Datasheet AD7482 (Analog Devices) - 4
Описание12-Bit, 3 MSPS SAR ADC
Страниц / Страница21 / 4 — AD7482. SPECIFICATIONS. Table 1. Parameter. Min. Typ. Max. Unit. Test …
ВерсияB
Формат / Размер файлаPDF / 574 Кб
AD7482. SPECIFICATIONS. Table 1. Parameter. Min. Typ. Max. Unit. Test Conditions/Comments
AD7482 SPECIFICATIONS Table 1 Parameter Min Typ Max Unit Test Conditions/Comments
33 предложений от 19 поставщиков
Микросхема Преобразователь AD, ANALOG DEVICES AD7482BSTZ Analog to Digital Converter, 12Bit, 3MSPS, Single, 4.75V, 5.25V, LQFP
AD7482BSTZ
825 ₽
AD7482BSTZ
от 3 263 ₽
727GS
AD7482BSTZ
AD7482BSTZ
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 6 link to page 6 link to page 6 link to page 6 link to page 5 link to page 5 link to page 6 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5
AVDD/DVDD = 5 V ± 5%, AGND = DGND = 0 V, VREF = external, fSAMPLE = 3 MSPS; al specifications TMIN to TMAX and valid for VDRIVE = 2.7 V to 5.25 V, unless otherwise noted. The operating temperature range is −40°C to +85°C.
Table 1. Parameter Min Typ Max Unit Test Conditions/Comments
DYNAMIC PERFORMANCE1, 2 Signal-to-Noise + Distortion (SINAD)3 71 dB fIN = 1 MHz 72 dB fIN = 1 MHz 71 dB fIN = 1 MHz, internal reference Total Harmonic Distortion (THD)3 −86 dB −90 dB −88 dB Internal reference Peak Harmonic or Spurious Noise (SFDR)3 −87 dB Intermodulation Distortion (IMD)3 Second Order Terms −96 dB fIN1 = 95.053 kHz, fIN2 = 105.329 kHz Third Order Terms −94 dB Aperture Delay 10 ns Full Power Bandwidth 40 MHz @ 3 dB 3.5 MHz @ 0.1 dB DC ACCURACY Resolution 12 Bits Integral Nonlinearity3 ±0.5 LSB B Grade ±0.25 ±1 LSB A Grade Differential Nonlinearity3 ±0.25 ±0.5 LSB Guaranteed no missed codes to 12 bits Offset Error3 ±1.5 LSB 0.036 %FSR Gain Error3 ±1.5 LSB 0.036 %FSR ANALOG INPUT Input Voltage −200 mV +2.7 V DC Leakage Current ±1 μA VIN from 0 V to 2.7 V ±2 μA VIN = −200 mV Input Capacitance4 35 pF REFERENCE INPUT/OUTPUT Input Voltage, VREFIN +2.5 V ±1% for specified performance Input DC Leakage Current, VREFIN ±1 μA Input Capacitance, V 4 REFIN 25 pF Input Current, VREFIN 220 μA External reference Output Voltage, VREFOUT +2.5 V Error @ 25°C, VREFOUT ±50 mV Error TMIN to TMAX, VREFOUT ±100 mV Output Impedance, VREFOUT 1 Ω Rev. B | Page 3 of 20 Document Outline Features Functional Block Diagram General Description Revision History Specifications Timing Characteristics Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Circuit Description Converter Operation Analog Input ADC Transfer Function Power Saving Offset/Overrange Parallel Interface Reading Data from the AD7482 Writing to the AD7482 Driving the CONVST Pin Typical Connection Board Layout and Grounding Outline Dimensions Ordering Guide
