Datasheet AD9249 (Analog Devices) - 9
Описание16 Channel 14-Bit, 65 MSPS, Serial LVDS, 1.8 V A/D Converter
Страниц / Страница37 / 9 — AD9249. Data Sheet. Timing Diagrams. N – 1. VIN±x1,. VIN±x2. tEH. tEL. …
AD9249. Data Sheet. Timing Diagrams. N – 1. VIN±x1,. VIN±x2. tEH. tEL. CLK–. CLK+. tCPD. DCO–1,. DCO–2. DCO+1,. DCO+2. tFCO. tFRAME. FCO–1,. FCO–2. FCO+1,
AD9249 Data Sheet Timing Diagrams N – 1 VIN±x1, VIN±x2 tEH tEL CLK– CLK+ tCPD DCO–1, DCO–2 DCO+1, DCO+2 tFCO tFRAME FCO–1, FCO–2 FCO+1,
IC ADC 14BIT PIPELINED 144CSPBGA. 14 Bit Analog to Digital Converter 16 Input 1 Pipelined 144-CSPBGA (10x10). Data Acquisition - Analog...
AD9249BBCZRL7-65
5 757 ₽
AD9249BBCZRL7-65
27 851 ₽
AD9249BBCZRL7-65
AD9249BBCZRL7-65
link to page 33
Refer to the Memory Map Register Descriptions section for SPI register setting of output mode.
N – 1 VIN±x1, VIN±x2 tA N tEH tEL CLK– CLK+ tCPD DCO–1, DCO–2 DCO+1, DCO+2 tFCO tFRAME FCO–1, FCO–2 FCO+1, FCO+2 tPD tDATA D–x1, D–x2 MSB D12 D11 D10 D9 D8 D7 D6 D5 D4 D3 D2 D1 D0 MSB D12 N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 16 N – 16 D+x1,
002
D+x2
1536- 1 Figure 3. Wordwise DDR, 1× Frame, 14-Bit Output Mode (Default)
N – 1 VIN±x1, tA VIN±x2 N tEH tEL CLK– CLK+ tCPD DCO–1, DCO–2 DCO+1, DCO+2 t t FCO FRAME FCO–1, FCO–2 FCO+1, FCO+2 tPD tDATA D–x1, D–x2 MSB D10 D9 D8 D7 D6 D5 D4 D3 D2 D1 D0 MSB D10 N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 16 N – 16
003
D+x1, D+x2
1536- 1 Figure 4. Wordwise DDR, 1× Frame, 12-Bit Output Mode Rev. 0 | Page 8 of 36 Document Outline Features Applications General Description Simplified Functional Block Diagram Product Highlights Revision History Functional Block Diagram Specifications DC Specifications AC Specifications Digital Specifications Switching Specifications Timing Diagrams Timing Specifications SYNC Timing Diagram Absolute Maximum Ratings Thermal Characteristics ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Equivalent Circuits Theory of Operation Analog Input Considerations Input Common Mode Differential Input Configurations Voltage Reference Internal Reference Connection External Reference Operation Clock Input Considerations Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations Power Dissipation and Power-Down Mode Digital Outputs and Timing SDIO/DFS Pin SCLK/DTP Pin CSB1 and CSB2 Pins RBIAS1 and RBIAS2 Pins Built-In Output Test Modes Output Test Modes Serial Port Interface (SPI) Configuration Using the SPI Hardware Interface Configuration Without the SPI SPI Accessible Features Memory Map Reading the Memory Map Register Table Open Locations Default Values Logic Levels Channel Specific Registers Memory Map Memory Map Register Descriptions Device Index (Register 0x04 and Register 0x05) Transfer (Register 0xFF) Power Modes (Register 0x08) Bits[7:6]—Open Bit 5—External Power-Down Pin Function Bits[4:2]—Open Bits[1:0]—Internal Power-Down Mode Enhancement Control (Register 0x0C) Bits[7:3]—Open Bit 2—Chop Mode Bits[1:0]—Open Output Mode (Register 0x14) Bit 7—Open Bit 6—LVDS-ANSI/LVDS-IEEE Option Bits[5:3]—Open Bit 2—Output Invert Bit 1—Open Bit 0—Output Format Output Adjust (Register 0x15) Bits[7:6]—Open Bits[5:4]—Output Driver Termination Bits[3:1]—Open Bit 0—FCO±x, DCO±x Output Drive Output Phase (Register 0x16) Bit 7—Open Bits[6:4]—Input Clock Phase Adjust Bits[3:0]—Output Clock Phase Adjust Resolution/Sample Rate Override (Register 0x100) User I/O Control 2 (Register 0x101) Bits[7:1]—Open Bit 0—SDIO Pull-Down User I/O Control 3 (Register 0x102) Bits[7:4]—Open Bit 3—VCM Power-Down Bits[2:0]—Open Applications Information Design Guidelines Power and Ground Recommendations Board Layout Considerations Sources of Coupling Crosstalk Between Inputs Coupling of Digital Output Switching Noise to Analog Inputs and Clock Clock Stability Considerations VCM Reference Decoupling SPI Port Outline Dimensions Ordering Guide
