Datasheet AD9230 (Analog Devices) - 7
Описание12-Bit, 170 MSPS/210 MSPS/250 MSPS, 1.8 V Analog-to-Digital Converter
Страниц / Страница33 / 7 — AD9230. SWITCHING SPECIFICATIONS. Table 4. AD9230-170. AD9230-210. …
Формат / Размер файлаPDF / 2.0 Мб
AD9230. SWITCHING SPECIFICATIONS. Table 4. AD9230-170. AD9230-210. AD9230-250. Parameter (Conditions). Temp Min. Typ. Max. Min. Unit
AD9230 SWITCHING SPECIFICATIONS Table 4 AD9230-170 AD9230-210 AD9230-250 Parameter (Conditions) Temp Min Typ Max Min Unit
22 предложений от 14 поставщиков
Микросхема Преобразователь AD, ANALOG DEVICES AD9230BCPZ-210 ANALOG TO DIGITAL CONVERTER ADC, 12Bit, 210MSPS, SPI, LFCSP-56
ЧипСити
AD9230BCPZ-210
3 200 ₽
AD9230BCPZ-210
3 327 ₽
Эиком
AD9230BCPZ-210
от 14 594 ₽
ЗУМ-СМД
AD9230BCPZ-210
link to page 7 link to page 7 link to page 8 link to page 8
AVDD = 1.8 V, DRVDD = 1.8 V, TMIN = −40°C, TMAX = +85°C, fIN = −1.0 dBFS, full scale = 1.25 V, DCS enabled, unless otherwise noted.
Table 4. AD9230-170 AD9230-210 AD9230-250 Parameter (Conditions) Temp Min Typ Max Min Typ Max Unit
Maximum Conversion Rate Full 170 210 250 MSPS Minimum Conversion Rate Full 40 40 40 MSPS CLK+ Pulse Width High (tCH) Full 2.65 2.9 2.15 2.4 1.8 2.0 ns CLK+ Pulse Width Low (tCL) Full 2.65 2.9 2.15 2.4 1.8 2.0 ns Output (LVDS − SDR Mode)1 Data Propagation Delay (tPD) Full 3.0 3.0 3.0 ns Rise Time (tR) (20% to 80%) 25°C 0.2 0.2 0.2 ns Fall Time (tF) (20% to 80%) 25°C 0.2 0.2 0.2 ns DCO Propagation Delay (tCPD) Full 3.9 3.9 3.9 ns Data to DCO Skew (tSKEW) Full −0.3 0.1 0.5 −0.3 0.1 0.5 −0.3 0.1 0.5 ns Latency Full 7 7 7 Cycles Output (LVDS − DDR Mode)2 Data Propagation Delay (tPD) Full 3.8 3.8 3.8 ns Rise Time (tR) (20% to 80%) 25°C 0.2 0.2 0.2 ns Fall Time (tF) (20% to 80%) 25°C 0.2 0.2 0.2 ns DCO Propagation Delay (tCPD) Full 3.9 3.9 3.9 ns Data to DCO Skew (tSKEW) Full −0.5 0.1 0.3 −0.5 0.1 0.3 −0.5 0.1 0.3 ns Latency Full 7 7 7 Cycles Aperture Uncertainty (Jitter, tJ) 25°C 0.2 0.2 ps rms 1 See Figure 2. 2 See Figure 3. Rev. 0 | Page 6 of 32 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS EQUIVALENT CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ANALOG INPUT AND VOLTAGE REFERENCE Differential Input Configurations CLOCK INPUT CONSIDERATIONS Clock Duty Cycle Considerations Clock Jitter Considerations POWER DISSIPATION AND POWER-DOWN MODE DIGITAL OUTPUTS Digital Outputs and Timing Output Data Rate and Pinout Configuration Out-of-Range (OR) TIMING RBIAS AD9230 CONFIGURATION USING THE SPI HARDWARE INTERFACE CONFIGURATION WITHOUT THE SPI MEMORY MAP READING THE MEMORY MAP TABLE RESERVED LOCATIONS DEFAULT VALUES LOGIC LEVELS OUTLINE DIMENSIONS ORDERING GUIDE
