Datasheet AD9695 (Analog Devices) - 6
Описание14-Bit, 1300 MSPS/625 MSPS, JESD204B, Dual Analog-to-Digital Converter
Страниц / Страница136 / 6 — Data Sheet. AD9695. SPECIFICATIONS DC SPECIFICATIONS. Table 1. 1300 MSPS. …
ВерсияA
Формат / Размер файлаPDF / 5.6 Мб
Data Sheet. AD9695. SPECIFICATIONS DC SPECIFICATIONS. Table 1. 1300 MSPS. 625 MSPS. Parameter. Min. Typ. Max. Unit
Data Sheet AD9695 SPECIFICATIONS DC SPECIFICATIONS Table 1 1300 MSPS 625 MSPS Parameter Min Typ Max Unit
AD9695BCPZRL7-625
AD9695BCPZRL7-625
AVDD1 = 0.95 V, AVDD1_SR = 0.95 V, AVDD2 = 1.8 V, AVDD3 = 2.5 V, DVDD = 0.95 V, DRVDD1 = 0.95 V, DRVDD2 = 1.8 V, SPIVDD = 1.8 V, clock divider = 2, default input full scale, 0.5 V internal reference, AIN = −1.0 dBFS, default SPI settings, and sample rate = 625 MSPS (AD9695-625 speed grade), sample rate = 1300 MSPS (AD9695-1300 speed grade), DCS on (AD9695-1300 speedgrade), DCS off (AD9695-625 speed grade), unless otherwise noted. Minimum and maximum specifications are guaranteed for the full operating junction temperature (TJ) range of −40°C to +105°C. Typical specifications represent performance at TJ = 35°C (TA = 25°C for the AD9695-625 speed grade) and TJ = 40°C (TA = 25°C for the AD9695-1300 speed grade).
Table 1. 1300 MSPS 625 MSPS Parameter Min Typ Max Min Typ Max Unit
RESOLUTION 14 14 Bits ACCURACY No Missing Codes Guaranteed Guaranteed Offset Error1 5 5 Codes Offset Matching −0.48 0 +0.48 −0.25 0 +0.25 % FSR Gain Error −2.9 ±1 +2.9 −2.6 ±2.22 +2.6 % FSR Gain Matching −2.64 ±0.18 +2.64 −2.5 ±0.18 +2.5 % FSR Differential Nonlinearity (DNL) −0.7 0.8 −0.8 +0.8 LSB Integral Nonlinearity (INL) −7 ±1 5 −5 ±2 +5 LSB TEMPERATURE DRIFT Offset Error ±9 ±6 ppm/°C Gain Error 69 123 ppm/°C INTERNAL VOLTAGE REFERENCE Voltage 0.5 0.5 V INPUT-REFERRED NOISE 3.8 2.7 LSB rms ANALOG INPUTS Differential Input Voltage Range 1.36 1.59 2.04 1.36 1.7 2.04 V p-p Common-Mode Voltage (VCM) 1.41 1.41 V Differential Input Resistance 200 200 Ω Differential Input Capacitance 1.75 1.75 pF Analog Full-Power Bandwidth 2 2 GHz POWER SUPPLY AVDD1 0.93 0.95 0.98 0.93 0.95 0.98 V AVDD2 1.71 1.8 1.89 1.71 1.8 1.89 V AVDD3 2.44 2.5 2.56 2.44 2.5 2.56 V AVDD1_SR 0.93 0.95 0.98 0.93 0.95 0.98 V DVDD 0.93 0.95 0.98 0.93 0.95 0.98 V DRVDD1 0.93 0.95 0.98 0.93 0.95 0.98 V DRVDD2 1.71 1.8 1.89 1.71 1.8 1.89 V SPIVDD2 1.71 1.8 1.89 1.71 1.8 1.89 V IAVDD1 304 383 182 257 mA IAVDD2 450 500 267 292 mA IAVDD3 55 61 29 35 mA IAVDD1_SR 15 27 9 15 mA IDVDD 218 400 103 293 mA I 3 DRVDD1 146 229 103 176 mA IDRVDD2 25 29 28 35 mA ISPIVDD 2 5 2 5 mA POWER CONSUMPTION Total Power Dissipation (Including Output Drivers)4 1.39 1.6 2 0.86 0.98 1.35 W Power-Down Dissipation 215 200 mW Standby5 890 740 mW 1 DC offset calibration on (Register 0x0701, Bit 7 = 1 and Register 0x073B, Bit 7 = 0). 