Datasheet AD10465 (Analog Devices) - 5
ОписаниеDual Channel, 14-Bit, 65 MSPS A/D Converter With Analog Input Signal Conditioning
Страниц / Страница25 / 5 — AD10465. Data Sheet. Test1. Mil. AD10465BZ/QML-H. Parameter. Temp. Level. …
ВерсияB
Формат / Размер файлаPDF / 2.0 Мб
AD10465. Data Sheet. Test1. Mil. AD10465BZ/QML-H. Parameter. Temp. Level. Subgroup. Min. Typ. Max. Unit
AD10465 Data Sheet Test1 Mil AD10465BZ/QML-H Parameter Temp Level Subgroup Min Typ Max Unit
Микросхема Преобразователь AD, ADC Dual Pipelined 65MSPS 14Bit Parallel 68Pin CLCC
AD10465BZ
64 ₽
AD10465BZ
52 371 ₽
AD10465BZ
111 276 ₽
AD10465BZ
134 515 ₽
link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6
SINAD8 Analog Input @ 4.98 MHz 25°C V 70 dB Analog Input @ 9.9 MHz 25°C I 4 67.5 69 dB Full II 5, 6 67.5 69 dB Analog Input @ 19.5 MHz 25°C I 4 65 68 dB Full II 5, 6 65 68 dB Analog Input @ 32.1 MHz 25°C I 4 60 63 dB Full II 5, 6 58 61 dB SPURIOUS-FREE DYNAMIC RANGE9 Analog Input @ 4.98 MHz 25°C V 85 dBFS Analog Input @ 9.9 MHz 25°C I 4 73 82 dBFS Full II 5, 6 70 82 dBFS Analog Input @ 19.5 MHz 25°C I 4 72 78 dBFS Full II 5, 6 70 78 dBFS Analog Input @ 32.1 MHz 25°C I 4 62 68 dBFS Full II 5, 6 60 66 dBFS TWO-TONE IMD REJECTION10 fIN = 10 MHz and 11 MHz 25°C I 4 78 87 dBFS f1 and f2 are −7 dB II 5, 6 78 dBFS fIN = 31 MHz and 32 MHz 25°C I 4 68 70 dBFS f1 and f2 Are −7 dB Full II 5, 6 60 dBFS CHANNEL-TO-CHANNEL ISOLATION11 25°C IV 12 90 dB TRANSIENT RESPONSE 25°C V 15.3 ns OVERVOLTAGE RECOVERY TIME VIN = 2.0 × fS Full IV 12 40 100 ns VIN = 4.0 × fS Full IV 12 150 200 ns DIGITAL OUTPUTS12 Logic Compatibility CMOS DVCC = 3.3 V Logic 1 Voltage Full I 1, 2, 3 2.5 DVCC − 0.2 V Logic 0 Voltage Full I 1, 2, 3 0.2 0.5 V DVCC = 5 V Logic 1 Voltage Full V DVCC − 0.3 V Logic 0 Voltage Full V 0.35 V Output Coding Twos complement POWER SUPPLY AVCC Supply Voltage13 Full VI 4.85 5.0 5.25 V I (AVCC) Current Full I 270 308 mA AVEE Supply Voltage13 Full VI −5.25 −5.0 −4.75 V I (AVEE) Current Full V 38 49 mA DVCC Supply Voltage13 Full VI 3.135 3.3 3.465 V I (DVCC) Current Full V 30 46 mA ICC (Total) Supply Current per Channel Full I 1, 2, 3 338 403 mA Power Dissipation (Total) Full I 1, 2, 3 3.5 3.9 W Power Supply Rejection Ratio (PSRR) Full V 0.02 % FSR/% VS Passband Ripple to 10 MHz V 0.1 dB Passband Ripple to 25 MHz V 0.2 dB Rev. B | Page 4 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TEST CIRCUITS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND PIN FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION USING THE FLEXIBLE INPUT APPLYING THE AD10465 ENCODING THE AD10465 JITTER CONSIDERATIONS POWER SUPPLIES OUTPUT LOADING LAYOUT INFORMATION EVALUATION BOARD BILL OF MATERIALS LIST FOR AD10465 EVALUATION BOARD SILKSCREENS OUTLINE DIMENSIONS ORDERING GUIDE
