Datasheet AD7794, AD7795 (Analog Devices) - 7
Описание6-Channel, Low Noise, Low Power, 16-Bit Sigma Delta ADC with On-Chip In-Amp and Reference
Страниц / Страница36 / 7 — AD7794/AD7795. Parameter. Unit. Test Conditions/Comments
ВерсияD
Формат / Размер файлаPDF / 542 Кб
AD7794/AD7795 Parameter Unit Test Conditions/Comments
15 предложений от 15 поставщиков
IC ADC 24BIT SIGMA-DELTA 24TSSOP. 24 Bit Analog to Digital Converter 6 Input 1 Sigma-Delta 24-TSSOP. Data Acquisition - Analog to...
AD7794BRU
81 ₽
Hi-Tech Circuit Group
AD7794BRU-REEL
AD7794BRU
AD7794BRU-REEL
link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7
1
AD7794/AD7795 Unit Test Conditions/Comments
LOGIC OUTPUT (INCLUDING CLK) VOH, Output High Voltage2 DVDD − 0.6 V min DVDD = 3 V, ISOURCE = 100 μA VOL, Output Low Voltage2 0.4 V max DVDD = 3 V, ISINK = 100 μA VOH, Output High Voltage2 4 V min DVDD = 5 V, ISOURCE = 200 μA VOL, Output Low Voltage2 0.4 V max DVDD = 5 V, ISINK = 1.6 mA (DOUT/RDY), 800 μA (CLK) Floating-State Leakage Current ±10 μA max Floating-State Output Capacitance 10 pF typ Data Output Coding Offset binary SYSTEM CALIBRATION2 Full-Scale Calibration Limit 1.05 × FS V max Zero-Scale Calibration Limit −1.05 × FS V min Input Span 0.8 × FS V min 2.1 × FS V max POWER REQUIREMENTS7 Power Supply Voltage AVDD to GND 2.7/5.25 V min/max DVDD to GND 2.7/5.25 V min/max Power Supply Currents IDD Current 140 μA max 110 μA typ @ AVDD = 3 V, 125 μA typ @ AVDD = 5 V, unbuffered mode, external reference 185 μA max 130 μA typ @ AVDD = 3 V, 165 μA typ @ AVDD = 5 V, buffered mode, gain = 1 or 2, external reference 400 μA max 300 μA typ @ AVDD = 3 V, 350 μA typ @ AVDD = 5 V, gain = 4 to 128, external reference 500 μA max 400 μA typ @ AVDD = 3 V, 450 μA typ @ AVDD = 5 V, gain = 4 to 128, internal reference IDD (Power-Down Mode) 1 μA max AD7794B, AD7795B 2 μA max AD7794C 1 Temperature range: B Grade: −40°C to +105°C, C Grade: −40°C to +125°C. At the 19.6 Hz and 39.2 Hz update rates, the INL, power supply rejection (PSR), common- mode rejection (CMR), and normal mode rejection (NMR) do not meet the data sheet specification if the voltage on the AIN(+) or AIN(−) pins exceeds AVDD – 1.6 V typically. In addition, the offset error and offset error drift degrade at these update rates when chopping is disabled. When this voltage is exceeded, the INL, for example, is reduced to 18 ppm of FS typically while the PSR is reduced to 69 dB typically. Therefore, for guaranteed performance at these update rates, the absolute voltage on the analog input pins needs to be below AVDD − 1.6 V. 2 Specification is not production tested but is supported by characterization data at initial product release. 3 Following a calibration, this error is in the order of the noise for the programmed gain and update rate selected. 4 Recalibration at any temperature removes these errors. 5 Full-scale error applies to both positive and negative full-scale, and applies at the factory calibration conditions (AVDD = 4 V, gain = 1, TA = 25°C). 6 FS[3:0] are the four bits used in the mode register to select the output word rate. 7 Digital inputs equal to DVDD or GND with excitation currents and bias voltage generator disabled. Rev. D | Page 7 of 36 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING CHARACTERISTICS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS RMS NOISE AND RESOLUTION SPECIFICATIONS CHOP ENABLED External Reference Internal Reference CHOP DISABLED TYPICAL PERFORMANCE CHARACTERISTICS ON-CHIP REGISTERS COMMUNICATIONS REGISTER RS2, RS1, RS0 = 0, 0, 0 STATUS REGISTER RS2, RS1, RS0 = 0, 0, 0; Power-On/Reset = 0x80 (AD7795)/0x88 (AD7794) MODE REGISTER RS2, RS1, RS0 = 0, 0, 1; Power-On/Reset = 0x000A CONFIGURATION REGISTER RS2, RS1, RS0 = 0, 1, 0; Power-On/Reset = 0x0710 DATA REGISTER RS2, RS1, RS0 = 0, 1, 1; Power-On/Reset = 0x0000(AD7795), 0x000000 (AD7794) ID REGISTER RS2, RS1, RS0 = 1, 0, 0; Power-On/Reset = 0xXF IO REGISTER RS2, RS1, RS0 = 1, 0, 1; Power-On/Reset = 0x00 OFFSET REGISTER RS2, RS1, RS0 = 1, 1, 0; Power-On/Reset = 0x8000 (AD7795), 0x800000 (AD7794)) FULL-SCALE REGISTER RS2, RS1, RS0 = 1, 1, 1; Power-On/Reset = 0x5XXX (AD7795), 0x5XXX00 (AD7794) ADC CIRCUIT INFORMATION OVERVIEW DIGITAL INTERFACE Single Conversion Mode Continuous Conversion Mode Continuous Read CIRCUIT DESCRIPTION ANALOG INPUT CHANNEL INSTRUMENTATION AMPLIFIER BIPOLAR/UNIPOLAR CONFIGURATION DATA OUTPUT CODING BURNOUT CURRENTS EXCITATION CURRENTS BIAS VOLTAGE GENERATOR REFERENCE REFERENCE DETECT RESET AVDD MONITOR CALIBRATION GROUNDING AND LAYOUT APPLICATIONS INFORMATION FLOWMETER OUTLINE DIMENSIONS ORDERING GUIDE
