Datasheet AD7898 (Analog Devices) - 4
Описание5V, 12-Bit, Serial 220 kSPS ADC in a 8-Lead Package
Страниц / Страница17 / 4 — AD7898
ВерсияA
Формат / Размер файлаPDF / 243 Кб
AD7898
AD7898
Микросхема Преобразователь AD, ADC Single SAR 220KSPS 12Bit Serial 8Pin SOIC N T/R
ЧипСити
AD7898ARZ-10REEL
686 ₽
Эиком
AD7898ARZ-10REEL
от 2 074 ₽
AD7898ARZ-10REEL7
AD7898ARZ-10REEL7
AD7898 TIMING SPECIFICATIONS1 (VDD = 4.75 V to 5.25 V; VDRIVE = 2.7 V to 5.25 V; REF IN = 2.5 V; TA = TMIN to TMAX, unless otherwise noted.) Parameter Limit at TMIN, TMAX Unit Description Mode 0 Operation
t1 40 ns min CONVST Pulse Width t2 262 ns min SCLK High Pulse Width, VDRIVE = 5 V ± 5% t3 262 ns min SCLK Low Pulse Width, VDRIVE = 5 V ± 5% 302 ns min SCLK High Pulse Width VDRIVE = 2.7 V to 3.6 V 302 ns min SCLK Low Pulse Width VDRIVE = 2.7 V to 3.6 V t4 603 ns max Data Access Time after Falling Edge of SCLK, VDRIVE = 5 V ± 5% t4 703 ns max Data Access Time after Falling Edge of SCLK, VDRIVE = 2.7 V to 3.6 V t5 20 ns min Data Hold Time after Falling Edge of SCLK t6 504 ns max Bus Relinquish Time after Falling Edge of SCLK tCONVERT 3.3 µs
Mode 1 Operation
f 5 SCLK 1 kHz min 3.7 MHz max tCONVERT 16 × tSCLK tSCLK = 1/fSCLK 4.33 µs max fSCLK = 3.7 MHz tQUIET 100 ns min Minimum Quiet Time Required between Conversions t2 70 ns min CS to SCLK Setup Time t 3 3 40 ns max Delay from CS Until SDATA Three-State Disabled t 3 4 80 ns max Data Access Time after SCLK Falling Edge t5 108 ns min SCLK High Pulse Width t6 108 ns min SCLK Low Pulse Width t7 60 ns min SCLK to Data Valid Hold Time t 4 8 20 ns min SCLK Falling Edge to SDATA High Impedance 60 ns max SCLK Falling Edge to SDATA High Impedance tPOWER-UP 4.33 µs max Power-Up Time from Power-Down Mode NOTES 1Sample tested at 25°C to ensure compliance. All input signals are specified with tr = tf = 5 ns (10% to 90% of V DD) and timed from a voltage level of 1.6 V. 2The SCLK maximum frequency is 15 MHz for Mode 0 operation for 220 kSPS throughput with V DRIVE = 5 V ± 5%, SCLK = 13 MHz with VDRIVE = 2.7 V to 3.6 V. The mark/space ratio for SCLK is specified for at least 40% high time (with corresponding 60% low time) or 40% low time (with corresponding 60% high time). As the SCLK frequency is reduced, the mark/space ratio may vary, provided limits are not exceeded. Care must be taken when interfacing to account for the data access time, t4, and the set-up time required for the users processor. These two times will determine the maximum SCLK frequency that the user’s system can operate with. See Serial Interface section. 3Measured with the load circuit of Figure 1 and defined as the time required for the output to cross 0.8 V or 2.0 V. 4t6 and t8 are derived from the measured time taken by the data outputs to change 0.5 V when loaded with the circuit of Figure 1. The measured number is then extrapo- lated back to remove the effects of charging or discharging the 50 pF capacitor. This means that the time, t 6 and t8, quoted in the timing characteristics is the true bus relinquish time of the part and is independent of the bus loading. 5Mark/Space ratio for the SCLK input is 40/60 to 60/40. Specifications subject to change without notice. REV. A –3– Document Outline FEATURES GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE PIN CONFIGURATION PIN FUNCTION DESCRIPTIONS TERMINOLOGY Signal to (Noise + Distortion) Ratio Total Harmonic Distortion Peak Harmonic or Spurious Noise Intermodulation Distortion Relative Accuracy Differential Nonlinearity Positive Full-Scale Error (AD7898-10) Positive Full-Scale Error (AD7898-3) Bipolar Zero Error (AD7898-10, AD7898-3) Negative Full-Scale Error (AD7898-10) Negative Full-Scale Error (AD7898-3) Track/Hold Acquisition Time PSR (Power Supply Rejection) PERFORMANCE CURVES Noise CONVERTER DETAILS CIRCUIT DESCRIPTION Analog Input Section Acquisition Time TYPICAL CONNECTION DIAGRAM VDRIVE Feature Track/Hold Section Reference Input SERIAL INTERFACE OPERATING MODES Mode 0 Operation Mode 1 Operation Mode Selection Power-Down Mode Power-Up Times MICROPROCESSOR/MICROCONTROLLER INTERFACE FOR MODE 0 OPERATION 8x51/L51 to AD7898 Interface 68HC11/L11 to AD7898 Interface ADSP-2103/ADSP-2105 to AD7898 Interface DSP56002/L002 to AD7898 Interface MICROPROCESSOR INTERFACING FOR MODE 1 TMS320C5x/C54x to AD7898 Interface AD7898 to ADSP-21xx Interface AD7898 to DSP56xxx Interface AD7898 to MC68HC16 Interface OUTLINE DIMENSIONS Revision History
