Datasheet AD9259 (Analog Devices) - 2
ОписаниеQuad, 14-Bit, 50 MSPS Serial LVDS 1.8 V ADC
Страниц / Страница53 / 2 — AD9259* PRODUCT PAGE QUICK LINKS Last Content Update: 06/09/2017. …
ВерсияE
AD9259* PRODUCT PAGE QUICK LINKS Last Content Update: 06/09/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. EVALUATION KITS
AD9259* PRODUCT PAGE QUICK LINKS Last Content Update: 06/09/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS EVALUATION KITS
20 предложений от 15 поставщиков
Микросхема Преобразователь AD, ADC Quad Pipelined 50MSPS 14Bit Serial (2-Wire)/LVDS 48Pin LFCSP EP T/R
AD9259ABCPZRL7-50
1 195 ₽
AD9259ABCPZRL7-50
от 4 939 ₽
Зенер
Россия и страны ТС
AD9259ABCPZRL7-50
от 14 676 ₽
Эиком
AD9259ABCPZRL7-50
от 15 403 ₽
View a parametric search of comparable parts. • Visual Analog • AD9259 IBIS Models
EVALUATION KITS
• AD9259 Evaluation Board
REFERENCE MATERIALS Technical Articles DOCUMENTATION
• Matching An ADC To A Transformer
Application Notes
• MS-2210: Designing Power Supplies for High Speed ADC • AN-1142: Techniques for High Speed ADC PCB Layout • AN-282: Fundamentals of Sampled Data Systems
DESIGN RESOURCES
• AN-345: Grounding for Low-and-High-Frequency Circuits • AD9259 Material Declaration • AN-501: Aperture Uncertainty and ADC System • PCN-PDN Information Performance • Quality And Reliability • AN-715: A First Approach to IBIS Models: What They Are • Symbols and Footprints and How They Are Generated • AN-737: How ADIsimADC Models an ADC
DISCUSSIONS
• AN-741: Little Known Characteristics of Phase Noise View all AD9259 EngineerZone Discussions. • AN-742: Frequency Domain Response of Switched- Capacitor ADCs
SAMPLE AND BUY
• AN-756: Sampled Systems and the Effects of Clock Phase Noise and Jitter Visit the product page to see pricing options. • AN-807: Multicarrier WCDMA Feasibility
TECHNICAL SUPPORT
• AN-808: Multicarrier CDMA2000 Feasibility Submit a technical question or find your regional support • AN-812: MicroController-Based Serial Port Interface (SPI) number. Boot Circuit • AN-827: A Resonant Approach to Interfacing Amplifiers to
DOCUMENT FEEDBACK
Switched-Capacitor ADCs • AN-835: Understanding High Speed ADC Testing and Submit feedback for this data sheet. Evaluation • AN-905: Visual Analog Converter Evaluation Tool Version 1.0 User Manual • AN-935: Designing an ADC Transformer-Coupled Front End
Data Sheet
• AD9259: Quad, 14-Bit, 50 MSPS Serial LVDS 1.8 V ADC Data Sheet
Document Outline Features Applications General Description Functional Block Diagram Product Highlights Revision History Specifications AC Specifications Digital Specifications Switching Specifications Timing Diagrams Absolute Maximum Ratings Thermal Impedance ESD Caution Pin Configuration and Function Descriptions Equivalent Circuits Typical Performance Characteristics Theory of Operation Analog Input Considerations Differential Input Configurations Single-Ended Input Configuration Clock Input Considerations Clock Duty Cycle Considerations Clock Jitter Considerations Power Dissipation and Power-Down Mode Digital Outputs and Timing SDIO/ODM Pin SCLK/DTP Pin CSB Pin RBIAS Pin Voltage Reference Internal Reference Operation External Reference Operation Serial Port Interface (SPI) Hardware Interface Memory Map Reading the Memory Map Table Reserved Locations Default Values Logic Levels Power and Ground Recommendations Exposed Paddle Thermal Heat Slug Recommendations Evaluation Board Power Supplies Input Signals Output Signals Default Operation and Jumper Selection Settings Alternative Analog Input Drive Configuration Outline Dimensions Ordering Guide
