Линейка продуктов KEEN SIDE
Datasheet AD7993, AD7994 (Analog Devices) - 9
Описание4 Channel, 12-Bit ADC with I2C Compatible Interface in 16-Lead TSSOP
Страниц / Страница32 / 9 — AD7993/AD7994. ABSOLUTE MAXIMUM RATINGS. Table 4. Parameter Rating. ESD …
AD7993/AD7994. ABSOLUTE MAXIMUM RATINGS. Table 4. Parameter Rating. ESD CAUTION
AD7993/AD7994 ABSOLUTE MAXIMUM RATINGS Table 4 Parameter Rating ESD CAUTION
29 предложений от 14 поставщиков
Микросхема Преобразователь AD, ADC Single SAR 188KSPS 10Bit Serial 16Pin TSSOP T/R
AD7993BRUZ-0REEL
196 ₽
727GS
AD7993BRUZ-0REEL
от 197 ₽
Эиком
AD7993BRUZ-0REEL
от 834 ₽
AD7993BRUZ-0REEL
от 1 235 ₽
link to page 9
TA = 25°C, unless otherwise noted.
Table 4.
Stresses above those listed under Absolute Maximum Ratings
Parameter Rating
may cause permanent damage to the device. This is a stress VDD to GND −0.3 V to 7 V rating only; functional operation of the device at these or any Analog Input Voltage to GND −0.3 V to VDD + 0.3 V other conditions above those listed in the operational sections Reference Input Voltage to GND −0.3 V to VDD + 0.3 V of this specification is not implied. Exposure to absolute Digital Input Voltage to GND −0.3 V to +7 V maximum rating conditions for extended periods may affect Digital Output Voltage to GND −0.3 V to VDD + 0.3 V device reliability. Input Current to Any Pin Except Supplies1 ±10 mA Operating Temperature Range Commercial (B Version) −40°C to +125°C Storage Temperature Range −65°C to +150° Junction Temperature 150°C 20-Lead TSSOP θJA Thermal Impedance 150.4°C/W θJC Thermal Impedance 27.6°C/W Pb/SN Temperature, Soldering Reflow (10 s to 30 s) 240(+0/-5)°C Pb-Free Temperature, Soldering Reflow 260(+0)°C ESD 1.5 kV 1 Transient currents of up to 100 mA do not cause SCR latch-up.
ESD CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection. Although this product features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high energy electrostatic discharges. Therefore, proper ESD precautions are recommended to avoid performance degradation or loss of functionality. Rev. 0 | Page 9 of 32 Document Outline FEATURES GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS AD7993 SPECIFICATIONS AD7994 SPECIFICATIONS I2C TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND PIN FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT INFORMATION CONVERTER OPERATION TYPICAL CONNECTION DIAGRAM ANALOG INPUT INTERNAL REGISTER STRUCTURE ADDRESS POINTER REGISTER CONFIGURATION REGISTER CONVERSION RESULT REGISTER LIMIT REGISTERS ALERT STATUS REGISTER CYCLE TIMER REGISTER SAMPLE DELAY AND BIT TRIAL DELAY SERIAL INTERFACE SERIAL BUS ADDRESS WRITING TO THE AD7993/AD7994 WRITING TO THE ADDRESS POINTER REGISTER FOR A SUBSEQUENT REA WRITING A SINGLE BYTE OF DATA TO THE ALERT STATUS REGISTER O WRITING TWO BYTES OF DATA TO A LIMIT OR HYSTERESIS REGISTER READING DATA FROM THE AD7993/AD7994 ALERT/BUSY PIN SMBus ALERT BUSY PLACING THE AD7993-1/AD7994-1 INTO HIGH SPEED MODE THE ADDRESS SELECT (AS) PIN MODES OF OPERATION MODE 1—USING THE CONVST PIN MODE 2—COMMAND MODE MODE 3—AUTOMATIC CYCLE INTERVAL MODE OUTLINE DIMENSIONS ORDERING GUIDE RELATED PARTS IN I2C-COMPATIBLE ADC PRODUCT FAMILY
