Линейка продуктов KEEN SIDE
Datasheet AD9230 (Analog Devices) - 2
Описание12-Bit, 170 MSPS/210 MSPS/250 MSPS, 1.8 V Analog-to-Digital Converter
Страниц / Страница33 / 2 — AD9230* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. …
Формат / Размер файлаPDF / 2.0 Мб
AD9230* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. EVALUATION KITS
AD9230* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS EVALUATION KITS
23 предложений от 16 поставщиков
Микросхема Преобразователь AD, ANALOG DEVICES AD9230BCPZ-170 Analog to Digital Converter, 12Bit, 170MSPS, Single, 1.7V, 1.9V, LFCSP
AD9230BCPZ-170
2 782 ₽
AD9230BCPZ-170
от 10 732 ₽
Элитан
AD9230BCPZ-170
15 549 ₽
AD9230BCPZ-170
View a parametric search of comparable parts. • Visual Analog • AD9230 (11-Bit) IBIS Model
EVALUATION KITS
• AD9230 IBIS Models • AD9230 Evaluation Board
REFERENCE MATERIALS DOCUMENTATION Technical Articles Application Notes
• Improve The Design Of Your Passive Wideband ADC • AN-1142: Techniques for High Speed ADC PCB Layout Front-End Network • AN-282: Fundamentals of Sampled Data Systems • MS-2210: Designing Power Supplies for High Speed ADC • AN-345: Grounding for Low-and-High-Frequency Circuits • AN-501: Aperture Uncertainty and ADC System
DESIGN RESOURCES
Performance • AD9230 Material Declaration • AN-586: LVDS Outputs for High Speed A/D Converters • PCN-PDN Information • AN-715: A First Approach to IBIS Models: What They Are • Quality And Reliability and How They Are Generated • Symbols and Footprints • AN-737: How ADIsimADC Models an ADC • AN-741: Little Known Characteristics of Phase Noise
DISCUSSIONS
• AN-742: Frequency Domain Response of Switched- View all AD9230 EngineerZone Discussions. Capacitor ADCs • AN-756: Sampled Systems and the Effects of Clock Phase
SAMPLE AND BUY
Noise and Jitter Visit the product page to see pricing options. • AN-807: Multicarrier WCDMA Feasibility • AN-808: Multicarrier CDMA2000 Feasibility
TECHNICAL SUPPORT
• AN-812: MicroController-Based Serial Port Interface (SPI) Submit a technical question or find your regional support Boot Circuit number. • AN-827: A Resonant Approach to Interfacing Amplifiers to Switched-Capacitor ADCs
DOCUMENT FEEDBACK
• AN-835: Understanding High Speed ADC Testing and Evaluation Submit feedback for this data sheet. • AN-878: High Speed ADC SPI Control Software • AN-905: Visual Analog Converter Evaluation Tool Version 1.0 User Manual • AN-935: Designing an ADC Transformer-Coupled Front End
Data Sheet
• AD9230: 12-Bit, 170 MSPS/210 MSPS/250 MSPS, 1.8 V Analog-to-Digital Converter Data Sheet
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS EQUIVALENT CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ANALOG INPUT AND VOLTAGE REFERENCE Differential Input Configurations CLOCK INPUT CONSIDERATIONS Clock Duty Cycle Considerations Clock Jitter Considerations POWER DISSIPATION AND POWER-DOWN MODE DIGITAL OUTPUTS Digital Outputs and Timing Output Data Rate and Pinout Configuration Out-of-Range (OR) TIMING RBIAS AD9230 CONFIGURATION USING THE SPI HARDWARE INTERFACE CONFIGURATION WITHOUT THE SPI MEMORY MAP READING THE MEMORY MAP TABLE RESERVED LOCATIONS DEFAULT VALUES LOGIC LEVELS OUTLINE DIMENSIONS ORDERING GUIDE
