Datasheet ADAS3022 (Analog Devices) - 5
Описание16-Bit, 1 MSPS, 8 Channel Data Acquisition System
Страниц / Страница41 / 5 — ADAS3022. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. …
ВерсияD
Формат / Размер файлаPDF / 797 Кб
ADAS3022. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
ADAS3022 Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit
26 предложений от 11 поставщиков
, 8-Channel Single ADC SAR 1Msps 16-bit Serial 48-Pin LQFP Tray
ADAS3022BSTZ
от 765 ₽
Зенер
Россия и страны ТС
ADAS3022BSTZ
от 2 005 ₽
ADAS3022BSTZ
2 740 ₽
Эиком
ADAS3022BSTZ
от 4 978 ₽
link to page 7 link to page 7
1 Offset Error Temperature Drift External reference PGIA gain = 0.16, 0.2, 0.4, 0.8 0.1 0.5 ppm/°C PGIA gain = 1.6 0.2 1.0 ppm/°C PGIA gain = 3.2 0.4 2.0 ppm/°C PGIA gain = 6.4 0.8 4.0 ppm/°C Total Unadjusted Error External reference, TA = 25°C PGIA gain = 0.16, 0.2, 0.4, 0.8, 1.6, 3.2 −9 +9 LSB PGIA gain = 6.4 −15 +15 LSB AC ACCURACY3 Signal-to-Noise Ratio (SNR) fIN = 10 kHz PGIA gain = 0.16 90.0 91.5 dB PGIA gain = 0.2 90.0 91.5 dB PGIA gain = 0.4 89.5 91.5 dB PGIA gain = 0.8 89.0 91.0 dB PGIA gain = 1.6 88.0 89.7 dB PGIA gain = 3.2 86.0 86.8 dB PGIA gain = 6.4 83.0 84.5 dB Signal-to-Noise-and-Distortion fIN = 10 kHz (SINAD) PGIA gain = 0.16 88.0 90.0 dB PGIA gain = 0.2 88.0 90.0 dB PGIA gain = 0.4 88.5 91.0 dB PGIA gain = 0.8 88.5 90.5 dB PGIA gain = 1.6 87.5 89.5 dB PGIA gain = 3.2 85.5 86.5 dB PGIA gain = 6.4 82.5 84.0 dB Dynamic Range fIN = 10 kHz, −60 dB input PGIA gain = 0.16 91.0 92.0 dB PGIA gain = 0.2 91.0 92.0 dB PGIA gain = 0.4 90.5 91.5 dB PGIA gain = 0.8 90.0 91.0 dB PGIA gain = 1.6 89.0 90.0 dB PGIA gain = 3.2 86.0 87.0 dB PGIA gain = 6.4 83.5 85.0 dB Total Harmonic Distortion fIN = 10 kHz, all PGIA gains −100 dB Spurious-Free Dynamic Range fIN = 10 kHz, all PGIA gains 101 dB Channel-to-Channel Crosstalk fIN = 10 kHz, all channels inactive −120 dB Common-Mode Rejection Ratio fIN = 2 kHz (CMRR) PGIA gain = 0.16, 0.2, 0.4, 0.8 90.0 110.0 dB PGIA gain = 1.6 90.0 105.0 dB PGIA gain = 3.2 90.0 98.0 dB PGIA gain = 6.4 90.0 98.0 dB −3 dB Input Bandwidth −40 dBFS 8 MHz AUXILIARY ADC INPUT CHANNEL DC Accuracy External reference Integral Nonlinearity Error −1.5 ±0.5 +1.5 LSB Differential Nonlinearity Error −0.8 ±0.6 +1.0 LSB Gain Error −2.5 ±0.2 +2.5 LSB Offset Error −5 ±0.2 +5 LSB Rev. C | Page 4 of 40 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Timing Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Overview ADAS3022 Operation Transfer Function Typical Application Connection Diagram Analog Inputs Input Structure Programmable Gain Common-Mode Operating Range Fully Differential, Antiphase Signals with a Zero Common Mode Fully Differential, Antiphase Signals with a Nonzero Common Mode Differential, Nonantiphase Signals with a Zero Common Mode Single-Ended Signals with a Nonzero DC Offset (Asymmetrical) Single-Ended Signals with a 0 V DC Offset (Symmetrical) Multiplexer Channel Sequencer Auxiliary Input Channel Driver Amplifier Choice Voltage Reference Output/Input Internal Reference External Reference and Internal Buffer External Reference Reference Decoupling Power Supply Core Supplies High Voltage Supplies Power Dissipation Modes Fully Operational Mode Power-Down Mode Conversion Modes Warp Mode (CMS = 0) Normal Mode (CMS = 1, Default) Digital Interface Conversion Control CNV Rising Edge—Start of a Conversion (SOC) BUSY Falling Edge—End of a Conversion (EOC) Reset and Power-Down (PD) Inputs Serial Data Interface CPHA Sampling on the SCK Falling Edge Sampling on the SCK Rising Edge (Alternate Edge) CFG Readback General Considerations Data Access During Conversion—Maximum Throughput General Timing Configuration Register On Demand Conversion Mode Channel Sequencer Details INx and COM Inputs (MUX = 1, TEMPB = 1) INx and COM Inputs with AUX Inputs (MUX = 0, TEMPB = 1) INx and COM Inputs with Temperature Sensor (MUX = 1, TEMPB = 0) INx and COM Inputs with AUX Inputs and Temperature Sensor (MUX = 0, TEMPB = 0) Sequencer Modes Basic Sequencer Mode (SEQ = 11) Update During Sequence (SEQ = 01) Advanced Sequencer Mode (SEQ = 10) Outline Dimensions Ordering Guide
