Datasheet AD7887 (Analog Devices) - 7
Описание2.7 V to 5.25 V, Micropower, 2-Channel, 125 kSPS, 12-Bit ADC in 8-Lead MSOP
Страниц / Страница25 / 7 — AD7887. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter. Rating. …
ВерсияE
Формат / Размер файлаPDF / 470 Кб
AD7887. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter. Rating. ESD CAUTION
AD7887 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 3 Parameter Rating ESD CAUTION
Микросхема Преобразователь AD, 2.7V to 5.25V, Micropower, 2Channel, 125KSPS, 12Bit ADC in 8-Lead MSOP
AD7887WARMZ-RL
258 ₽
AD7887WARMZ-RL
376 ₽
AD7887WARMZ-RL
от 570 ₽
IC Home
AD7887WARMZ-RL
723 ₽
TA = 25°C, unless otherwise noted.
Table 3.
Stresses above those listed under Absolute Maximum Ratings
Parameter Rating
may cause permanent damage to the device. This is a stress VDD to AGND −0.3 V to +7 V rating only; functional operation of the device at these or any Analog Input Voltage to AGND −0.3 V to VDD + 0.3 V other conditions above those indicated in the operational Digital Input Voltage to AGND −0.3 V to VDD + 0.3 V section of this specification is not implied. Exposure to absolute Digital Output Voltage to AGND −0.3 V to VDD + 0.3 V maximum rating conditions for extended periods may affect REFIN/REFOUT to AGND −0.3 V to VDD + 0.3 V device reliability. Input Current to Any Pin Except Supplies1 ±10 mA Operating Temperature Range
ESD CAUTION
Commercial Temperature Range A, B Versions −40°C to +125°C Storage Temperature Range −65°C to +150°C Junction Temperature +150°C SOIC or MSOP Package Power Dissipation 450 mW θJA Thermal Impedance 157°C/W (SOIC) 205.9°C/W (MSOP) θJC Thermal Impedance 56°C/W (SOIC) 43.74°C/W (MSOP) Lead Temperature, Soldering Vapor Phase (60 sec) 215°C Infrared (15 sec) 220°C Pb-Free Temperature, Soldering Reflow 260(0)°C ESD 4 kV 1 Transient currents of up to 100 mA do not cause SCR latch-up. Rev. E | Page 6 of 24 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Table of Contents Revision History Specifications Timing Specifications6F Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Terminology Control Register Theory of Operation Circuit Information Converter Operation ADC Transfer Function Typical Connection Diagram Analog Input On-Chip Reference Power-Down Options Power-Up Times Power vs. Throughput Rate Modes of Operation Mode 1 (PM1 = 0, PM0 = 0) Mode 2 (PM1 = 0, PM0 = 1) Mode 3 (PM1 = 1, PM0 = 0) Mode 4 (PM1 = 1, PM0 = 1) Serial Interface Microprocessor Interfacing AD7887 to TMS320C5x AD7887 to ADSP-21xx AD7887 to DSP56xxx AD7887 to MC68HC11 AD7887 to 8051 AD7887 to PIC16C6x/PIC16C7x Application Hints Grounding and Layout Outline Dimensions Ordering Guide Automotive Products
