Datasheet AD9656 (Analog Devices) - 2
ОписаниеQuad, 16-Bit, 125 MSPS JESD204B 1.8 V Analog-to-Digital Converter
Страниц / Страница47 / 2 — AD9656* PRODUCT PAGE QUICK LINKS Last Content Update: 03/25/2017. …
ВерсияA
AD9656* PRODUCT PAGE QUICK LINKS Last Content Update: 03/25/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
AD9656* PRODUCT PAGE QUICK LINKS Last Content Update: 03/25/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
Микросхема Преобразователь AD, ANALOG DEVICES AD9656BCPZ-125 Analog to Digital Converter, 16Bit, 125MSPS, Single, 1.7V, 1.9V, LFCSP
ЗУМ-СМД
AD9656BCPZ-125
17 847 ₽
AD9656BCPZ-125
29 876 ₽
AD9656BCPZ-125
43 944 ₽
Эиком
AD9656BCPZ-125
87 716 ₽
View a parametric search of comparable parts. • AD9656 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • AD9656 Evaluation Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Data Sheet
View all AD9656 EngineerZone Discussions. • AD9656: Quad, 16-Bit, 125 MSPS, JESD204B 1.8 V Analog- to-Digital Converter Data Sheet
SAMPLE AND BUY
Visit the product page to see pricing options.
TOOLS AND SIMULATIONS
• AD9656 Input Impedance
TECHNICAL SUPPORT
• Visual Analog Submit a technical question or find your regional support • AD9656 AMI Model number.
REFERENCE MATERIALS DOCUMENT FEEDBACK Informational
Submit feedback for this data sheet. • JESD204 Serial Interface
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS, VREF = 1.4 V DC SPECIFICATIONS, VREF = 1.0 V AC SPECIFICATIONS, VREF = 1.4 V AC SPECIFICATIONS, VREF = 1.0 V DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS VREF = 1.4 V VREF = 1.0 V EQUIVALENT CIRCUITS THEORY OF OPERATION ANALOG INPUT CONSIDERATIONS Input Common-Mode Voltage Differential Input Configurations VOLTAGE REFERENCE Internal Reference Connection External Reference Operation CLOCK INPUT CONSIDERATIONS Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations POWER DISSIPATION AND POWER-DOWN MODE DIGITAL OUTPUTS JESD204B Transmit Top Level Description JESD204B Overview JESD204B Configurations Initial JESD204B Link Startup Resynchronization JESD204B Synchronization Details CGS Phase ILAS Phase Data Transmission Phase Link Setup Parameters Disable Lanes Before Changing Configuration Select Quick Configuration Option Configure Detailed Options Check FCHK, Checksum of JESD204B Interface Parameters Set Additional Digital Output Configuration Options Reenable Lanes After Configuration Frame and Lane Alignment Monitoring and Correction Digital Outputs and Timing SERIAL PORT INTERFACE (SPI) CONFIGURATION USING THE SPI HARDWARE INTERFACE SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE Open and Reserved Locations Default Values Logic Levels Channel Specific Registers MEMORY MAP REGISTER TABLE MEMORY MAP REGISTER DESCRIPTIONS Device Index (Register 0x05) Transfer (Register 0xFF) Power Modes (Register 0x08) Bit 5—PDWN Pin Function Bit 4—JTX Standby Mode Bits[1:0]—Power Mode Enhancement Control (Register 0x0C) Bit 2—Chop Mode Output Mode (Register 0x14) Bits[7:5]—JTX CS Mode Bits[1:0]—Output Format Clock Phase Control (Register 0x16) Bits[6:4]—Input Clock Phase Adjust JTX User Pattern (Register 0xA0 to Register 0xA7) Resolution/Sample Rate Override (Register 0x100) User I/O Control 2 (Register 0x101) Bit 0—SDIO Pull-Down User I/O Control 3 (Register 0x102) Bit 3—VCM Power-Down APPLICATIONS INFORMATION DESIGN GUIDELINES POWER AND GROUND RECOMMENDATIONS CLOCK STABILITY CONSIDERATIONS EXPOSED PAD THERMAL HEAT SLUG RECOMMENDATIONS VCM REFERENCE DECOUPLING SPI PORT OUTLINE DIMENSIONS ORDERING GUIDE
