Datasheet AD9200 (Analog Devices) - 9
Описание10-Bit, 20 MSPS, 80 mW CMOS A/D Converter
Страниц / Страница25 / 9 — AD9200. APPLYING THE AD9200. THEORY OF OPERATION. –12. –15. –18. SIGNAL …
ВерсияE
Формат / Размер файлаPDF / 378 Кб
AD9200. APPLYING THE AD9200. THEORY OF OPERATION. –12. –15. –18. SIGNAL AMPLITUDE – dB. –21. –24. –27. 1.0E+6. 10.0E+6. 100.0E+6. 1.0E+9
AD9200 APPLYING THE AD9200 THEORY OF OPERATION –12 –15 –18 SIGNAL AMPLITUDE – dB –21 –24 –27 1.0E+6 10.0E+6 100.0E+6 1.0E+9
48 предложений от 20 поставщиков
Микросхема Преобразователь AD, Analog to Digital Converters - ADC 10B 20MSPS 80mW CMOS
AD9200ARSZRL
106 ₽
ICdarom.ru
AD9200ARSZRL
от 464 ₽
AD9200ARSZRL
1 724 ₽
AD9200ARSZRL
AD9200 0 APPLYING THE AD9200 –3 THEORY OF OPERATION
The AD9200 implements a pipelined multistage architecture to
–6
achieve high sample rate with low power. The AD9200 distrib-
–9
utes the conversion over several smaller A/D subblocks, refining the conversion with progressively higher accuracy as it passes
–12
the results from stage to stage. As a consequence of the distrib-
–15
uted conversion, the AD9200 requires a small fraction of the
–18
1023 comparators used in a traditional flash type A/D. A
sample-and-hold function within each of the stages permits the
–21
first stage to operate on a new input sample while the second,
–24
third and fourth stages operate on the three preceding samples.
–27 1.0E+6 10.0E+6 100.0E+6 1.0E+9 OPERATIONAL MODES FREQUENCY – Hz
The AD9200 is designed to allow optimal performance in a wide variety of imaging, communications and instrumentation Figure 13. Full Power Bandwidth applications, including pin compatibility with the AD876 A/D. To realize this flexibility, internal switches on the AD9200 are used to reconfigure the circuit into different modes. These modes
25
are selected by appropriate pin strapping. There are three parts of the circuit affected by this modality: the voltage reference, the
20
reference buffer, and the analog input. The nature of the appli-
15
cation will determine which mode is appropriate: the descrip-
10
tions in the following sections, as well as the Table I should
REFBS = 0.5V 5 REFTS = 2.5V
assist in picking the desired mode.
A CLOCK = 20MHz
m
0 – I B –5 –10 –15 –20 –25 0 0.5 1.0 1.5 2.0 2.5 3.0 INPUT VOLTAGE – V
Figure 14. Input Bias Current vs. Input Voltage
Table I. Mode Selection Input Input MODE REFSENSE Modes Connect Span Pin Pin REF REFTS REFBS Figure
TOP/BOTTOM AIN 1 V AVDD Short REFSENSE, REFTS and VREF Together AGND 18 AIN 2 V AVDD AGND Short REFTS and VREF Together AGND 19 CENTER SPAN AIN 1 V AVDD/2 Short VREF and REFSENSE Together AVDD/2 AVDD/2 20 AIN 2 V AVDD/2 AGND No Connect AVDD/2 AVDD/2 Differential AIN Is Input 1 1 V AVDD/2 Short VREF and REFSENSE Together AVDD/2 AVDD/2 29 REFTS and REFBS Are Shorted Together for Input 2 2 V AVDD/2 AGND No Connect AVDD/2 AVDD/2 External Ref AIN 2 V max AVDD AVDD No Connect Span = REFTS 21, 22 – REFBS (2 V max) AGND Short to Short to 23 VREFTF VREFBF AD876 AIN 2 V Float or AVDD No Connect Short to Short to 30 AVSS VREFTF VREFBF –8– REV. E
