Datasheet AD7366-5, AD7367-5 (Analog Devices) - 3
ОписаниеTrue Bipolar Input, 14-Bit, 2-Channel, Simultaneous Sampling SAR ADC
Страниц / Страница28 / 3 — AD7366-5/AD7367-5. SPECIFICATIONS AD7366-5 SPECIFICATIONS. Table 2. …
ВерсияB
Формат / Размер файлаPDF / 460 Кб
AD7366-5/AD7367-5. SPECIFICATIONS AD7366-5 SPECIFICATIONS. Table 2. Parameter Min. Typ. Max. Unit. Test. Conditions/Comments
AD7366-5/AD7367-5 SPECIFICATIONS AD7366-5 SPECIFICATIONS Table 2 Parameter Min Typ Max Unit Test Conditions/Comments
35 предложений от 18 поставщиков
Микросхема Преобразователь AD, ADC Dual SAR 500KSPS 12Bit Serial 24Pin TSSOP T/R
AD7366BRUZ-5-RL7
531 ₽
AD7366BRUZ-5-RL7
532 ₽
AD7366BRUZ-5
от 1 445 ₽
Эиком
AD7366BRUZ-5
от 1 478 ₽
link to page 28 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 28 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
AVCC = DVCC = 4.75 V to 5.25 V; VDD = 5 V to 16.5 V; VSS = −16.5 V to −5 V; VDRIVE = 2.7 V to 5.25 V; fSAMPLE = 500 kSPS; fSCLK = 20 MHz; VREF = 2.5 V internal/external; TA = −40°C to +85°C, unless otherwise noted.
Table 2. Parameter Min Typ Max Unit Test Conditions/Comments
DYNAMIC PERFORMANCE fIN = 50 kHz sine wave Signal-to-Noise Ratio (SNR)1 70 72 dB Signal-to-Noise (+ Distortion) Ratio (SINAD)1 70 71 dB Total Harmonic Distortion (THD)1 −85 −78 dB Spurious-Free Dynamic Range (SFDR)1 −87 −78 dB Intermodulation Distortion (IMD)1 fa = 49 kHz, fb = 51 kHz Second-Order Terms −88 dB Third-Order Terms −88 dB Channel-to-Channel Isolation1 −90 dB SAMPLE AND HOLD Aperture Delay2 10 ns Aperture Jitter2 40 ps Aperture Delay Matching2 ±100 ps Full Power Bandwidth 35 MHz @ 3 dB, ±10 V range 8 MHz @ 0.1 dB, ±10 V range DC ACCURACY Resolution 12 Bits Integral Nonlinearity (INL)1 ±0.5 ±1 LSB Differential Nonlinearity (DNL)1 ±0.25 ±0.5 LSB Guaranteed no missed codes to 12 bits Positive Full-Scale Error1 ±1 ±7 LSB ±5 V and ±10 V analog input range ±1 ±6 LSB 0 V to 10 V analog input range Positive Full-Scale Error Match1 ±1.5 LSB Matching from ADC A to ADC B ±0.1 LSB Channel-to-channel matching for ADC A and ADC B Zero Code Error1 ±0.5 ±3 LSB ±5 V and ±10 V analog input range ±1 ±6 LSB 0 V to 10 V analog input range Zero Code Error Match1 ±1.5 LSB Matching from ADC A to ADC B ±0.1 LSB Channel-to-channel matching for ADC A and ADC B Negative Full-Scale Error1 ±1 ±7 LSB ±5 V and ±10 V analog input range ±1 ±6 LSB 0 V to 10 V analog input range Negative Full-Scale Error Match1 ±1.5 LSB Matching from ADC A to ADC B ±0.1 LSB Channel-to-channel matching for ADC A and ADC B ANALOG INPUT Input Voltage Ranges ±10 V (Programmed via RANGE Pins) ±5 V 0 to 10 V DC Leakage Current ±0.01 ±1 μA Input Capacitance 9 pF When in track, ±10 V range 13 pF When in track, ±5 V or 0 V to +10 V range Input Impedance 500 kΩ For ±10 V @ 500 kSPS 2.5 MΩ For ±10 V @ 100 kSPS 250 kΩ For ±5 V/0 V to +10 V @ 500 kSPS 1.2 MΩ For ±5 V/0 V to +10 V @ 100 kSPS Rev. B | Page 3 of 28 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS AD7366-5 SPECIFICATIONS AD7367-5 SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER OPERATION ANALOG INPUTS TRANSFER FUNCTION Track-and-Hold TYPICAL CONNECTION DIAGRAM DRIVER AMPLIFIER CHOICE VDRIVE REFERENCE MODES OF OPERATION NORMAL MODE SHUTDOWN MODE POWER-UP TIMES SERIAL INTERFACE MICROPROCESSOR INTERFACING AD7366-5/AD7367-5 TO ADSP-218x AD7366-5/AD7367-5 TO ADSP-BF53x AD7366-5/AD7367-5 TO TMS320VC5506 AD7366-5/AD7367-5 TO DSP563xx APPLICATION HINTS LAYOUT AND GROUNDING EVALUATING THE AD7366-5/AD7367-5 OUTLINE DIMENSIONS ORDERING GUIDE
