Datasheet AD9051 (Analog Devices) - 5
Описание10-Bit, 60 MSPS A/D Converter
Страниц / Страница12 / 5 — AD9051. ABSOLUTE MAXIMUM RATINGS*. EXPLANATION OF TEST LEVELS. Test Level
ВерсияC
Формат / Размер файлаPDF / 698 Кб
AD9051 ABSOLUTE MAXIMUM RATINGS* EXPLANATION OF TEST LEVELS Test Level
33 предложений от 20 поставщиков
Микросхема Преобразователь AD, ANALOG DEVICES AD9051BRSZ Analog to Digital Converter, 10Bit, 60MSPS, Single, 5V, SSOP
Контест
AD9051BRSZ
1 963 ₽
Эиком
AD9051BRSZ
от 3 549 ₽
Hi-Tech Circuit Group
AD9051BRSZ
AD9051BRSZ2V
V
Test Level
D, VDD . 7 V Analog Inputs . –0.5 V to V I. 100% production tested. D + 0.5 V Digital Inputs . –0.5 V to VD II. 100% production tested at 25°C and sample tested at VREF Input . –0.5 V to VD specified temperatures. Digital Output Current . 20 mA Operating Temperature . –55°C to +125°C III. Sample tested only. Storage Temperature . –65°C to +150°C IV. Parameter is guaranteed by design and characterization Maximum Junction Temperature . 150°C testing. Maximum Case Temperature . 150°C V. Parameter is a typical value only.
Stresses above those listed under Absolute Maximum Ratings may cause perma- VI. 100% production tested at 25°C; guaranteed by design and nent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational characterization testing for industrial temperature range. sections of this specification is not implied. Exposure to absolute maximum ratings for extended periods may effect device reliability.
Table I. Digital Coding (Single-Ended Input with AIN, AINB Bypassed to GND) OR Digital Output Analog Input Voltage Level (Out of Range) MSB . LSB
3.126 (3.50)
Positive Full Scale + 1 LSB 1 1111111111 2.5 Midscale 0 0111111111 1.874 (1.50)
Negative Full Scale – 1 LSB 1 0000000000
(BRS-2V Version)
CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection. Although
WARNING!
the AD9051 features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high-energy electrostatic discharges. Therefore, proper ESD precautions are
ESD SENSITIVE DEVICE
recommended to avoid performance degradation or loss of functionality. –4– REV. C
