Datasheet AD7731 (Analog Devices) - 2
ОписаниеLow Noise, High Throughput 24-Bit Sigma-Delta ADC
Страниц / Страница45 / 2 — AD7731* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
ВерсияA
Формат / Размер файлаPDF / 862 Кб
AD7731* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Technical Articles
AD7731* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS Technical Articles
28 предложений от 18 поставщиков
Микросхема Преобразователь AD, ANALOG DEVICES AD7731BNZ Analog to Digital Converter, 24Bit, 6.4KSPS, Single, 2.7V, 5.25V, DIP
AD7731BNZ
от 661 ₽
AD7731BNZ
966 ₽
AD7731BNZ
2 263 ₽
Контест
AD7731BNZ
3 840 ₽
View a parametric search of comparable parts.
Technical Articles
• Delta-Sigma Rocks RF, As ADC Designers Jump On Jitter
EVALUATION KITS
• MS-2210: Designing Power Supplies for High Speed ADC • AD7731 Evaluation Kit • Part 1: Circuit Suggestions Using Features and Functionality of New Sigma-Delta ADCs
DOCUMENTATION
• Part 2: Circuit Suggestions Using Features and
Application Notes
Functionality of New Sigma-Delta ADCs • AN-202: An IC Amplifier User’s Guide to Decoupling, Grounding, and Making Things Go Right for a Change
DESIGN RESOURCES
• AN-283: Sigma-Delta ADCs and DACs • AD7731 Material Declaration • AN-311: How to Reliably Protect CMOS Circuits Against • PCN-PDN Information Power Supply Overvoltaging • Quality And Reliability • AN-388: Using Sigma-Delta Converters-Part 1 • Symbols and Footprints • AN-389: Using Sigma-Delta Converters-Part 2 • AN-397: Electrically Induced Damage to Standard Linear
DISCUSSIONS
Integrated Circuits: View all AD7731 EngineerZone Discussions. • AN-607: Selecting a Low Bandwidth (<15 kSPS) Sigma- Delta ADC
SAMPLE AND BUY
• AN-615: Peak-to-Peak Resolution Versus Effective Visit the product page to see pricing options. Resolution
Data Sheet TECHNICAL SUPPORT
• AD7731: Low Noise, High Throughput 24-Bit Sigma-Delta ADC Data Sheet Submit a technical question or find your regional support number.
TOOLS AND SIMULATIONS DOCUMENT FEEDBACK
• AD7730/AD7730L/AD7731 Digital Filter Model Submit feedback for this data sheet. • dt_Register_Assistant • Sigma-Delta ADC Tutorial
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM AD7731-SPECIFICATIONS TIMING CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS Ordering Guide ESD Caution PIN CONFIGURATION Pin Function Descriptions TERMINOLOGY OUTPUT NOISE AND RESOLUTION SPECIFICATION Output Noise (CHP = 0, SKIP= 1) Output Noise (CHP = 1, SKIP = 0) ON-CHIP REGISTERS Communications Register (RS2-RS0 = 0, 0, 0) Status Register (RS2-RS0 = 0, 0, 0); Power-On/Reset Status: CX Hex Data Register (RS2-RS0 = 0, 0, 1); Power On/Reset Status: 000000 Hex Mode Register (RS2-RS0 = 0, 1, 0); Power-On/Reset Status: 0174 Hex Filter Register (RS2-RS0 = 0, 1, 1); Power-On/Reset Status: 2002 Hex Offset Calibration Register (RS2-RS0 = 1, 0, 1) Gain Calibration Register (RS2-RS0 = 1, 1, 0) Test Register (RS2-RS0 = 1, 1, 1); Power On/Reset Status: 000000 Hex READING FROM AND WRITING TO THE ON-CHIP REGISTERS CALIBRATION OPERATION SUMMARY CIRCUIT DESCRIPTION ANALOG INPUT Analog Input Channels Buffered Inputs Analog Input Ranges Programmable Gain Amplifier Bipolar/Unipolar Inputs Burnout Currents REFERENCE INPUT Reference Detect SIGMA-DELTA MODULATOR DIGITAL FILTERING Filter Architecture First State Filter/SKIP Mode Enabled (SKIP =1) Nonchop Mode (SKIP =1, CHP = 0) Chop Mode (SKIP = 1, CHP =1) Second Stage Filter Normal FIR Operation (SKIP = 0) Chop Mode (SKIP = 0, CHP =1) Nonchop Mode (SKIP = 1, CHP = 0) FASTStep Mode (SKIP = 0, FAST = 1) CALIBRATION Internal Zero-Scale Calibration Internal Full-Scale Calibration System Zero-Scale Calibration System Full-Scale Calibration Span and Offset Limits Power-Up and Calibration Drift Considerations USING THE AD7731 Clocking and Oscillator Circuit System Synchronization Single-Shot Conversions Reset Input Standby Mode Digital Outputs POWER SUPPLIES Grounding and Layout Evaluting the AD7731 Performance SERIAL INTERFACE Write Operation Read Operation CONFIGURING THE AD7731 MICROCOMPUTER/MICROPROCESSOR INTERFACING AD7731 to 68HC11 Interface AD7731 to 8051 Interface AD7731 to ADSP-2103/ADSP-2105 Interface APPLICATIONS Data Acquisition Programmable Logic Controllers Pressure Measurement Temperature Measurement Bipolar Input Signals PAGE INDEX TABLE INDEX OUTLINE DIMENSIONS
