Datasheet AD9255 (Analog Devices) - 3
Описание14-Bit, 125 MSPS/105 MSPS/80 MSPS, 1.8 V Analog-to-Digital Converter
Страниц / Страница45 / 3 — AD9255. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 7/13—Rev. B to …
ВерсияC
Формат / Размер файлаPDF / 1.8 Мб
AD9255. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 7/13—Rev. B to Rev. C. 3/13—Rev. A to Rev. B. 1/10—Rev. 0 to Rev. A
AD9255 Data Sheet TABLE OF CONTENTS REVISION HISTORY 7/13—Rev B to Rev C 3/13—Rev A to Rev B 1/10—Rev 0 to Rev A
Микросхема Преобразователь AD, ADC Single Pipelined 125MSPS 14Bit Parallel/Serial (3-Wire, SPI)/LVDS 48Pin LFCSP EP T/R
727GS
AD9255BCPZRL7-125
от 3 320 ₽
AD9255BCPZRL7-125
4 793 ₽
AD9255BCPZRL7-125
от 7 400 ₽
AD9255BCPZRL7-125
14 932 ₽
link to page 1 link to page 1 link to page 1 link to page 1 link to page 3 link to page 4 link to page 5 link to page 5 link to page 6 link to page 7 link to page 9 link to page 10 link to page 11 link to page 11 link to page 11 link to page 12 link to page 16 link to page 24 link to page 26 link to page 26 link to page 26 link to page 29 link to page 30 link to page 32 link to page 33 link to page 33 link to page 34 link to page 34 link to page 34 link to page 35 link to page 35 link to page 35 link to page 36 link to page 36 link to page 37 link to page 37 link to page 38 link to page 40 link to page 41 link to page 41 link to page 42 link to page 42
Features .. 1 Voltage Reference ... 28 Applications ... 1 Clock Input Considerations .. 29 Product Highlights ... 1 Power Dissipation and Standby Mode .. 31 Functional Block Diagram .. 1 Digital Outputs ... 32 Revision History ... 2 Timing ... 32 General Description ... 3 Built-In Self-Test (BIST) and Output Test .. 33 Specifications ... 4 Built-In Self-Test (BIST) .. 33 ADC DC Specifications ... 4 Output Test Modes ... 33 ADC AC Specifications ... 5 Serial Port Interface (SPI) .. 34 Digital Specifications ... 6 Configuration Using the SPI ... 34 Switching Specifications .. 8 Hardware Interface ... 34 Timing Specifications .. 9 Configuration Without the SPI .. 35 Absolute Maximum Ratings .. 10 SPI Accessible Features .. 35 Thermal Characteristics .. 10 Memory Map .. 36 ESD Caution .. 10 Reading the Memory Map Register Table ... 36 Pin Configurations and Function Descriptions ... 11 Memory Map Register Table ... 37 Typical Performance Characteristics ... 15 Memory Map Register Descriptions .. 39 Equivalent Circuits ... 23 Applications Information .. 40 Theory of Operation .. 25 Design Guidelines .. 40 ADC Architecture .. 25 Outline Dimensions ... 41 Analog Input Considerations .. 25 Ordering Guide .. 41
Changes to Data Clock Output (DCO) Section ... 32
Changes to Table 17 .. 1 Updated Outline Dimensions ... 41
Changes to Worst Other (Harmonic or Spur) Parameter, Table 2 .. 6 Changes to Figure 77 .. 29 Changes to Input Clock Divider Section ... 30 Changes to Table 17 .. 37 Updated Outline Dimensions ... 41
10/09—Revision 0: Initial Version
Rev. C | Page 2 of 44 Document Outline Features Applications Product Highlights Functional Block Diagram Table of Contents Revision History General Description Specifications ADC DC Specifications ADC AC Specifications Digital Specifications Switching Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings Thermal Characteristics ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Equivalent Circuits Theory of Operation ADC Architecture Analog Input Considerations Input Common Mode Dither Differential Input Configurations Voltage Reference Internal Reference Connection External Reference Operation Clock Input Considerations Clock Input Options Clock Duty Cycle Input Clock Divider Jitter Considerations Power Dissipation and Standby Mode Digital Outputs Digital Output Enable Function (OEB) Timing Data Clock Output (DCO) Built-In Self-Test (BIST) and Output Test Built-In Self-Test (BIST) Output Test Modes Serial Port Interface (SPI) Configuration Using the SPI Hardware Interface Configuration Without the SPI SPI Accessible Features Memory Map Reading the Memory Map Register Table Open Locations Default Values Logic Levels Transfer Register Map Memory Map Register Table Memory Map Register Descriptions Sync Control (Register 0x100) Applications Information Design Guidelines Power and Ground Recommendations LVDS Operation Exposed Paddle Thermal Heat Slug Recommendations VCM RBIAS Reference Decoupling SPI Port Outline Dimensions Ordering Guide
