Note 7) ∆ILINE LED Current Line Regulation VISP = VISN = 5V, VLEDxx = 0.5V, –0.2 0.2 1 %/V REGDC = 0x20, VCC = 3V to 5.5V (Note 8) ∆ILOAD LED Current Load Regulation VISP = VISN = 5V, REGDC = 0x20, –1 1 3 %/V VLEDxx = 0.5V to 2.5V (Note 9) VOPEN Open LED Threshold VISP = VISN = 5V, VLEDxx Falling 0.1 V VSHT Short LED Threshold VISP = VISN = 5V, VLEDxx Rising 3.65 3.9 4.15 V TLEDON Minimum LED On Time VISP = VISN = 5V, REGGS = 0x001 0.5 µs PWMCK LOGIC VCC = 3V to 5.5V High Level Voltage 2.4 VCC V Low Level Voltage 0 0.6 V
Thermal Protection
ITSET TSET Output Current VTSET = 1V l 19.0 19.8 20.6 µA TSET Over Temperature Threshold TA = 25°C 510 mV
Serial Data Interface
Single-Ended Input (Note 10) VCC = 3V to 5.5V VSIH High Level Voltage 2.4 VCC V VSIL Low Level Voltage 0 0.6 V ISI Single-Ended Input Current VCC = 3V to 5.5V, SI = VCC or GND –0.2 0.2 µA Single-Ended Output (Note 10) VCC = 3V to 5.5V V VSOH High Level Voltage ISO = –1mA VCC – 0.1 V VSOL Low Level Voltage ISO = 1mA 0.1 V 3746fa 4 For more information www.linear.com/3746 Document Outline Description Typical Application Absolute Maximum Ratings Pin Configuration Electrical Characteristics Pin Functions Block Diagram Applications Information Typical Application Related Parts
