Datasheet AD9283 (Analog Devices) - 3
Описание8-Bit, 50 MSPS/80 MSPS/100 MSPS ADC
Страниц / Страница13 / 3 — AD9283–SPECIFICATIONS (VDD = 3.0 V, VD = 3.0 V; single-ended input; …
ВерсияC
Формат / Размер файлаPDF / 281 Кб
AD9283–SPECIFICATIONS (VDD = 3.0 V, VD = 3.0 V; single-ended input; external reference, unless otherwise noted). Test
AD9283–SPECIFICATIONS (VDD = 3.0 V, VD = 3.0 V; single-ended input; external reference, unless otherwise noted) Test
28 предложений от 14 поставщиков
Микросхема Преобразователь AD, IC ADC 8Bit 50MSPS 3V 20-SSOP
AD9283BRSZ-RL50
от 323 ₽
Элитан
AD9283BRSZ-RL50
720 ₽
AD9283BRSZ-RL50
AD9283BRSZ-RL50
AD9283–SPECIFICATIONS (VDD = 3.0 V, VD = 3.0 V; single-ended input; external reference, unless otherwise noted) Test AD9283BRS-100 AD9283BRS-80 AD9283BRS-50 Parameter Temp Level Min Typ Max Min Typ Max Min Typ Max Unit
RESOLUTION 8 8 8 Bits DC ACCURACY Differential Nonlinearity 25°C I ±0.5 +1.25 ±0.5 +1.25 ±0.5 +1.25 LSB Full VI +1.50 +1.50 +1.50 LSB Integral Nonlinearity 25°C I –1.25 ±0.75 +1.25 –1.25 ±0.75 +1.25 –1.25 ±0.75 +1.25 LSB Full VI +2.25 +1.50 +1.50 LSB No Missing Codes Full VI Guaranteed Guaranteed Guaranteed Gain Error1 25°C I –6 ±2.5 +6 –6 ±2.5 +6 –6 ±2.5 +6 % FS Full VI –8 +8 –8 +8 –8 +8 % FS Gain Tempco1 Full VI 80 80 80 ppm/°C ANALOG INPUT Input Voltage Range (With Respect to AIN) Full V ±512 ±512 ±512 mV p-p Common-Mode Voltage Full V ±200 ±200 ±200 mV Input Offset Voltage 25°C I –35 ±10 +35 –35 ±10 +35 –35 ±10 +35 mV Full VI ±40 ±40 ±40 mV Reference Voltage Full VI 1.2 1.25 1.3 1.2 1.25 1.3 1.2 1.25 1.3 V Reference Tempco Full VI ±130 ±130 ±130 ppm/°C Input Resistance 25°C I 7 10 13 7 10 13 7 10 13 kΩ Full VI 5 16 5 16 5 16 kΩ Input Capacitance 25°C V 2 2 2 pF Full VI µA Analog Bandwidth, Full Power 25°C V 475 475 475 MHz SWITCHING PERFORMANCE Maximum Conversion Rate Full VI 100 80 50 MSPS Minimum Conversion Rate 25°C IV 1 1 1 MSPS Encode Pulsewidth High (tEH) 25°C IV 4.3 1000 5.0 1000 8.0 1000 ns Encode Pulsewidth Low (tEL) 25°C IV 4.3 1000 5.0 1000 8.0 1000 ns Aperture Delay (tA) 25°C V 0 0 0 ns Aperture Uncertainty (Jitter) 25°C V 5 5 5 ps rms Output Valid Time (tV)2 Full VI 2.0 3.0 2.0 3.0 2.0 3.0 ns Output Propagation Delay (tPD)2 Full VI 4.5 7.0 4.5 7.0 4.5 7.0 ns DIGITAL INPUTS Logic “1” Voltage Full VI 2.0 2.0 2.0 V Logic “0” Voltage Full VI 0.8 0.8 0.8 V Logic “1” Current Full VI ±1 ±1 ±1 µA Logic “0” Current Full VI ±1 ±1 ±1 µA Input Capacitance 25°C V 2.0 2.0 2.0 pF DIGITAL OUTPUTS Logic “1” Voltage Full VI 2.95 2.95 2.95 V Logic “0” Voltage Full VI 0.05 0.05 0.05 V Output Coding Offset Binary Code Offset Binary Code Offset Binary Code POWER SUPPLY Power Dissipation3, 4 Full VI 90 120 90 115 80 100 mW Power-Down Dissipation Full VI 4.2 7 4.2 7 4.2 7 mW Power Supply Rejection Ratio (PSRR) 25°C I 18 18 18 mV/V –2– REV. C
