Datasheet AD7264 (Analog Devices) - 7
Описание1 MSPS, 14-Bit, Simultaneous Sampling SAR ADC with PGA and Four Comparators
Страниц / Страница30 / 7 — AD7264. Data Sheet. TIMING SPECIFICATIONS. Table 2. Limit. TMIN, TMAX. …
ВерсияE
AD7264. Data Sheet. TIMING SPECIFICATIONS. Table 2. Limit. TMIN, TMAX. Parameter. 2.7 V ≤ VDRIVE ≤ 3.6 V. 4.75 V ≤ VDRIVE ≤ 5.25 V
AD7264 Data Sheet TIMING SPECIFICATIONS Table 2 Limit TMIN, TMAX Parameter 2.7 V ≤ VDRIVE ≤ 3.6 V 4.75 V ≤ VDRIVE ≤ 5.25 V
33 предложений от 20 поставщиков
Микросхема Преобразователь AD, ANALOG DEVICES AD7264BCPZ Analogue to Digital Converter, 14Bit, 1MSPS, Single, 4.75V, 5.25V, LFCSP
AD7264BCPZ-5-RL7
675 ₽
Рутоника
AD7264BCPZ
760 ₽
AD7264BCPZ-5-RL7
1 310 ₽
AD7264BCPZ-5
2 753 ₽
link to page 15
AVCC = 4.75 V to 5.25 V, CA_CBVCC = CC_CDVCC = 2.7 V to 5.25 V, VREF = 2.5 V internal/external; TA = TMIN to TMAX, unless otherwise noted.1
Table 2. Limit at TMIN, TMAX Parameter 2.7 V ≤ VDRIVE ≤ 3.6 V 4.75 V ≤ VDRIVE ≤ 5.25 V Unit Description
fSCLK 200 200 kHz min 34 342 MHz max AD7264 20 20 MHz max AD7264-5 tCONVERT 19 × tSCLK 19 × tSCLK ns max tSCLK = 1/fSCLK 560 560 ns max AD7264 950 950 ns max AD7264-5 tQUIET 13 13 ns min Minimum time between end of serial read/bus relinquish and next falling edge of CS t2 10 10 ns min CS to SCLK setup time t 3 3 15 15 ns max Delay from 19th SCLK falling edge until DOUTA and DOUTB are three-state disabled t4 29 23 ns max Data access time after SCLK falling edge t5 15 13 ns min SCLK to data valid hold time t6 0.4 × tSCLK 0.4 × tSCLK ns min SCLK high pulse width t7 0.4 × tSCLK 0.4 × tSCLK ns min SCLK low pulse width t8 13 13 ns min CS rising edge to falling edge pulse width t9 13 13 ns max CS rising edge to DOUTA, DOUTB high impedance/bus relinquish t10 5 5 ns min SCLK falling edge to DOUTA, DOUTB high impedance 35 35 ns max SCLK falling edge to DOUTA, DOUTB high impedance t11 2 2 μs min Minimum CAL pin high time t12 2 2 μs min Minimum time between the CAL pin high and the CS falling edge t13 3 3 ns min DIN setup time prior to SCLK falling edge t14 3 3 ns min DIN hold time after SCLK falling edge tPOWER-UP 240 240 μs max Internal reference, with a 1 μF decoupling capacitor 15 15 μs max With an external reference, 10 μs typical 1 Sample tested during initial release to ensure compliance. All input signals are specified with tR = tF = 5 ns (10% to 90% of VDD) and timed from a voltage level of 1.6 V. All timing specifications given are with a 25 pF load capacitance. With a load capacitance greater than this value, a digital buffer or latch must be used. See the Terminology section. 2 The AD7264 is functional with a 40 MHz SCLK at 25°C, but specified performance is not guaranteed with SCLK frequencies greater than 34 MHz. 3 The time required for the output to cross 0.4 V or 2.4 V.
CS t8 t2 t6 SCLK 1 2 3 4 5 18 19 20 21 31 32 33 t7 t t t 9 3 t 5 4 tQUIET D DB13 DB12 DB11 DB1 OUTA THREE-STATE A A A A DB0A THREE- STATE D DB13 DB12 DB11 DB1 OUTB THREE-STATE B B B B DB0B THREE-
-002
STATE
6732 0 Figure 2. Serial Interface Timing Diagram Rev. D | Page 6 of 29 Document Outline FEATURES GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CIRCUIT INFORMATION COMPARATORS OPERATION ANALOG INPUTS Transfer Function VDRIVE REFERENCE TYPICAL CONNECTION DIAGRAMS Comparator Application Details APPLICATION DETAILS MODES OF OPERATION PIN DRIVEN MODE GAIN SELECTION POWER-DOWN MODES Power-Up Conditions CONTROL REGISTER ON-CHIP REGISTERS Writing to a Register Reading from a Register SERIAL INTERFACE CALIBRATION INTERNAL OFFSET CALIBRATION ADJUSTING THE OFFSET CALIBRATION REGISTER SYSTEM GAIN CALIBRATION APPLICATIONS INFORMATION GROUNDING AND LAYOUT PCB DESIGN GUIDELINES FOR LFCSP OUTLINE DIMENSIONS ORDERING GUIDE
