Линейка продуктов KEEN SIDE
Datasheet AD7952 (Analog Devices) - 2
Описание14-Bit, 1 MSPS, Differential, Programmable Input PulSAR® ADC
Страниц / Страница33 / 2 — AD7952* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
ВерсияA
Формат / Размер файлаPDF / 615 Кб
AD7952* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. DOCUMENTATION
AD7952* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES DOCUMENTATION
31 предложений от 17 поставщиков
Микросхема Преобразователь AD, ANALOG DEVICES AD7952BSTZ Analogue to Digital Converter, 14Bit, 1MSPS, Single, 4.75V, 5.25V, LQFP
727GS
AD7952BSTZ
от 359 ₽
AD7952BSTZ
от 539 ₽
AD7952BSTZ
2 334 ₽
SUV System
AD7952BSTZ
View a parametric search of comparable parts. • AD7952 Material Declaration • PCN-PDN Information
DOCUMENTATION
• Quality And Reliability
Application Notes
• Symbols and Footprints • AN-931: Understanding PulSAR ADC Support Circuitry
Data Sheet DISCUSSIONS
• AD7952: 14-Bit, 1 MSPS, Differential, Programmable Input View all AD7952 EngineerZone Discussions. PulSAR ADC Data Sheet
User Guides SAMPLE AND BUY
• EVAL-AD76XXCBZ: Evaluation Board For AD761x,762x/ Visit the product page to see pricing options. AD763x AD764x/AD765x/AD766x/AD767x/AD795x
TECHNICAL SUPPORT REFERENCE MATERIALS
Submit a technical question or find your regional support
Technical Articles
number. • MS-2210: Designing Power Supplies for High Speed ADC
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION OVERVIEW CONVERTER OPERATION MODES OF OPERATION Warp Mode Normal Mode Impulse Mode TRANSFER FUNCTIONS TYPICAL CONNECTION DIAGRAM ANALOG INPUTS Input Range Selection Input Structure Single-to-Differential Driver VOLTAGE REFERENCE INPUT/OUTPUT Internal Reference (REF = 5 V, PDREF = Low, PDBUF = Low) External 2.5 V Reference and Internal Buffer (REF = 5 V, PDREF = High, PDBUF = Low) External 5 V Reference (PDREF = High, PDBUF = High) Reference Decoupling Temperature Sensor POWER SUPPLIES Core Supplies High Voltage Supplies Digital Output Supply Power Sequencing Power Dissipation vs. Throughput Power Down CONVERSION CONTROL INTERFACES DIGITAL INTERFACE RESET PARALLEL INTERFACE Master Parallel Interface Slave Parallel Interface 8-Bit Interface (Master or Slave) SERIAL INTERFACE Data Interface Serial Configuration Interface MASTER SERIAL INTERFACE Internal Clock (SER/ = High, EXT/ = Low) Read During Convert (RDC = High) Read After Convert (RDC = Low, DIVSCLK[1:0] = [0 to 3]) SLAVE SERIAL INTERFACE External Clock (SER/ = High, EXT/ = High) External Discontinuous Clock Data Read After Conversion Daisy-Chain Feature External Clock Data Read During Previous Conversion External Clock Data Read After/During Conversion HARDWARE CONFIGURATION SOFTWARE CONFIGURATION MICROPROCESSOR INTERFACING SPI Interface APPLICATION INFORMATION LAYOUT GUIDELINES OUTLINE DIMENSIONS ORDERING GUIDE
