Линейка продуктов KEEN SIDE
Datasheet AD9434 (Analog Devices) - 2
Описание12-Bit, 370 MSPS/500 MSPS, 1.8 V Analog-to-Digital Converter
Страниц / Страница29 / 2 — AD9434* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
ВерсияB
Формат / Размер файлаPDF / 937 Кб
AD9434* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. EVALUATION KITS
AD9434* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS EVALUATION KITS
15 предложений от 15 поставщиков
Микросхема Преобразователь AD, Analog to Digital Converters - ADC 12Bit 500MSPS 1.8V
ЧипСити
AD9434BCPZRL7-500
13 307 ₽
AD9434BCPZRL7-500
15 043 ₽
AD9434BCPZRL7-500
20 978 ₽
AD9434BCPZRL7-500
Ruimeng предлагает удачную замену популярной микросхеме Axx1248 – 24-битный Σ-Δ АЦП MS5148T
View a parametric search of comparable parts. • Visual Analog • AD9434/AD9484 IBIS Model
EVALUATION KITS
• AD9434 Evaluation Board
REFERENCE DESIGNS
• CN0238
DOCUMENTATION Application Notes REFERENCE MATERIALS
• AN-1142: Techniques for High Speed ADC PCB Layout
Technical Articles
• AN-586: LVDS Outputs for High Speed A/D Converters • MS-1779: Nine Often Overlooked ADC Specifications • AN-742: Frequency Domain Response of Switched- • MS-2210: Designing Power Supplies for High Speed ADC Capacitor ADCs
Tutorials
• AN-756: Sampled Systems and the Effects of Clock Phase • MT-002: What the Nyquist Criterion Means to Your Noise and Jitter Sampled Data System Design • AN-807: Multicarrier WCDMA Feasibility • MT-031: Grounding Data Converters and Solving the • AN-808: Multicarrier CDMA2000 Feasibility Mystery of "AGND" and "DGND" • AN-827: A Resonant Approach to Interfacing Amplifiers to • MT-075: Differential Drivers for High Speed ADCs Switched-Capacitor ADCs Overview • AN-835: Understanding High Speed ADC Testing and Evaluation
DESIGN RESOURCES
• AN-878: High Speed ADC SPI Control Software • AD9434 Material Declaration • AN-905: Visual Analog Converter Evaluation Tool Version • PCN-PDN Information 1.0 User Manual • Quality And Reliability • AN-935: Designing an ADC Transformer-Coupled Front • Symbols and Footprints End
Data Sheet DISCUSSIONS
• AD9434: 12-Bit, 370 MSPS/500 MSPS, 1.8 V Analog-to- Digital Converter Data Sheet View all AD9434 EngineerZone Discussions.
Technical Books SAMPLE AND BUY
• The Data Conversion Handbook, 2005 Visit the product page to see pricing options.
User Guides
• UG-290: Evaluating the AD9434 and AD9484 Analog-to-
TECHNICAL SUPPORT
Digital Converters Submit a technical question or find your regional support
SOFTWARE AND SYSTEMS REQUIREMENTS
number. • AD9434 Native FMC Card & ML605 Xilinx Reference
DOCUMENT FEEDBACK
Design Submit feedback for this data sheet.
Document Outline Features Applications General Description Functional Block Diagram Product Highlights Revision History Specifications DC Specifications AC Specifications Digital Specifications Switching Specifications Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Equivalent Circuits Theory of Operation Analog Input and Voltage Reference Differential Input Configurations Clock Input Considerations Clock Duty Cycle Considerations Clock Jitter Considerations Power Dissipation and Power-Down Mode Digital Outputs Digital Outputs and Timing Output Data Rate and Pinout Configuration Out-of-Range (OR) Timing VREF AD9434 Configuration Using the SPI Using the AD9434 to Replace the AD9230 Hardware Interface Configuration Without the SPI Memory Map Reading the Memory Map Table Reserved Locations Default Values Logic Levels Outline Dimensions Ordering Guide
