Datasheet AD7891 (Analog Devices) - 4
ОписаниеTrue Bipolar Input, Single Supply, Parallel, 8-Channel, 12-Bit High Speed Data Acquisition System
Страниц / Страница21 / 4 — AD7891. Parameter. A Version1. B Version. Y Version. Unit. Test …
ВерсияD
Формат / Размер файлаPDF / 398 Кб
AD7891. Parameter. A Version1. B Version. Y Version. Unit. Test Conditions/Comments. ABSOLUTE MAXIMUM RATINGS*. CAUTION
AD7891 Parameter A Version1 B Version Y Version Unit Test Conditions/Comments ABSOLUTE MAXIMUM RATINGS* CAUTION
31 предложений от 20 поставщиков
Интегральные микросхемы Микросхемы сбора данных - АЦП/ЦАП специального назначения
AD7891APZ-1
от 774 ₽
AD7891APZ-1REEL
2 078 ₽
AD7891APZ-1
от 4 513 ₽
МосЧип
AD7891APZ-1
LOGIC OUTPUTS Output High Voltage, VOH 4.0 4.0 4.0 V min ISOURCE = 200 mA. Output Low Voltage, VOL 0.4 0.4 0.4 V max ISINK = 1.6 mA. DB11to DB0 Floating-State Leakage Current ±10 ±10 ±10 mA max Floating-State Capacitance5 15 15 15 pF max Output Coding Straight (Natural) Binary Data format bit of control register = 0. Twos Complement Data format bit of control register = 1. CONVERSION RATE Conversion Time 1.6 1.6 1.6 ms max Track/Hold Acquisition Time 0.6 0.6 0.6 ms max AD7891-1 hardware conversion. 0.7 0.7 0.7 ms max AD7891-1 software conversion. 0.4 0.4 0.4 ms max AD7891-2. POWER REQUIREMENTS VDD 5 5 5 V nom ±5% for specified performance. IDD Normal Mode 20 20 21 mA max Standby Mode 80 80 80 mA max Logic inputs = 0 V or VDD. Power Dissipation VDD = 5 V. Normal Mode 100 100 105 mW max Typically 82 mW. Standby Mode 400 400 400 mW max Typically 75 mW. NOTES 1Temperature ranges for the A and B Versions: –40∞C to +85∞C. Temperature range for the Y Version: –55∞C to +105∞C. 2The AD7891-1’s dynamic performance (THD and SNR) and the AD7891-2’s THD are measured with an input frequency of 10 kHz. The AD7891-2’s SNR is evaluated with an input frequency of 100 kHz. 3This throughput rate can only be achieved when the part is operated in the parallel interface mode. Maximum achievable throughput rate in the serial interface mode is 357 kSPS. 4See the Terminology section. 5Sample tested during initial release and after any redesign or process change that may affect this parameter. 6REF IN must be buffered before being applied to VINXB. Specifications subject to change without notice.
Junction Temperature . 150∞C (TA = 25∞C, unless otherwise noted) MQFP Package, Power Dissipation . 450 mW V q DD to AGND . –0.3 V to +7 V JA Thermal Impedance . 95∞C/W V Lead Temperature, Soldering DD to DGND . –0.3 V to +7 V Analog Input Voltage to AGND Vapor Phase (60 sec) . 215∞C AD7891-1 . ± 17 V Infrared (15 sec) . 220∞C AD7891-2 . –5 V, +10 V PLCC Package, Power Dissipation . 500 mW Reference Input Voltage to AGND . –0.3 V to V q DD + 0.3 V JA Thermal Impedance . 55∞C/W Digital Input Voltage to DGND . –0.3 V to V Lead Temperature, Soldering DD + 0.3 V Digital Output Voltage to DGND . –0.3 V to V Vapor Phase (60 sec) . 215∞C DD + 0.3 V Operating Temperature Range Infrared (15 sec) . 220∞C Commercial (A, B Versions) . – 40∞C to +85∞C *Stresses above those listed under Absolute Maximum Ratings may cause perma- Automotive (Y Version) . –55∞C to +105∞C nent damage to the device. This is a stress rating only; functional operation of the Storage Temperature Range . –65∞C to +150∞C device at these or any other conditions above those listed in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection. Although the AD7891 features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high energy electrostatic discharges. Therefore, proper ESD precautions are recommended to avoid performance degradation or loss of functionality. REV. D –3– Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS TIMING CHARACTERISTICS ORDERING GUIDE PIN CONFIGURATIONS PIN FUNCTION DESCRIPTIONS PARALLEL INTERFACE MODE FUNCTIONS Data I/O Lines Parallel Read Operation SERIAL INTERFACE MODE FUNCTIONS CONTROL REGISTER TERMINOLOGY Signal-to-(Noise + Distortion) Ratio Total Harmonic Distortion (THD) Peak Harmonic or Spurious Noise Intermodulation Distortion Channel-to-Channel Isolation Relative Accuracy Differential Nonlinearity Positive Full-Scale Error (AD7891-1, ±10 V and ±5 V; AD7891-2, ±2.5 V) Positive Full-Scale Error (AD7891-2, 0 V to 5 V and 0 V to 2.5 V) Bipolar Zero Error (AD7891-1, ±10 V and ±5 V; AD7891-2, ±2.5 V) Unipolar Offset Error (AD7891-2, 0 V to 5 V and 0 V to 2.5 V) Negative Full-Scale Error (AD7891-1, ±10 V and ±5V; AD7891-2, ±2.5 V) Track/Hold Acquisition Time CONVERTER DETAILS INTERFACE INFORMATION Parallel Interface Mode Serial Interface Mode Simplifying the Serial Interface CIRCUIT DESCRIPTION Reference Analog Input Section Track/Hold Amplifier STANDBY Operation MICROPROCESSOR INTERFACING AD7891 to 8X51 Serial Interface AD7891 to 68HC11 Serial Interface AD7891 to ADSP-21xx Serial Interface AD7891 to DSP5600x Serial Interface AD7891 to TMS320xxx Serial Interface PARALLEL INTERFACING AD7891 to ADSP-21xx AD7891 to TMS32020, TMS320C25, and TMS320C5x AD7891 to TMS320C3x AD7891 to DSP5600x Power Supply Bypassing and Grounding AD7891 PERFORMANCE Linearity Noise Dynamic Performance Effective Number of Bits OUTLINE DIMENSIONS Revision History
