Datasheet AD7484 (Analog Devices) - 9
Описание14-Bit, 3 MSPS SAR ADC
Страниц / Страница21 / 9 — AD7484. Pin No. Mnemonic Description
ВерсияC
Формат / Размер файлаPDF / 602 Кб
AD7484 Pin No Mnemonic Description
28 предложений от 18 поставщиков
IC ADC 14BIT SAR 48LQFP. 14 Bit Analog to Digital Converter 1 Input 1 SAR 48-LQFP (7x7). Data Acquisition - Analog...
Рутоника
AD7484BSTZ
1 847 ₽
Элитан
AD7484BSTZ
4 465 ₽
Эиком
AD7484BSTZ
от 6 170 ₽
SUV System
AD7484BSTZ
link to page 16 link to page 16 link to page 15
AD7484 Pin No. Mnemonic Description
40 D14 Data Output Bit for Overranging. If the overrange feature is not used, this pin should be pulled to DGND via a 100 kΩ resistor. 41 CONVST Convert Start Logic Input. A conversion is initiated on the falling edge of the CONVST signal. The input track- and-hold amplifier goes from track mode to hold mode, and the conversion process commences. 42 RESET Reset Logic Input. An active low reset pulse must be applied to this pin after power-up to ensure correct operation. A falling edge on this pin resets the internal state machine and terminates a conversion that may be in progress. The contents of the offset register will also be cleared on this edge. Holding this pin low keeps the part in a reset state. 43 MODE2 Operating Mode Logic Input. See Table 8 for details. 44 MODE1 Operating Mode Logic Input. See Table 8 for details. 45 CLIP Logic Input. A logic high on this pin enables output clipping. In this mode, any input voltage that is greater than positive full scale or less than negative full scale will be clipped to all 1s or all 0s, respectively. Further details are given in the Offset/Overrange section. Rev. C | Page 8 of 20 Document Outline Features Functional Block Diagram General Description Revision History Specifications Timing Characteristics Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Circuit Description Converter Operation Analog Input ADC Transfer Function Power Saving Offset/Overrange Parallel Interface Reading Data from the AD7484 Writing to the AD7484 Driving the CONVST Pin Typical Connection Board Layout and Grounding Outline Dimensions Ordering Guide
