Datasheet AD9250 (Analog Devices) - 8
Описание14-Bit, 170 MSPS/250 MSPS, JESD204B, Dual Analog-to-Digital Converter
Страниц / Страница45 / 8 — AD9250. Data Sheet. Parameter. Temperature. Min. Typ. Max. Unit
ВерсияE
AD9250 Data Sheet Parameter Temperature Min Typ Max Unit
14 предложений от 14 поставщиков
IC ADC 14BIT PIPELINED 48LFCSP. 14 Bit Analog to Digital Converter 2 Input 2 Pipelined 48-LFCSP-WQ (7x7). Data Acquisition - Analog...
AD9250BCPZRL7-250
6 509 ₽
ЧипСити
AD9250BCPZRL7-250
21 698 ₽
727GS
AD9250BCPZRL7-250
AD9250BCPZRL7-250
SYSREF INPUT (SYSREF±) Logic Compliance LVDS Internal Common-Mode Bias Full 0.9 V Differential Input Voltage Range Full 0.3 3.6 V p-p Input Voltage Range Full AGND AVDD V Input Common-Mode Range Full 0.9 1.4 V High Level Input Current Full −5 +5 µA Low Level Input Current Full −5 +5 µA Input Capacitance Full 4 pF Input Resistance Full 8 10 12 kΩ LOGIC INPUT (RST, CS)1 High Level Input Voltage Full 1.22 2.1 V Low Level Input Voltage Full 0 0.6 V High Level Input Current Full −5 +5 µA Low Level Input Current Full −100 −45 µA Input Resistance Full 26 kΩ Input Capacitance Full 2 pF LOGIC INPUT (SCLK/PDWN)2 High Level Input Voltage Full 1.22 2.1 V Low Level Input Voltage Full 0 0.6 V High Level Input Current Full 45 100 µA Low Level Input Current Full −10 +10 µA Input Resistance Full 26 kΩ Input Capacitance Full 2 pF LOGIC INPUTS (SDIO)2 High Level Input Voltage Full 1.22 2.1 V Low Level Input Voltage Full 0 0.6 V High Level Input Current Full 45 100 µA Low Level Input Current Full −10 10 µA Input Resistance Full 26 kΩ Input Capacitance Full 5 pF DIGITAL OUTPUTS (SERDOUT0±/SERDOUT1±) Logic Compliance Full CML Differential Output Voltage (VOD) Full 400 600 750 mV p-p Output Offset Voltage (VOS) Full 0.75 DRVDD/2 1.05 V DIGITAL OUTPUTS (SDIO/FDA/FDB) High Level Output Voltage (VOH) Full IOH = 50 µA Full 1.79 V IOH = 0.5 mA Full 1.75 V Low Level Output Voltage (VOL) Full IOL = 1.6 mA Full 0.2 V IOL = 50 µA Full 0.05 V 1 Pull-up. 2 Pull-down. Rev. E | Page 8 of 45 Document Outline Features Applications Functional Block Diagram Product Highlights Revision History General Description Specifications ADC DC Specifications ADC AC Specifications Digital Specifications Switching Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings Thermal Characteristics ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Equivalent Circuits Theory of Operation ADC Architecture Analog Input Considerations Input Common Mode Differential Input Configurations Voltage Reference Clock Input Considerations Nyquist Clock Input Options RF Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations Power Dissipation and Standby Mode Digital Outputs JESD204B Transmit Top Level Description JESD204B Overview JESD204B Synchronization Details CGS Phase ILAS Phase Data Transmission Phase Link Setup Parameters Disable Lanes Before Changing Configuration Select Quick Configuration Option Configure Detailed Options Check FCHK, Checksum of JESD204B Interface Parameters Additional Digital Output Configuration Options Re-Enable Lanes After Configuration Internal FIFO Timing Optimization Frame and Lane Alignment Monitoring and Correction Digital Outputs and Timing ADC Overrange and Gain Control ADC Overrange (OR) Gain Switching Fast Threshold Detection (FDA and FDB) DC Correction DC Correction Bandwidth DC Correction Readback DC Correction Freeze DC Correction (DCC) Enable Bits Serial Port Interface (SPI) Configuration Using the SPI Hardware Interface SPI Accessible Features Memory Map Reading the Memory Map Register Table Open and Reserved Locations Default Values Logic Levels Channel-Specific Registers Memory Map Register Table Memory Map Register Description Applications Information Design Guidelines Power and Ground Recommendations Exposed Paddle Thermal Heat Slug Recommendations VCM SPI Port SPI Initialization Sequence Outline Dimensions Ordering Guide