2 The voltage level on the SPIVDD rail and on the DRVDD2 rail must be the same. 3 All lanes running. Power dissipation on DRVDD changes with lane rate and number of lanes used. 4 Default mode. No DDCs used. 5 Can be controlled by SPI. Rev. 0 | Page 5 of 135 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY GENERAL DESCRIPTION PRODUCT HIGHLIGHTS SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS—1300 MSPS AC SPECIFICATIONS—625 MSPS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS 1300 MSPS 625 MSPS EQUIVALENT CIRCUITS THEORY OF OPERATION ADC ARCHITECTURE ANALOG INPUT CONSIDERATIONS Differential Input Configurations Input Common Mode Analog Input Buffer Controls and SFDR Optimization Absolute Maximum Input Swing Dither VOLTAGE REFERENCE DC OFFSET CALIBRATION CLOCK INPUT CONSIDERATIONS Clock Duty Cycle Considerations Input Clock Divider Input Clock Divider ½ Period Delay Adjust Clock Fine Delay and Superfine Delay Adjust Clock Coupling Considerations Clock Jitter Considerations POWER-DOWN/STANDBY MODE TEMPERATURE DIODE ADC OVERRANGE AND FAST DETECT ADC OVERRANGE FAST THRESHOLD DETECTION (FD_A AND FD_B) ADC APPLICATION MODES AND JESD204B Tx CONVERTER MAPPING PROGRAMMABLE FINITE IMPULSE RESPONSE (FIR) FILTERS SUPPORTED MODES PROGRAMMING INSTRUCTIONS DIGITAL DOWNCONVERTER (DDC) DDC I/Q INPUT SELECTION DDC I/Q OUTPUT SELECTION DDC GENERAL DESCRIPTION DDC FREQUENCY TRANSLATION DDC Frequency Translation General Description Variable IF Mode 0 Hz IF (ZIF) Mode fS/4 Hz IF Mode Test Mode DDC NCO Description DDC NCO Programmable Modulus Mode DDC NCO Coherent Mode NCO FTW/POW/MAW/MAB Description NCO FTW/POW/MAW/MAB Programmable Modulus Mode NCO FTW/POW/MAW/MAB Coherent Mode NCO Channel Selection GPIO Level Control Mode GPIO Edge Control Mode Register Map Mode Setting Up the Multichannel NCO Feature NCO Synchronization NCO Multichip Synchronization NCO Multichip Synchronization at Startup NCO Multichip Synchronization During Normal Operation DDC Mixer Description DDC NCO + Mixer Loss and SFDR DDC DECIMATION FILTERS HB4 Filter Description HB3 Filter Description HB2 Filter Description HB1 Filter Description TB2 Filter Description TB1 Filter Description FB2 Filter Description DDC GAIN STAGE DDC COMPLEX TO REAL CONVERSION DDC MIXED DECIMATION SETTINGS DDC EXAMPLE CONFIGURATIONS SIGNAL MONITOR SPORT OVER JESD204B DIGITAL OUTPUTS INTRODUCTION TO THE JESD204B INTERFACE JESD204B OVERVIEW FUNCTIONAL OVERVIEW Transport Layer Data Link Layer Physical Layer JESD204B LINK ESTABLISHMENT Code Group Synchronization (CGS) Initial Lane Alignment Sequence (ILAS) User Data and Error Detection 8-Bit/10-Bit Encoder PHYSICAL LAYER (DRIVER) OUTPUTS Digital Outputs, Timing, and Controls Deemphasis Phase-Locked Loop (PLL) SETTING UP THEAD9695 DIGITAL INTERFACE Example Setup 1—Full Bandwidth Mode Example Setup 2—ADC with DDC Option (Two ADCs Plus Two DDCs) DETERMINISTIC LATENCY SUBCLASS 0 OPERATION SUBCLASS 1 OPERATION Deterministic Latency Requirements Setting Deterministic Latency registers MULTICHIP SYNCHRONIZATION NORMAL MODE TIMESTAMP MODE SYSREF± INPUT SYREF± Control Features SYSREF± SETUP/HOLD WINDOW MONITOR LATENCY END TO END TOTAL LATENCY EXAMPLE LATENCY CALCULATIONS LMFC REFERENCED LATENCY TEST MODES ADC TEST MODES JESD204B BLOCK TEST MODES Transport Layer Sample Test Mode Interface Test Modes Data Link Layer Test Modes SERIAL PORT INTERFACE (SPI) CONFIGURATION USING THE SPI HARDWARE INTERFACE SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE Open and Reserved Locations Default Values Logic Levels Channel Specific Registers SPI Soft Reset MEMORY MAP REGISTERS APPLICATIONS INFORMATION POWER SUPPLY RECOMMENDATIONS LAYOUT GUIDELINES AVDD1_SR (PIN 57) AND AGND_SR (PIN 56 AND PIN 60) OUTLINE DIMENSIONS ORDERING GUIDE
