Datasheet AD9262 (Analog Devices) - 2
Описание16-Bit, 2.5 MHz/5 MHz/10 MHz, 30 MSPS to 160 MSPS Dual Continuous Time Sigma-Delta ADC
Страниц / Страница33 / 2 — AD9262* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. …
ВерсияA
AD9262* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. EVALUATION KITS
AD9262* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS EVALUATION KITS
13 предложений от 13 поставщиков
Микросхема Преобразователь AD, 16Bit, 2.5MHz/5MHz/10MHz, 30MSPS to 160MSPS Dual Continuous Time Sigma-Delta ADC
AD9262BCPZRL7-10
2 480 ₽
AD9262BCPZRL7-10
LifeElectronics
AD9262BCPZRL7
AD9262BCPZRL7-5
View a parametric search of comparable parts. • AD9262 IBIS Model
EVALUATION KITS REFERENCE MATERIALS
• AD9262 Evaluation Board
Technical Articles
• MS-2210: Designing Power Supplies for High Speed ADC
DOCUMENTATION
• Understanding Continuous-Time, Discrete-Time Sigma-
Application Notes
Delta ADCs And Nyquist ADCs • AN-1142: Techniques for High Speed ADC PCB Layout • AN-282: Fundamentals of Sampled Data Systems
DESIGN RESOURCES
• AN-283: Sigma-Delta ADCs and DACs • AD9262 Material Declaration • AN-807: Multicarrier WCDMA Feasibility • PCN-PDN Information • AN-808: Multicarrier CDMA2000 Feasibility • Quality And Reliability • AN-812: MicroController-Based Serial Port Interface (SPI) • Symbols and Footprints Boot Circuit • AN-835: Understanding High Speed ADC Testing and
DISCUSSIONS
Evaluation View all AD9262 EngineerZone Discussions. • AN-878: High Speed ADC SPI Control Software • AN-905: Visual Analog Converter Evaluation Tool Version
SAMPLE AND BUY
1.0 User Manual Visit the product page to see pricing options. • Interfacing the ADL5382 Quadrature I/Q Demodulator to the AD9262 16-Bit Continuous Time Sigma-Delta ADC as
TECHNICAL SUPPORT
an RF-to-Bits Solution Submit a technical question or find your regional support
Data Sheet
number. • AD9262: 16-Bit, 2.5 MHz/5 MHz/10 MHz, 30 MSPS to 160 MSPS Dual Continuous Time Sigma-Delta ADC Data Sheet
DOCUMENT FEEDBACK User Guides
Submit feedback for this data sheet. • UG-051: Evaluating the AD9262, 16-Bit, Dual Continuous Time Sigma Delta ADC and Demonstrating Direct Conversion
Document Outline Features Applications General Description Functional Block Diagram Product Highlights Revision History Specifications DC Specifications AC Specifications Digital Decimation Filtering Characteristics Digital Specifications Switching Specifications Timing Diagram Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics AD9262BCPZ AD9262BCPZ-5 AD9262BCPZ-10 Equivalent Circuits Theory of Operation Analog Input Considerations Input Common Mode Differential Input Configurations Voltage Reference Internal Reference Connection External Reference Operation Clock Input Considerations Direct Clocking Internal PLL Clock Distribution PLL Autoband Select Jitter Considerations Power Dissipation and Standby Mode Digital Engine Bandwidth Selection Decimation Filters Sample Rate Converter Cascaded Filter Responses DC and Quadrature Error Correction (QEC) LO Leakage (DC) Correction QEC and DC Correction Range Digital Outputs Digital Output Format Interleaved Outputs Overrange (OR) Condition Timing Serial Port Interface (SPI) Configuration Using the SPI Hardware Interface Applications Information Filtering Requirement Memory Map Memory Map Definitions Outline Dimensions Ordering Guide
