Datasheet AD9230-11 (Analog Devices) - 6
Описание11-Bit, 200 MSPS, 1.8 V Analog-to-Digital Converter
Страниц / Страница29 / 6 — AD9230-11. DIGITAL SPECIFICATIONS. Table 3. Parameter1. Temp. Min. Typ. …
Формат / Размер файлаPDF / 665 Кб
AD9230-11. DIGITAL SPECIFICATIONS. Table 3. Parameter1. Temp. Min. Typ. Max. Unit
AD9230-11 DIGITAL SPECIFICATIONS Table 3 Parameter1 Temp Min Typ Max Unit
Микросхема Преобразователь AD, ADC Single Pipelined 200MSPS 12Bit Parallel 56Pin LFCSP EP
AD9230BCPZ11-200
3 756 ₽
AD9230BCPZ11-200
9 078 ₽
AD9230BCPZ11-200
10 926 ₽
AD9230BCPZ11-200
от 11 039 ₽
link to page 6 link to page 6
AVDD = 1.8 V, DRVDD = 1.8 V, TMIN = −40°C, TMAX = +85°C, fIN = −1.0 dBFS, full scale = 1.25 V, DCS enabled, unless otherwise noted.
Table 3. Parameter1 Temp Min Typ Max Unit
CLOCK INPUTS Logic Compliance Full CMOS/LVDS/LVPECL Internal Common-Mode Bias Full 1.2 V Differential Input Voltage Full 0.2 6 V p-p Input Voltage Range Full AGND − 0.3 AVDD + 1.6 V Input Common-Mode Range Full 1.1 AVDD V High Level Input Voltage (VIH) Full 1.2 3.6 V Low Level Input Voltage (VIL) Full 0 0.8 V High Level Input Current (IIH) Full −10 +10 μA Low Level Input Current (IIL) Full −10 +10 μA Input Resistance (Differential) Full 16 20 24 kΩ Input Capacitance Full 4 pF LOGIC INPUTS Logic 1 Voltage Full 0.8 × AVDD V Logic 0 Voltage Full 0.2 × AVDD V Logic 1 Input Current (SDIO) Full 0 μA Logic 0 Input Current (SDIO) Full −60 μA Logic 1 Input Current (SCLK, PWDN, CSB, RESET) Full 55 μA Logic 0 Input Current (SCLK, PWDN, CSB, RESET) Full 0 μA Input Capacitance 25°C 4 pF LOGIC OUTPUTS2 VOD Differential Output Voltage Full 247 454 mV VOS Output Offset Voltage Full 1.125 1.375 V Output Coding Twos complement, gray code, or offset binary (default) 1 See the AN-835 Application Note, Understanding High Speed ADC Testing and Evaluation, for a complete set of definitions and an explanation of how these tests were completed. 2 LVDS RTERMINATION = 100 Ω. Rev. 0 | Page 5 of 28 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS THEORY OF OPERATION ANALOG INPUT AND VOLTAGE REFERENCE Differential Input Configurations CLOCK INPUT CONSIDERATIONS Clock Duty Cycle Considerations Clock Jitter Considerations POWER DISSIPATION AND POWER-DOWN MODE DIGITAL OUTPUTS Digital Outputs and Timing Output Data Rate and Pinout Configuration Out-of-Range (OR) TIMING RBIAS CONFIGURATION USING THE SPI HARDWARE INTERFACE CONFIGURATION WITHOUT THE SPI MEMORY MAP READING THE MEMORY MAP TABLE RESERVED LOCATIONS DEFAULT VALUES LOGIC LEVELS TRANSFER REGISTER MAP OUTLINE DIMENSIONS ORDERING GUIDE
