Datasheet AD7780 (Analog Devices) - 7
Описание24-Bit Pin-Programmable Low Power Σ−Δ ADC
Страниц / Страница17 / 7 — AD7780. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 4. Parameter. …
ВерсияA
Формат / Размер файлаPDF / 359 Кб
AD7780. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 4. Parameter. Rating. Table 5. Package Type. θJA. θJC Unit. ESD CAUTION
AD7780 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 4 Parameter Rating Table 5 Package Type θJA θJC Unit ESD CAUTION
36 предложений от 21 поставщиков
Аппаратно конфигурируемый, малопотребляющий 24-разрядный сигма-дельта АЦП
AD7780BRUZ-REEL
184 ₽
ЧипСити
AD7780BRUZ-REEL
184 ₽
AD7780BRUZ
AD7780BRUZ
TA = 25°C, unless otherwise noted.
THERMAL RESISTANCE Table 4.
θJA is specified for the worst-case conditions, that is, a device soldered in a circuit board for surface-mount packages.
Parameter Rating
AVDD to GND −0.3 V to +7 V
Table 5.
DVDD to GND −0.3 V to +7 V
Analog Input Voltage to GND −0.3 V to AVDD + 0.3 V 14-Lead SOIC 104.5 42.9 °C/W Reference Input Voltage to GND −0.3 V to AVDD + 0.3 V 16-Lead TSSOP 150.4 27.6 °C/W Digital Input Voltage to GND −0.3 V to DVDD + 0.3 V Digital Output Voltage to GND −0.3 V to DVDD + 0.3 V AIN/Digital Input Current 10 mA
ESD CAUTION
Operating Temperature Range −40°C to +105°C Storage Temperature Range −65°C to +150°C Maximum Junction Temperature 150°C Lead Temperature, Soldering Reflow 260°C Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Rev. A | Page 6 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING CHARACTERISTICS Circuit and Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OUTPUT NOISE AND RESOLUTION THEORY OF OPERATION FILTER, DATA RATE, AND SETTLING TIME GAIN POWER-DOWN/RESET () ANALOG INPUT CHANNEL BIPOLAR CONFIGURATION DATA OUTPUT CODING REFERENCE BRIDGE POWER-DOWN SWITCH DIGITAL INTERFACE APPLICATIONS INFORMATION WEIGH SCALES PERFORMANCE IN A WEIGH SCALE SYSTEM EMI RECOMMENDATIONS GROUNDING AND LAYOUT OUTLINE DIMENSIONS ORDERING GUIDE
