Datasheet AD7328 (Analog Devices) - 3
ОписаниеSoftware Selectable, True Bipolar Input, 8-Channel, 12-Bit Plus Sign A/D Converter
Страниц / Страница37 / 3 — AD7328. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 1/14—Rev. B to …
ВерсияC
Формат / Размер файлаPDF / 773 Кб
AD7328. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 1/14—Rev. B to Rev. C. 6/06—Rev. 0 to Rev. A. 2/10—Rev. A to Rev. B
AD7328 Data Sheet TABLE OF CONTENTS REVISION HISTORY 1/14—Rev B to Rev C 6/06—Rev 0 to Rev A 2/10—Rev A to Rev B
48 предложений от 27 поставщиков
Микросхема Преобразователь AD, ANALOG DEVICES AD7328BRUZ Analog to Digital Converter, 13Bit, 1MSPS, 2.5V, 16.5V, TSSOP
AD7328BRUZ-REEL7
от 1 215 ₽
Hi-Tech Circuit Group
AD7328BRUZ
727GS
AD7328BRUZ-REEL
МосЧип
AD7328BRUZ-REEL7
link to page 1 link to page 1 link to page 1 link to page 1 link to page 3 link to page 4 link to page 7 link to page 8 link to page 8 link to page 9 link to page 10 link to page 14 link to page 16 link to page 16 link to page 16 link to page 17 link to page 19 link to page 19 link to page 21 link to page 22 link to page 22 link to page 23 link to page 25 link to page 25 link to page 26 link to page 28 link to page 28 link to page 28 link to page 29 link to page 29 link to page 29 link to page 30 link to page 30 link to page 31 link to page 32 link to page 33 link to page 33 link to page 33 link to page 34 link to page 34 link to page 34 link to page 35 link to page 35
Features .. 1 Sequence Register ... 24 General Description ... 1 Range Registers ... 24 Functional Block Diagram .. 1 Sequencer Operation ... 25 Product Highlights ... 1 Reference ... 27 Revision History ... 2 VDRIVE .. 27 Specifications ... 3 Temperature Indicator ... 27 Timing Specifications .. 6 Modes of Operation ... 28 Absolute Maximum Ratings .. 7 Normal Mode (PM1 = PM0 = 0) ... 28 ESD Caution .. 7 Full Shutdown Mode (PM1 = PM0 = 1) ... 28 Pin Configuration and Function Descriptions ... 8 Autoshutdown Mode (PM1 = 1, PM0 = 0) ... 29 Typical Performance Characteristics ... 9 Autostandby Mode (PM1 = 0, PM0 = 1) .. 29 Terminology .. 13 Power vs. Throughput Rate ... 30 Theory of Operation .. 15 Serial Interface .. 31 Circuit Information .. 15 Microprocessor Interfacing ... 32 Converter Operation .. 15 AD7328 to ADSP-21xx .. 32 Analog Input Structure .. 16 AD7328 to ADSP-BF53x ... 32 Typical Connection Diagram ... 18 Applications Information .. 33 Analog Input ... 18 Layout and Grounding .. 33 Driver Amplifier Choice .. 20 Power Supply Configuration .. 33 Registers ... 21 Outline Dimensions ... 34 Addressing Registers .. 21 Ordering Guide .. 34 Control Register .. 22
Changes to Circuit Information Section and Table 6 .. 15
Changes to Addressing Registers Section .. 21 Changes to Table 1 ... 1 Changes to Power Supply Configuration Section .. 33 Changes to Specifications ... 3 Changes to Ordering Guide .. 34 Added Thermal Hysteresis to Terminology Section.. 14 Change to Figure 42 ... 20
Change to Control Register Section ... 23 Change to Product Highlights Section .. 1 Changes to DC Accuracy Parameter, Test Conditions/
10/05—Revision 0: Initial Version
Comments, Table 2 ... 3 Changes to Normal Mode (Operational) ICC and IDRIVE Parameter and to Power Dissipation Normal Mode Parameter, Table 2 .. 5 Changes to Table 14 and Table 15 .. 32 Added Power Supply Configuration Section and Figure 56 ... 33 Changes to Ordering Guide .. 34 Rev. C | Page 2 of 36 Document Outline Features General Description Functional Block Diagram Product Highlights Table of Contents Revision History Specifications Timing Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Circuit Information Converter Operation Output Coding Transfer Functions Analog Input Structure Track-and-Hold Section Typical Connection Diagram Analog Input Single-Ended Inputs True Differential Mode Pseudo Differential Inputs Driver Amplifier Choice Registers Addressing Registers Control Register Sequence Register Range Registers Sequencer Operation Reference VDRIVE Temperature Indicator Modes of Operation Normal Mode (PM1 = PM0 = 0) Full Shutdown Mode (PM1 = PM0 = 1) Autoshutdown Mode (PM1 = 1, PM0 = 0) Autostandby Mode (PM1 = 0, PM0 = 1) Power vs. Throughput Rate Serial Interface Microprocessor Interfacing AD7328 to ADSP-21xx AD7328 to ADSP-BF53x Applications Information Layout and Grounding Power Supply Configuration Outline Dimensions Ordering Guide
