Datasheet AD7856 (Analog Devices) - 4
Описание5 V Single-Supply, 8-Channel, 14-Bit, 285 kSPS, Serial Sampling ADC
Страниц / Страница33 / 4 — AD7856. Parameter. A Version1. K Version1. Units. Test Conditions/Comments
ВерсияA
Формат / Размер файлаPDF / 331 Кб
AD7856 Parameter A Version1 K Version1 Units Test Conditions/Comments
29 предложений от 17 поставщиков
Микросхема Преобразователь AD, * Single 5V Supply * 285KSPS Throughput Rate * Self- and System Calibration with Autocalibration on * Power-Up...
AD7856ARSZ
от 530 ₽
ЧипСити
AD7856ARSZ
1 308 ₽
AD7856ARSZ
от 1 430 ₽
AD7856ARSZ
от 3 570 ₽
POWER PERFORMANCE AVDD, DVDD +4.75/+5.25 +4.75/+5.25 V min/max IDD Normal Mode5 17 17 mA max AVDD = DVDD = 4.75 V to 5.25 V. Typically 12 mA Sleep Mode6 With External Clock On 30 10 µA typ Full Power-Down. Power Management Bits in Con- trol Register Set as PMGT1 = 1, PMGT0 = 0 400 500 µA typ Partial Power-Down. Power Management Bits in Control Register Set as PMGT1 = 1, PMGT0 = 1 With External Clock Off 5 5 µA max Typically 0.5 µA. Full Power-Down. Power Manage- ment. Bits in Control Register Set as PMGT1 = 1, PMGT0 = 0 200 200 µA typ Partial Power-Down. Power Management Bits in Control Register Set as PMGT1 = 1, PMGT0 = 1 Normal Mode Power Dissipation 89.25 89.25 mW max VDD = 5.25 V. Typically 60 mW; SLEEP = VDD Sleep Mode Power Dissipation With External Clock On 52.5 52.5 µW typ VDD = 5.25 V. SLEEP = 0 V With External Clock Off 26.25 26.25 µW max VDD = 5.25 V. Typically 5.25 µW; SLEEP = 0 V SYSTEM CALIBRATION Offset Calibration Span7 +0.0375 × VREF/–0.0375 × VREF V max/min Allowable Offset Voltage Span for Calibration Gain Calibration Span7 +1.01875 × VREF/–0.98125 × VREF V max/min Allowable Full-Scale Voltage Span for Calibration NOTES 1Temperature ranges as follows: A Version: –40°C to +105°C. K Version: 0°C to +105°C. 2Specifications apply after calibration. 3SNR calculation includes distortion and noise components. 4Sample tested @ +25°C to ensure compliance. 5All digital inputs @ DGND except for CONVST, SLEEP, CAL and SYNC @ DVDD. No load on the digital outputs. Analog inputs @ AGND. 6CLKIN @ DGND when external clock off. All digital inputs @ DGND except for CONVST, SLEEP, CAL, and SYNC @ DVDD. No load on the digital outputs. Analog inputs @ AGND. 7The Offset and Gain Calibration Spans are defined as the range of offset and gain errors that the AD7856 can calibrate. Note also that these are voltage spans and are not absolute voltages (i.e., the allowable system offset voltage presented at AIN(+) for the system offset error to be adjusted out will be AIN(–) ± 0.0375 × VREF, and the allowable system full-scale voltage applied between AIN(+) and AIN(–) for the system full-scale voltage error to be adjusted out will be V REF ± 0.01875 × VREF). This is explained in more detail in the Calibration section of the data sheet. Specifications subject to change without notice. REV. A –3–
