Datasheet AD7865 (Analog Devices) - 7
ОписаниеFast, Low-Power, 4-Channel, Simultaneous Sampling, 14-bit ADC
Страниц / Страница20 / 7 — AD7865. PIN FUNCTION DESCRIPTIONS. Pin. Mnemonic. Description
ВерсияB
Формат / Размер файлаPDF / 243 Кб
AD7865 PIN FUNCTION DESCRIPTIONS Pin Mnemonic Description
21 предложений от 18 поставщиков
Микросхема Преобразователь AD, ANALOG DEVICES AD7865ASZ-2 Analogue to Digital Converter, Quad, 14Bit, 350KSPS, Single, 4.75V, 5.25V, QFP
AD7865ASZ-2REEL
2 093 ₽
AD7865ASZ-2
от 5 844 ₽
Эиком
AD7865ASZ-2
от 6 395 ₽
Hi-Tech Circuit Group
AD7865ASZ-2
1 BUSY Busy Output. The busy output is triggered high by the rising edge of CONVST and remains high until conversion is completed on all selected channels. 2 FRSTDATA First Data Output. FRSTDATA is a logic output which, when high, indicates that the Output Data Register Pointer is addressing Register 1—See Accessing the Output Data Registers. 3 CONVST Convert Start Input. Logic Input. A low-to-high transition on this input puts all track/holds into their hold mode and starts conversion on the selected channels. In addition, the state of the Channel Sequence Selection is also latched on the rising edge of CONVST. 4 CS Chip Select Input. Active low logic input. The device is selected when this input is active. 5 RD Read Input. Active low logic input which is used in conjunction with CS low to enable the data outputs. Ensure the WR pin is at logic high while performing a read operation. 6 WR Write Input. A rising edge on the WR input, with CS low and RD high, latches the logic state on DB0 to DB3 into the channel select register. 7 CLK IN/SL1 Conversion Clock Input/Hardware Channel Select. The function of this pin depends upon the H/S SEL input. When the H/S SEL input is high (choosing software control of the channel selection sequence), this pin assumes its CLK IN function. CLK IN is an externally applied clock (that is only necessary when INT/EXT CLK is high) this allows the user to control the conversion rate of the AD7865. Each conversion needs 16 clock cycles in order for the conver- sion to be completed. The clock should have a duty cycle that is no greater than 60/40. See Using an External Clock. When the H/S SEL input is low (choosing hardware control of the channel conversion se- quence), this pin assumes its Hardware Channel Select function. The SL1 input determines whether Channel 1 is included in the channel conversion sequence. The selection is latched on the rising edge of CONVST. See Selecting a Conversion Sequence. 8 INT/EXT CLK/SL2 Internal/External Clock/Hardware Channel Select. The function of this pin depends upon the H/S SEL input. When the H/S SEL input is high (choosing software control of the channel selection sequence), this pin assumes its INT/EXT CLK function. When INT/EXT CLK is at a Logic 0, the AD7865 uses its internally generated master clock. When INT/EXT CLK is at Logic 1, the master clock is generated externally to the device and applied to CLK IN. When the H/S SEL input is low (choosing hardware control of the channel conversion sequence), this pin assumes its Hardware Channel Select function. The SL2 input determines whether Channel 2 is included in the channel conversion sequence. The selection is latched on the rising edge of CONVST. When H/S is at Logic 1 these pins have no function and can be tied to Logic 1 or Logic 0. See Selecting a Conversion Sequence. 9, 10 SL3, SL4 Hardware Channel Select. When the H/S SEL input is at Logic 0, the SL3 input determines whether Channel 3 is included in the channel conversion sequence while SL4 determines whether Channel 4 is included in the channel conversion sequence. When the pin is at Logic 1, the channel is included in the conversion sequence. When the pin is at Logic 0, the channel is excluded from the conversion sequence. The selection is latched on the rising edge of CONVST. See Selecting a Conversion Sequence. 11 H/S SEL Hardware/Software Select Input. When this pin is at a Logic 0, the AD7865 conversion sequence selection is controlled via the SL1–SL4 input pins and runs off an internal clock. When this pin is at Logic 1, the conversion sequence is controlled via the channel select regis- ter and allows the ADC to run with an internal or external clock. See Selecting a Conversion Sequence. 12 AGND Analog Ground. General Analog Ground. This AGND pin should be connected to the system’s AGND plane. 13–16 VIN4x, VIN3x Analog Inputs. See Analog Input section. 17 AGND Analog Ground. Analog Ground reference for the attenuator circuitry. This AGND pin should be connected to the system’s AGND plane. 18–21 VIN2x, VIN1x Analog Inputs. See Analog Input section. 22 STBY Standby Mode Input. This pin is used to put the device into the power save or standby mode. The STBY input is high for normal operation and low for standby operation. 23 AGND Analog Ground. General Analog Ground. This AGND pin should be connected to the system’s AGND plane. –6– REV. B
