Datasheet AD9681 (Analog Devices) - 8
ОписаниеOctal, 14-Bit, 125 MSPS, Serial LVDS, 1.8 V Analog-to-Digital Converter
Страниц / Страница41 / 8 — Data Sheet. AD9681. SWITCHING SPECIFICATIONS. Table 4. Parameter1, 2. …
ВерсияC
Формат / Размер файлаPDF / 1.6 Мб
Data Sheet. AD9681. SWITCHING SPECIFICATIONS. Table 4. Parameter1, 2. Symbol Temp. Min. Typ. Max. Unit
Data Sheet AD9681 SWITCHING SPECIFICATIONS Table 4 Parameter1, 2 Symbol Temp Min Typ Max Unit
17 предложений от 17 поставщиков
Микросхема Преобразователь AD, ANALOG DEVICES AD9681BBCZ-125 Analog to Digital Converter, 14Bit, 125MSPS, Single, 1.7V, 1.9V, CSPBGA
AD9681BBCZ-125
15 599 ₽
Зенер
Россия и страны ТС
AD9681BBCZ-125
28 304 ₽
AD9681BBCZ-125
AD9681BBCZ-125
link to page 26
AVDD = 1.8 V, DRVDD = 1.8 V, 2 V p-p differential input, 1.0 V internal reference, AIN = −1.0 dBFS, unless otherwise noted.
Table 4. Parameter1, 2 Symbol Temp Min Typ Max Unit
CLOCK3 Input Clock Rate Full 10 1000 MHz Conversion Rate4 Full 10 125 MSPS Clock Pulse Width High tEH Full 4.00 ns Clock Pulse Width Low tEL Full 4.00 ns OUTPUT PARAMETERS3 Propagation Delay tPD Full 1.5 2.3 3.1 ns Rise Time (20% to 80%) tR Full 300 ps Fall Time (20% to 80%) tF Full 300 ps FCO±1, FCO±2 Propagation Delay tFCO Full 1.5 2.3 3.1 ns DCO±1, DCO±2 Propagation Delay5 tCPD Full tFCO + (tSAMPLE/16) ns DCO±1, DCO±2 to Data Delay5 tDATA Full (tSAMPLE/16) − 300 (tSAMPLE/16) (tSAMPLE/16) + 300 ps DCO±1, DCO±2 to FCO±1, FCO±2 Delay5 tFRAME Full (tSAMPLE/16) − 300 (tSAMPLE/16) (tSAMPLE/16) + 300 ps Lane Delay tLD 90 ps Data to Data Skew tDATA-MAX − tDATA-MIN Full ±50 ±200 ps Wake-Up Time (Standby) 25°C 250 ns Wake-Up Time (Power-Down)6 25°C 375 μs Pipeline Latency Full 16 Clock cycles APERTURE Aperture Delay tA 25°C 1 ns Aperture Uncertainty (Jitter) tJ 25°C 135 fs rms Out-of-Range Recovery Time 25°C 1 Clock cycles 1 See the AN-835 Application Note, Understanding High Speed ADC Testing and Evaluation, for definitions and for details on how these tests were completed. 2 Measured on standard FR-4 material. 3 Adjustable using the SPI. The conversion rate is the clock rate after the divider. 4 The maximum conversion rate is based on two-lane output mode. See the Digital Outputs and Timing section for the maximum conversion rate in one-lane output mode. 5 tSAMPLE/16 is based on the number of bits in two LVDS data lanes. tSAMPLE = 1/fSAMPLE. 6 Wake-up time is defined as the time required to return to normal operation from power-down mode. Rev. C | Page 7 of 40 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION SIMPLIFIED FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS THEORY OF OPERATION ANALOG INPUT CONSIDERATIONS Input Common Mode Differential Input Configurations VOLTAGE REFERENCE Internal Reference Connection External Reference Operation CLOCK INPUT CONSIDERATIONS Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations POWER DISSIPATION AND POWER-DOWN MODE DIGITAL OUTPUTS AND TIMING SDIO/OLM Pin SCLK/DTP Pin CSB1 and CSB2 Pins RBIAS1 and RBIAS2 Pins OUTPUT TEST MODES SERIAL PORT INTERFACE (SPI) CONFIGURATION USING THE SPI HARDWARE INTERFACE CONFIGURATION WITHOUT THE SPI SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE Open Locations Default Values Logic Levels Channel Specific Registers MEMORY MAP MEMORY MAP REGISTER DESCRIPTIONS Device Index (Register 0x05) Transfer (Register 0xFF) Power Modes (Register 0x08) Enhancement Control (Register 0x0C) Output Mode (Register 0x14) Output Adjust (Register 0x15) Output Phase (Register 0x16) Serial Output Data Control (Register 0x21) Resolution/Sample Rate Override (Register 0x100) User I/O Control 2 (Register 0x101) User I/O Control 3 (Register 0x102) APPLICATIONS INFORMATION DESIGN GUIDELINES POWER AND GROUND RECOMMENDATIONS BOARD LAYOUT CONSIDERATIONS Sources of Coupling Crosstalk Between Inputs Coupling of Digital Output Switching Noise to Analog Inputs and Clock CLOCK STABILITY CONSIDERATIONS VCM REFERENCE DECOUPLING SPI PORT OUTLINE DIMENSIONS ORDERING GUIDE
