Datasheet AD7854, AD7854L (Analog Devices) - 8
Описание3 V to 5 V Single Supply, 200 kSPS, 12-Bit, Parallel Sampling ADC
Страниц / Страница28 / 8 — AD7854/AD7854L. AD7854/AD7854L ON-CHIP REGISTERS
ВерсияB
Формат / Размер файлаPDF / 265 Кб
AD7854/AD7854L AD7854/AD7854L ON-CHIP REGISTERS
14 предложений от 14 поставщиков
Микросхема Преобразователь AD, Analog to Digital Converters - ADC 3-5V SGL Supply 200KSPS 12B Parallel
Xinhuo Future
AD7854LARSZ-REEL
838 ₽
Рутоника
AD7854LARSZ-REEL
844 ₽
AD7854LARSZ-REEL
AD7854LARSZ-REEL
The AD7854/AD7854L powers up with a set of default conditions, and the user need not ever write to the device. In this case the AD7854/AD7854L will operate as a read-only ADC. The WR pin should be tied to DVDD for operating the AD7854/AD7854L as a read-only ADC. Extra features and flexibility such as performing different power-down options, different types of calibrations including system cali- bration, and software conversion start can be selected by writing to the part. The AD7854/AD7854L contains a
control register, ADC output data register, status register, test register
and
10 calibra- tion registers
. The control register is write-only, the ADC output data register and the status register are read-only, and the test and calibration registers are both read/write registers. The test register is used for testing the part and should not be written to.
Addressing the On-Chip Registers
Writing To write to the AD7854/AD7854L, a 16-bit word of data must be transferred. This transfer consists of two 8-bit writes. The first 8 bits of data that are written must consist of the 8 LSBs of the 16-bit word and the second 8 bits that are written must consist of the 8 MSBs of the 16-bit word. For each of these 8-bit writes, the data is placed on Pins DB0 to DB7, Pin DB0 being the LSB of each transfer and Pin DB7 being the MSB of each transfer. The two MSBs of the 16-bit word, ADDR1 and ADDR0, are decoded to determine which register is addressed, and the 14 LSBs are written to the addressed register. Table I shows the decoding of the address bits, while Figure 2 shows the overall write register hierarchy.
Table I. Write Register Addressing ADDR1 ADDR0 Comment
0 0 This combination does not address any register. 0 1 This combination addresses the
TEST REGISTER
. The 14 LSBs of data are written to the test register. 1 0 This combination addresses the
CALIBRATION REGISTER
. The 14 least significant data bits are writ- ten to the selected calibration register. 1 1 This combination addresses the
CONTROL REGISTER
. The 14 least significant data bits are written to the control register. Reading To read from the various registers the user must first write to Bits 6 and 7 in the Control Register, RDSLT0 and RDSLT1. These bits are decoded to determine which register is addressed during a read operation. Table II shows the decoding of the read address bits while Figure 3 shows the overall read register hierarchy. The power-up status of these bits is 00 so that the default read will be from the ADC output data register. Note: when reading from the calibration registers, the low byte must always be read first. Once the read selection bits are set in the control register all subsequent read operations that follow are from the selected register until the read selection bits are changed in the control register.
Table II. Read Register Addressing RDSLT1 RDSLT0 Comment
0 0 All successive read operations are from the
ADC OUTPUT DATA REGISTER
. This is the default power- up setting. There is always four leading zeros when reading from the ADC output data register. 0 1 All successive read operations are from the
TEST REGISTER
. 1 0 All successive read operations are from the
CALIBRATION REGISTERS
. 1 1 All successive read operations are from the
STATUS REGISTER
ADDR1, ADDR0 RDSLT1, RDSLT0 DECODE DECODE 01 10 11 00 01 10 11 TEST CALIBRATION CONTROL ADC OUTPUT TEST CALIBRATION CONTROL REGISTER REGISTERS REGISTER DATA REGISTER REGISTER REGISTERS REGISTER GAIN(1) GAIN(1) GAIN(1) GAIN(1) OFFSET(1) GAIN(1) OFFSET(1) OFFSET(1) GAIN(1) OFFSET(1) OFFSET(1) OFFSET(1) DAC(8) DAC(8) CALSLT1, CALSLT0 00 01 10 11 CALSLT1, CALSLT0 00 01 10 11 DECODE DECODE
Figure 2. Write Register Hierarchy/Address Decoding Figure 3. Read Register Hierarchy/Address Decoding –8– REV. B
