Линейка продуктов KEEN SIDE
Datasheet AD9267 (Analog Devices) - 10
Описание10 MHz Bandwidth, 640 MSPS Dual Continuous Time Sigma-Delta Modulator
Страниц / Страница25 / 10 — AD9267. TYPICAL PERFORMANCE CHARACTERISTICS. –10. –20. –30. –40. –50. …
Формат / Размер файлаPDF / 562 Кб
AD9267. TYPICAL PERFORMANCE CHARACTERISTICS. –10. –20. –30. –40. –50. –60. E (. –70. UDE. –80. –90. –100. –110. –120. –130. –140. FREQUENCY (MHz)
AD9267 TYPICAL PERFORMANCE CHARACTERISTICS –10 –20 –30 –40 –50 –60 E ( –70 UDE –80 –90 –100 –110 –120 –130 –140 FREQUENCY (MHz)
Микросхема Преобразователь AD, ADC Dual Delta-Sigma 640MSPS 16Bit Parallel/Serial (SPI)/LVDS 64Pin LFCSP EP
AD9267BCPZRL7
3 888 ₽
AD9267BCPZRL7
5 837 ₽
Эиком
AD9267BCPZRL7
от 11 892 ₽
AD9267BCPZRL7
link to page 10 link to page 10
All power supplies set to 1.8 V, 640 MHz sample rate, 0.5 V internal reference, PLL disabled, AIN = −2.0 dBFS, TA = 25°C, unless otherwise noted. The output spectrums shown in Figure 4 through Figure 9 were obtained after 16× decimation at the output of the AD9267 and are shown for a 10 MHz bandwidth.
0 0 –10 –10 –20 –20 –30 –30 –40 ) –40 S S) –50 F –50 BF B d d ( –60 –60 E ( –70 D –70 UDE U IT –80 IT L –80 P PL –90 M –90 AM A –100 –100 –110 –110 –120 –120 –130 –130 –140 –140 0 1 2 3 4 5 6 7 8 9 10
4
09 00 0 3- 3-
FREQUENCY (MHz)
77
FREQUENCY (MHz)
77 07 07 Figure 4. Single-Tone FFT with fIN = 2.4 MHz Figure 7. Two-Tone FFT with fIN1 = 2.1 MHz, fIN2= 2.4 MHz
0 0 –10 –10 –20 –20 –30 –30 –40 ) –40 ) S S –50 –50 BF BF d d ( –60 ( –60 –70 –70 UDE UDE IT –80 IT L –80 L P P –90 –90 AM AM –100 –100 –110 –110 –120 –120 –130 –130 –140 –140 0 1 2 3 4 5 6 7 8 9 10
5
0 00 01 3- 3-
FREQUENCY (MHz)
77
FREQUENCY (MHz)
77 07 07 Figure 5. Single-Tone FFT with fIN = 4.2 MHz Figure 8. Two-Tone FFT with fIN1 = 3.6 MHz, fIN2 = 4.2 MHz
6
1 00 01 3- 3-
FREQUENCY (MHz)
77
FREQUENCY (MHz)
77 07 07 Figure 6. Single-Tone FFT with fIN = 8.4 MHz Figure 9. Two-Tone FFT with fIN1 = 7.2 MHz, fIN2 = 8.4 MHz Rev. 0 | Page 9 of 24 Document Outline Features Applications General Description Functional Block Diagram Product Highlights Revision History Specifications DC Specifications AC Specifications Digital Specifications Switching Specifications Timing Diagram Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Equivalent Circuits Theory of Operation Analog Input Considerations Input Common Mode Differential Input Configurations Voltage Reference Internal Reference Connection External Reference Operation Clock Input Considerations Direct Clocking Internal PLL Clock Distribution External PLL Control PLL Autoband Select Power Dissipation and Standby Mode Digital Outputs Digital Output Format Overrange (OR) Condition Timing Serial Port Interface (SPI) Configuration Using the SPI Hardware Interface Applications Information Filtering Requirement Memory Map Memory Map Definitions Outline Dimensions Ordering Guide
