Datasheet AD7656, AD7657, AD7658 (Analog Devices) - 7
Описание250 kSPS, 6-Channel,SimultaneousSampling, Bipolar 12-Bit A/D Converter
Страниц / Страница32 / 7 — Data Sheet. AD7656/AD7657/AD7658. AD7658. Table 3. Parameter. B Version. …
ВерсияD
Формат / Размер файлаPDF / 595 Кб
Data Sheet. AD7656/AD7657/AD7658. AD7658. Table 3. Parameter. B Version. Y Version. Unit. Test Conditions/Comments
Data Sheet AD7656/AD7657/AD7658 AD7658 Table 3 Parameter B Version Y Version Unit Test Conditions/Comments
15 предложений от 15 поставщиков
IC ADC 12BIT SAR 64LQFP. 12 Bit Analog to Digital Converter 6 Input 6 SAR 64-LQFP (10x10). Data Acquisition - Analog...
Рутоника
AD7658BSTZ-REEL
931 ₽
AD7658BSTZ-REEL
1 038 ₽
AD7658BSTZ-REEL
1 040 ₽
Hi-Tech Circuit Group
AD7658BSTZ-REEL
link to page 20 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8
VREF = 2.5 V internal/external, AVCC = 4.75 V to 5.25 V, DVCC = 4.75 V to 5.25 V, VDRIVE = 2.7 V to 5.25 V; For ±4 × VREF range: VDD = 10 V to 16.5 V, VSS = −10 V to −16.5 V; For ±2 × VREF range: VDD = 5 V to 16.5 V, VSS = −5 V to −16.5 V; fSAMPLE = 250 kSPS, TA = TMIN to TMAX, unless otherwise noted.1
Table 3. Parameter B Version
1
Y Version
1
DYNAMIC PERFORMANCE fIN = 50 kHz sine wave Signal-to-Noise + Distortion (SINAD)2 73 73 dB min 73.5 73.5 dB typ Total Harmonic Distortion (THD)2 −88 −88 dB max −92 −92 dB typ Peak Harmonic or Spurious Noise (SFDR)2 −97 −97 dB typ Intermodulation Distortion (IMD)2 fa = 50 kHz, fb = 49 kHz Second-Order Terms −106 −106 dB typ Third-Order Terms −101 −101 dB typ Aperture Delay 10 10 ns max Aperture Delay Matching 4 4 ns max Aperture Jitter 35 35 ps typ Channel-to-Channel Isolation2 −100 −100 dB typ fIN on unselected channels up to 100 kHz Full Power Bandwidth 12 12 MHz typ @ −3 dB 2 2 MHz typ @ −0.1 dB DC ACCURACY Resolution 12 12 Bits No Missing Codes 12 12 Bits min Differential Nonlinearity ±0.7 ±0.7 LSB max Integral Nonlinearity2 ±1 ±1 LSB max Positive Full-Scale Error2 ±0.75 ±0.75 % FSR max ±0.244% FSR typical Positive Full-Scale Error Matching2 ±0.366 ±0.366 % FSR max Bipolar Zero-Scale Error2 ±3 ±3 LSB max ±0.0488% FSR typical Bipolar Zero-Scale Error Matching2 ±3 ±3 LSB max Negative Full-Scale Error2 ±0.75 ±0.75 % FSR max ±0.244% FSR typical Negative Full-Scale Error Matching2 ±0.366 ±0.366 % FSR max ANALOG INPUT See Table 8 for min VDD/VSS for each range Input Voltage Ranges ±4 × VREF ±4 × VREF V RNG bit/RANGE pin = 0 ±2 × VREF ±2 × VREF V RNG bit/RANGE pin = 1 DC Leakage Current ±1 ±1 µA max Input Capacitance3 10 10 pF typ ±4 × VREF range when in track 14 14 pF typ ±2 × VREF range when in track REFERENCE INPUT/OUTPUT Reference Input Voltage Range 2.5/3 2.5/3 V min/max DC Leakage Current ±1 ±1 µA max Input Capacitance3 18.5 18.5 pF typ REFEN/DIS = 1 Reference Output Voltage 2.49/2.51 2.49/2.51 V min/max Long-Term Stability 150 150 ppm typ 1,000 hours Reference Temperature Coefficient 25 25 ppm/°C max 6 6 ppm/°C typ LOGIC INPUTS Input High Voltage (VINH) 0.7 × VDRIVE 0.7 × VDRIVE V min Input Low Voltage (VINL) 0.3 × VDRIVE 0.3 × VDRIVE V max Input Current (IIN) ±1 ±1 µA max Typically 10 nA, VIN = 0 V or VDRIVE Input Capacitance (CIN)3 10 10 pF max Rev. D | Page 7 of 32 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Table of Contents Revision History Specifications AD7656 AD7657 AD7658 Timing Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Converter Details Track-and-Hold Section Analog Input Section ADC Transfer Function Reference Section Typical Connection Diagram Driving the Analog Inputs Interface Section Parallel Interface (SER/ = 0) Software Selection of ADCs Changing the Analog Input Range (/S SEL = 0) Changing the Analog Input Range (/S SEL = 1) Serial Interface (SER/ = 1) Serial Read Operation Daisy-Chain Mode (DCEN = 1, SER/ = 1) Standby/Partial Power-Down Modes of Operation Application Hints Layout Power Supply Configuration Outline Dimensions Ordering Guide
