Datasheet AD9410 (Analog Devices) - 8
Описание10-Bit, 210 MSPS ADC
Страниц / Страница21 / 8 — AD9410. ABSOLUTE MAXIMUM RATINGS. Table 5. Parameter Rating. EXPLAINATION …
ВерсияA
Формат / Размер файлаPDF / 389 Кб
AD9410. ABSOLUTE MAXIMUM RATINGS. Table 5. Parameter Rating. EXPLAINATION OF TEST LEVELS. Test Level. ESD CAUTION
AD9410 ABSOLUTE MAXIMUM RATINGS Table 5 Parameter Rating EXPLAINATION OF TEST LEVELS Test Level ESD CAUTION
22 предложений от 18 поставщиков
Микросхема Преобразователь AD, ANALOG DEVICES AD9410BSVZ Analogue to Digital Converter, 10Bit, 210MSPS, Single, 2.5V, 3.6V, HTQFP
AD9410BSVZ
от 3 107 ₽
AD9410BSVZ
7 299 ₽
Зенер
Россия и страны ТС
AD9410BSVZ
от 8 646 ₽
Hi-Tech Circuit Group
AD9410BSVZ
link to page 8
AD9410 ABSOLUTE MAXIMUM RATINGS Table 5.
Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress
Parameter Rating
rating only; functional operation of the device at these or any VD, VCC, VDD 6 V other conditions above those indicated in the operational Analog Inputs 0 V to VCC + 0.5 V section of this specification is not implied. Exposure to absolute Digital Inputs 0 V to VDD + 0.5 V maximum rating conditions for extended periods may affect VREFIN 0 V to VD + 0.5 V device reliability. Digital Output Current 20 mA Operating Temperature Range −55°C to +125°C Storage Temperature Range −65°C to +150°C
Maximum Junction Temperature1 150°C
Test Level
1 Adequate dissipation of power from the AD9410 relies on all power and I. 100% production tested. ground pins of the device being soldered directly to a copper plane on a PCB. In addition, the thermally enhanced package of the AD9410BSVZ has an exposed paddle on the bottom that must be soldered to a large copper II. 100% production tested at 25°C and sample tested at plane, which, for convenience, can be the ground plane. Sockets for package specified temperatures. style of the AD9410 device are not recommended. III. Sample tested only. IV. Parameter is guaranteed by design and characterization testing. V. Parameter is a typical value only. VI. 100% production tested at 25°C; guaranteed by design and characterization testing for industrial temperature range.
ESD CAUTION
Rev. A | Page 7 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS SWITCHING SPECIFICATIONS DIGITAL SPECIFICATIONS AC SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS EXPLAINATION OF TEST LEVELS Test Level ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY EQUIVALENT CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION USING THE AD9410 Clock Input ANALOG INPUT DIGITAL OUTPUTS CLOCK OUTPUTS (DCO, ) VOLTAGE REFERENCE TIMING DATA SYNC (DS) OUTLINE DIMENSIONS ORDERING GUIDE
