Datasheet AD9635 (Analog Devices) - 10
| Производитель | Analog Devices |
| Описание | Dual, 12-Bit, 80 MSPS/125 MSPS Serial LVDS 1.8 V Analog-to-Digital Converter |
| Страниц / Страница | 37 / 10 — Data Sheet. AD9635. N – 1. VINx±. tEH. tEL. CLK–. CLK+. tCPD. DCO–. DCO+. … |
| Версия | B |
| Формат / Размер файла | PDF / 1.0 Мб |
Data Sheet. AD9635. N – 1. VINx±. tEH. tEL. CLK–. CLK+. tCPD. DCO–. DCO+. tFCO. tFRAME. FCO–. FCO+. tDATA. D0x–. MSB. D10. N – 17. N – 17 N – 17. N – 16. D0x+. N – 9
12 предложений от 12 поставщиков IC ADC 12BIT PIPELINED 32LFCSP. 12 Bit Analog to Digital Converter 2 Input 2 Pipelined 32-LFCSP-WQ (5x5). Data Acquisition - Analog... |
| AD9635BCPZRL7-80 Analog Devices | 998 ₽ | |
| AD9635BCPZRL7-80 Analog Devices | 2 038 ₽ | |
| AD9635BCPZRL7-80 Analog Devices | по запросу | |
Data Sheet AD9635 N – 1 VINx± tA N tEH tEL CLK– CLK+ tCPD DCO– DCO+ tFCO tFRAME FCO– FCO+ t tDATA PD D0x– MSB D10 D9 D8 D7 D6 D5 D4 D3 D2 D1 D0 MSB D10
006
N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 17 N – 16 N – 16 D0x+
10577- Figure 6. Wordwise DDR, One-Lane, 1× Frame, 12-Bit Output Mode
N – 1 VINx± tA N tEH tEL CLK– CLK+ tCPD DCO– DCO+ tFCO tFRAME FCO– FCO+ t tDATA PD D0x– MSB D8 D7 D6 D5 D4 D3 D2 D1 D0 MSB D8 D7 D6 D5
007
N – 9 N – 9 N – 9 N – 9 N – 9 N – 9 N – 9 N – 9 N – 9 N – 9 N – 8 N – 8 N – 8 N – 8 N – 8 D0x+
10577- Figure 7. Wordwise DDR, One-Lane, 1× Frame, 10-Bit Output Mode Rev. B | Page 9 of 36 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS AD9635-80 AD9635-125 EQUIVALENT CIRCUITS THEORY OF OPERATION ANALOG INPUT CONSIDERATIONS Input Common Mode Differential Input Configurations VOLTAGE REFERENCE CLOCK INPUT CONSIDERATIONS Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations POWER DISSIPATION AND POWER-DOWN MODE DIGITAL OUTPUTS AND TIMING SDIO/PDWN Pin SCLK/DFS Pin CSB Pin RBIAS Pin OUTPUT TEST MODES SERIAL PORT INTERFACE (SPI) CONFIGURATION USING THE SPI HARDWARE INTERFACE CONFIGURATION WITHOUT THE SPI SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE Open Locations Default Values Logic Levels Channel-Specific Registers MEMORY MAP REGISTER TABLE MEMORY MAP REGISTER DESCRIPTIONS Device Index (Register 0x05) Transfer (Register 0xFF) Power Modes (Register 0x08) Bits[7:2]—Open Bits[1:0]—Power Mode Enhancement Control (Register 0x0C) Bits[7:3]—Open Bit 2—Chop Mode Bits[1:0]—Open Output Mode (Register 0x14) Bit 7—Open Bit 6—LVDS-ANSI/LVDS-IEEE Option Bits[5:3]—Open Bit 2—Output Invert Bit 1—Open Bit 0—Output Format Output Adjust (Register 0x15) Bits[7:6]—Open Bits[5:4]—Output Driver Termination Bits[3:1]—Open Bit 0—Output Drive Output Phase (Register 0x16) Bit 7—Open Bits[6:4]—Input Clock Phase Adjust Bits[3:0]—Output Clock Phase Adjust Serial Output Data Control (Register 0x21) Resolution/Sample Rate Override (Register 0x100) User I/O Control 2 (Register 0x101) Bits[7:1]—Open Bit 0—SDIO Pull-Down User I/O Control 3 (Register 0x102) Bits[7:4]—Open Bit 3—VCM Power-Down Bits[2:0]—Open APPLICATIONS INFORMATION DESIGN GUIDELINES POWER AND GROUND GUIDELINES CLOCK STABILITY CONSIDERATIONS EXPOSED PAD THERMAL HEAT SLUG RECOMMENDATIONS VCM REFERENCE DECOUPLING SPI PORT OUTLINE DIMENSIONS ORDERING GUIDE
